#8910 - 04/06/2000 23:49 Backlit Buttons?
CHiP
Sorry if someone asked this already, but when i was looking on the new site, i noticed that the buttons on the new MarkII have lights behind them... Is this true?
-CHiP
-CHiP
#8911 - 05/06/2000 00:33 Re: Backlit Buttons? [Re: CHiP]
teemcbee
Right, the buttons have the possibility to be backlit, but they are not transparent so the are not backlit at the moment.
TeeMcBee
TeeMcBee
#8912 - 05/06/2000 09:35 Re: Backlit Buttons? [Re: teemcbee]
To clarify even further...
The buttons that ship with the Empeg do not have lights inside them, although there is a space inside the buttons for lights if you wanted to do some really precision soldering. Or purchase replacement buttons that already had the lights in them. The photo of the backlit buttons at the website was one of the developer's (or was it Rob's?) units where they did the lit-button hack for fun.
#8913 - 05/06/2000 16:25 Re: Backlit Buttons? [Re: tfabris]
CHiP
Lit Button hack for fun? What does that mean? I mean, are there lights behind the buttons or not? and if there is, are you saying that they don't go on because of software?
-CHiP
-CHiP
#8914 - 05/06/2000 16:30 Re: Backlit Buttons? [Re: tfabris]
ppslim
Loc: N Wales, UK
They are saying they are not there, but they could be installed into the panel. The buttons on the pucture where placed there by themselves (or who evers pannel that actualy was).
Proud owner of #161
Proud owner of #161
#8915 - 05/06/2000 16:40 Re: Backlit Buttons? [Re: CHiP]
It means that one of the developers wondered what backlit buttons might look like on an Empeg Car and hacked (hardware hacked, i.e., soldering-iron-and-needlenose-pliers hacked) some LEDs onto the unit.
No, there are no lights behind the buttons. The buttons themselves are the kind that you could insert lights into them if you wanted to, but you'd have to do some delicate soldering work and know exactly what you were doing. And you'd have to fashion or obtain translucent button caps, too.
I think the option to control them via software could actually be implemented, but I don't know if you could do it independently of the display or not. They would probably just turn on and off with the display.
#8916 - 06/06/2000 01:02 Re: Backlit Buttons? [Re: tfabris]
jfranke
I'm really keen on the backlit buttons - any knows if there are plans to provide transparent buttons ? Doing them themself probably doesn't give the best result back...
And I wonder why that hesn't been implemented into production - I think that would be a very nice feature.
J.
#8917 - 06/06/2000 01:04 Re: Backlit Buttons? [Re: jfranke]
jfranke
Ops, forgot to ask one thing - anyone knows if there are circuits on the display-panel PCB where the LED's could be soldered onto ? Cheers, J.
#8918 - 06/06/2000 01:27 Re: Backlit Buttons? [Re: jfranke]
teemcbee
Maybe the guys@empeg could provide transparent & backlit buttons in a faceplate-upgrade a little later (when they have time)
TeeMcBee
TeeMcBee
#8919 - 06/06/2000 03:50 Re: Backlit Buttons? [Re: jfranke]
We've already stated why we're not using backlit buttons on the production model, but here it is again:
1. We can't get enough white LED's, which would be needed if the button caps were to match the main display colour.
2. The button caps were not designed with backlighting in mind, so they won't diffuse the light well.
3. Having backlit buttons but not a backlit rotary control would look a bit odd.
4. The new buttons have a good contrast (both in colour and feel) with the rest of the player, and it's not hard to locate the one you want to use in the dark.
Just for fun, though, we're going to try to persuade the plastics people to run one complete set of parts in transparant plastic. I wonder how much the world's only "i-empeg" will be worth in years to come :-)
#8920 - 06/06/2000 04:53 Re: Backlit Buttons? [Re: jfranke]
Yes, there are circuits. You need to fit a 1206 sized SMD 4-resistor pack and 4x 3mm LEDs, and write some software to send the correct ioctl to the display driver to turn the lights on (you can turn them on/off/dim them). They all turn on/off together, and can run wether or not the display is on.
As rob said, you also need transparent caps.
Basically, it's not a user-fit job. The PCB has the tracking on it, the PICs have the code in them, but the necessary parts are not fitted.
#8921 - 06/06/2000 04:57 Re: Backlit Buttons? [Re: rob]
phaigh
You could do the whole case in plastic, and add the airport cable around the inside (like an iBook).
You'd definitely want different colour lights for each button though!
Awesome!
Paul
Paul Haigh, 6GB, Blue
Reg: 4120 - Serial 00254
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#8922 - 06/06/2000 08:08 Re: Backlit Buttons? [Re: tfabris]
schofiel
The tracks have been designed into the boards on the Mk2. It is not a hack; the problem was in obtaining 3.5 mm White LEDs, as only 5mm ones were available at the time of design. You could fit LEDs yourself without effort.
When the guys looked at button illumination, it looked a bit tacky and could not really decide. They did have transparent buttons cast up to try it, but they were only for test.
Note that the tracking is not present in the Mk1 display boards, so you would have to hack this.
Me, I'm just waiting till the guarantee expires before going in with the soldering iron and 3.5 blue LEDs. Now where's my hobby casting kit...
#8923 - 06/06/2000 21:31 Re: Backlit Buttons? [Re: altman]
bmihulka
Loc: Lincoln, NE
Looks like its time to order some parts from digikey. And try my hand at plastic casting. Although I'll have to think about the warranty. Is there any way I can only void the warranty on the display board?
-Waiting to replace the hole in my truck with a Mark2
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#8924 - 07/06/2000 02:57 Re: Backlit Buttons? [Re: bmihulka]
schofiel
An alternative which I think I will try is to get a laser to drill a 0.6mm hole through the centre of the current buttons. You can then feed a standard multimode glass fibre through the hole for efficient light conduction.
