#93770 - 14/05/2002 09:20
Wish: Headlight warner
Loc: Copenhagen SW, Denmark
Here is a request for a feature that may belong to hijack or to the main software...
How about a warning-sound for when the engine is turned off, but the headlights forgotten?
(when ignition-sense==off and headlight-sense=on do Beep)
Marius (Escort Cab + Mark II)
#93771 - 14/05/2002 09:51
Re: Wish: Headlight warner
[Re: jane]
Loc: Germany (Ruhrgebiet)
Hi.
Why not play a user definable sound if that happens? Like "Turn of the light, idiot"
cu,
sven
#93772 - 14/05/2002 09:57
[Re: jane]
Pah, my car already does this anyway -- if the ignition's off, but the lights are on, it emits a continuous tone when you open the driver's door.
#93773 - 14/05/2002 10:01
[Re: Roger]
My thoughts exactly. Maybe I'll take a quick gander sometime to see if it's easily doable in Hijack - but there's plenty of other stuff that has a higher priority, and my time is limited at the moment.
#93774 - 14/05/2002 10:38
[Re: Roger]
Maybe we could hook up the door-sensor to the phone-mute line, and achieve that :-)
#93775 - 14/05/2002 14:33
[Re: jane]
I would have to agree on this. If it's going to be a usable feature it would need to be triggered by opening the doors, as most people (I think) turn the car off before they turn their lights off.
My car dings when I leave the lights on, so it wouldn't be worth fishing for the door line to me.
#93776 - 14/05/2002 14:35
[Re: jane]
Loc: chicago
the player has no concept of on or off, does it? it's simply "state A" or "state B", as different cars use different types of signaling for the headlight sense. or am i missing something?
--dan.
#93777 - 15/05/2002 03:16
[Re: djc]
Nope, you're not missing anything. The player doesn't know whether the lights are on or off.
#93778 - 15/05/2002 10:54
[Re: Roger]
Loc: San Jose, CA
Why can't it use the headlight sense?
Calvin
#93779 - 15/05/2002 11:13
[Re: eternalsun]
The player only knows that the line is high or low, and allows you to assign a different dimmer setting to each state, without ever interpreting what that state actually means. The stock kernel doesn't attempt to interpret it.
The button LED code in Hijack assumes that 12V means that the headlights are on, and 0V means that they are off. I'm confident that this will bite us at some point if the button LED hack becomes popular. At some point I'm looking to rework the button LED code anyway - and I'll probably add a Hijack option Dimmer_line_is_inverted or similar. Once that happens then doing stuff like "if (headlights && accessory_line_is_low) {beep}" becomes more feasible.
#93780 - 15/05/2002 11:22
[Re: eternalsun]
Argh, you're not listening!
Because the headlight sense doesn't know the difference between "off" and "on". It just knows "line is high" and "line is low" and adjusts the dimmer to two user-controlled presets accordingly. Different cars do it opposite of each other.
Okay, the above thing could be handled with an INI setting. But here is the other problem with using the empeg as your headlight-warner: Headlight warning is only useful if the key is out of the ignition. But if the key is pulled out of the ignition, then the empeg goes into sleep mode and the amplifier is turned off, hence no way for the empeg to make a warning sound.
#93781 - 15/05/2002 11:33
That wouldn't be too hard to deal with - we'd delay standby until both accessory and the 'normalised' headlight line were both low. And the feature would be off by default too so that it would be totally backwards compatible.
The biggest problem is the time taken to do this. Both Mark and I are working at the moment, and other stuff has a higher priority. (Such as fixing the button LEDs for everyone, extending the range of bass/treble controls, AC mode display dimming etc).
Actually, I'd really like to see beta13...I'd hate to work on stuff only to see it obsoleted.
#93782 - 15/05/2002 11:41
[Re: genixia]
I wouldn't worry too much about that. The next beta will only be bug fixes. Internal Beta12 hasn't made your stuff break, I don't see any reason why the next one should.
#93783 - 15/05/2002 11:50
Hey how come he has Internal beta 12? No fair!
#93784 - 15/05/2002 11:52
[Re: tonyc]
Because the alpha team gets all internal betas.
#93785 - 15/05/2002 11:57
Ah, didn't know genixia was also on the alpha team. Nevermind.
#93786 - 15/05/2002 11:59
[Re: tonyc]
He isn't, that's why he's worried about the next beta breaking things.
He didn't say he had beta 12. I did.
#93787 - 15/05/2002 12:00
[Re: tonyc]
I'm not. (Yet!!?????????????? beg???) So the news that internal beta12 hasn't broken any of my code is reassuring
#93788 - 15/05/2002 12:01
Oh, I get it. YOU tested his stuff on the betas. I think I missed a pronoun somewhere. Move along, nothing to see here.
#93789 - 15/05/2002 12:11
Loc: San Jose, CA
oops, that's what I get for reading this thread in "flat" mode. The replies are disconnected from their contexts. Oh well.
Calvin
#93790 - 15/05/2002 12:13
[Re: tonyc]
Loc: San Jose, CA
Tony has a habit of accusing innocent people of having the beta. :-) I've been the victim of that as well. :-D *razz*
Calvin
#93791 - 15/05/2002 12:24
[Re: eternalsun]
A problem which could be solved by, gee, giving us these betas.
#93792 - 15/05/2002 13:10
[Re: jane]
Most cars already do this if they were built after a certain date.
You may be able to retro fit a small electronics circuit to do the same for a whole lot less sodding around.
Two thyristors (i think) in line one being switched by the ignition and the second by the lights might work. I could do it in relays i understand relay. Thyrisitors my only experince of them is in diesel electric ships where we use them to control and power the main engines
Aberdeen Scotland
#93793 - 15/05/2002 15:27
[Re: thinfourth2]
I want to do it with the empeg because it is *cool*
#93794 - 17/05/2002 13:26
Loc: Florida, USA
My MkIIa by default when I got it continued to play for 1 minute after I turned off the ignition and took the keys out, left the car and didn't turn off until I was a good distance from it. I have since set it to only 30 seconds, but it keeps playing after my car is shut of. Is there something wrong with my unit or is this a feature specific to the MkIIa?
Daniel
[blue] 10G MkIIa [/blue]
Quantum Mechanics: The Dreams Stuff are made of.
#93795 - 17/05/2002 13:45
[Re: Ralyon]
Click here for one possible explanation, but the "one minute" thing sounds like it could be more complicated than that.
Sounds like something is miswired, causing the ignition-switched wire on the player to maintain voltage after the car is shut off. For instance, if you connected it to something other than the ignition-swiched wire on the car. An example would be if you connected the Orange wire from the sled to the Orange wire on the car just because they were the same color (assuming that the color codes meant something without actually checking what each wire did). On many aftermarket harness adapters, the Orange wire is actually the headlight sense wire, not the ignition switched wire.
#93796 - 17/05/2002 13:46
Or it could have been the known Jiffies bug in Beta11. Have you installed a recent Hijack (which fixes the bug)?
#93797 - 21/05/2002 14:36
Loc: San Jose, CA
The other day, when I turned off my car, the car unit kept playing for a good 20 seconds before it realized the power is out and it shut down. I wonder if this is related.
Calvin
#93798 - 21/05/2002 14:41
[Re: eternalsun]
Yeah, this bug seems to have several corrolaries, like how you sometimes have to hold the rewind button for 10 seconds before it responds to your press. I think they're the same bug. But I've never seen it go longer than that.
#93799 - 21/05/2002 14:59
Bitt-warning. I suggest that manifestations would have been a better choice.