This gives a really intense light in the centre of the button, and it looks really cool - I have seen this on a front panel for a telephone exchange, and behind a smoke glass panel it looks great.
#8925 - 07/06/2000 07:11 Re: Backlit Buttons? [Re: schofiel]
ccrobin
Loc: Minnesota, USA
I'll just be happy when I get mine and can listen to music with it. :)
"I drank what?" - Socrates
#8926 - 07/06/2000 07:53 Re: Backlit Buttons? [Re: schofiel]
bmihulka
Loc: Lincoln, NE
I think I may try that out. It just happens that my graduate work is in lasers and I have access to most any type.
It will be at least a month anyway because digikey is backorded on the white leds until about July 7th.
Brian
#8927 - 08/06/2000 00:40 Re: Backlit Buttons? [Re: bmihulka]
jfranke
Thanks for the answers. I might try as well to get mine backlit. What I would like to use for that is a very little pice of fiber from a TOSLINK optical wire, drill a hole and use that to get the 'light-dot' in.
Another question I got, blue and white LED's require roughly 3.6V, other colors maybe 1.8V. Is this regulated via the resistor package Hugo was referring before ?
Wow..these white suckers are expensive!
Thanks! J.
#8928 - 08/06/2000 01:05 Re: Backlit Buttons? [Re: teemcbee]
CHiP
Agreed, i would be willing to pay a few $$ to have the buttons light up. ( if done right).
-CHiP
-CHiP
#8929 - 08/06/2000 09:00 Re: Backlit Buttons? [Re: jfranke]
bmihulka
Loc: Lincoln, NE
Most likely the resistors are the current limiter for the leds. I'm not sure what voltage is supplied, but most likely 5v. So depending on what the voltage drop across the diode is and how much current you want flowing through them you can find the resistor size from Ohm's law.
Hugo, what are you driving the leds with to be able to dim them? Are you using pulse width modulation or an analog output?
Brian
#8930 - 22/12/2000 11:44 Re: Backlit Buttons? [Re: schofiel]
Rob, did you ever get around to doing this?
Last night in the car, my wife tried to skip a Nine Inch Nails track and couldn't find the button.
#8931 - 22/12/2000 14:18 Re: Backlit Buttons? [Re: rob]
flashman
Loc: U.S.
Rob..... in response to "Just for fun, though, we're going to try to persuade the plastics people to run one complete set of parts in transparant plastic. I wonder how much the world's only "i-empeg" will be worth in years to come :-)"
I am very comfortable with performing my own addition of LEDs.
Please Sir..... How does one get on this list for a set of these magical transparent sets of buttons?????
Be happy to pay for them. :)
Consider doing the volume knob as well? ... it would be fairly simple to affix backround lighting for it.
12Gb MKII 080000516 Blue
12Gb MKII 080000516 Blue 20Gb MKII 010101303 Green 20Gb MKII 090001020 Green 30Gb MKII 10101980 Blue
#8932 - 22/12/2000 16:31 Re: Backlit Buttons? [Re: flashman]
There's only only one set, and Toby has them :-)
They don't look too good anyway - the plastic form wasn't designed with backlighting in mind.
#8933 - 23/12/2000 10:34 Re: Backlit Buttons? [Re: flashman]
Rob S. mentioned trying it with a hobbyist casting set. I'm curious if anyone has tried this.
#8934 - 23/12/2000 11:04 Re: Backlit Buttons? [Re: tfabris]
xavyer
Wouldn't translucent be better than transparent?
A translucent set of buttons would diffuse the light, would it not?
Say, for example, a 'murky white' color would allow for any color of LED.
#8935 - 23/12/2000 11:06 Re: Backlit Buttons? [Re: xavyer]
Wouldn't translucent be better than transparent? A translucent set of buttons would diffuse the light, would it not?
I think that everyone here assumed that they meant translucent when they said transparent. I don't think anyone would want completely transparent buttons.
#8936 - 23/12/2000 12:12 Re: Backlit Buttons? [Re: CHiP]
jwickis
Loc: India
You could do the opposite and light the area around the button and not need translucent buttons it would be an outline of the buttons. I think some equipment manufacturers have done this as a retrofit instead of a button change and it would only take one per left hand button and one for volume knob. The lighted buttons would look cooler.
I really like the fiber optic solution.
#695 Mk2 BLUE 12Gig
Ask and I may tell you
#8937 - 01/01/2001 15:07 Re: Backlit Buttons? [Re: jwickis]
Fogduck
Loc: BC
jwickis: thats a good idea...leave the buttons alone, and install something to shine out from behind them, to outline 'em.
That indiglo stuff used in night-lights and Timex watches (etc.) -- I wonder what the properties of that stuff is. I wonder if you can cut it into interesting shapes (say, an outline of the empeg buttons) and still power it...
You could buy two of those inexpensive night-lights that use the material and experiment...in fact, Costco has those on sale, so you could afford to mangle quite a few.
MK2 #141, green, 12GB
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
#8938 - 01/01/2001 15:51 Re: Backlit Buttons? [Re: Fogduck]
They sell that stuff in the Edmund Scientific catalog for just that sort of purpose. You can cut it into shapes, with some limitations. Although I don't see how you could light effectively around the edges of the buttons, there's no gap between the buttons and the plastic bezel.
I'm starting to like the fiber optic idea...
#8939 - 01/01/2001 15:56 Re: Backlit Buttons? [Re: rob]
beaker
Loc: England
Sorry if this sounds daft but what about glo-in-the-dark plastic buttons? I don't know whether the grey pigment in the buttons would prevent them from glowing though.
Just a thought.
beaker
12 gig blue
