#88267 - 15/04/2002 23:59 "clock" time format crashes 2.0b11 player app?
Daria
My wife had been whining that she couldn't tell what time it was in the car, so I set the time format to "clock". I also put the developer image on the unit, so I could try to figure out how to bypass the "can't set the timezone" problem in 2.0b11. Never did find that out, but that's another story. I then went on a 10 hour trip. A few times I noticed my visual went away. Finally, I noticed why. The player app was restarting, but the unit was not rebooting.Attaching a serial cable showed it (the player application) was crashing. I reinstalled the consumer 2.0b11 image. Still crashing. I disabled the "clock" time format, and lo, no crash.
Fluke, or has anyone else seen this?
#88268 - 16/04/2002 09:53 Re: "clock" time format crashes 2.0b11 player app? [Re: Daria]
This is the first I've heard of this happening. Does anyone else run the clock display 100 percent of the time?
Also note: There is no "can't set the time zone" bug in beta 11. What it is, is a "time zone menu always defaults to US-Alaska even when my time zone is set correctly". This is known and will be fixed in the next release, and as far as I know, it's cosmetic-only. This is unrelated to the other issue you were describing.
#88269 - 16/04/2002 10:59 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
jimhogan
Loc: Seattle, WA, U.S.A.
Maybe. Just the other day I remarked to myself "Hey, the Empeg hasn't been spontaneously rebooting lately. What changed?" Well, aside from some Hijack updates, the main change is that I haven't been running clock visuals (I did for a while). I'll switch back to see if it starts rebooting. It also froze several times -- I'd leave it running overnight and find clock showing frozen time display from middle of the night.
Jim
#88270 - 16/04/2002 11:04 Re: "clock" time format crashes 2.0b11 player app? [Re: jimhogan]
Uh oh, the evidence mounts. Wonder if there's a bug in there someplace?
Anyone else?
#88271 - 16/04/2002 11:42 Re: "clock" time format crashes 2.0b11 player app? [Re: jimhogan]
Daria
Well, this isn't the clock visual, but yeah, I guess the code is probably the same.
And yeah, sorry for the poor phrasing of the "time zone selection" point, which yes, I realize is unrelated.
#88272 - 16/04/2002 14:13 Re: "clock" time format crashes 2.0b11 player app? [Re: Daria]
Neutrino
I'm not sure that this is what your asking for. I run the clock all the time. This is to say that I use the track info screen with the clock enabled. I rarely use the visuals. I have not had a problem with this Mk2a rebooting. The first Mk2a I purchased does reboot on occasion using the same format. it is a 30gb while the stable one is a 20bg.
#88273 - 22/08/2002 06:19 Re: "clock" time format crashes 2.0b11 player app? [Re: Daria]
My wife had been whining [...] Fluke, or has anyone else seen this?
Has anyone seen this with beta 13? I've just fixed a specific bug to do with failing to restart the player when synchronising with timemode set to clock, but haven't seen it crash during playback.
#88274 - 29/10/2002 23:26 Re: "clock" time format crashes 2.0b11 player app? [Re: peter]
Loc: Los Angeles, CA
<DELETED> double post </DELETED>
#88275 - 29/10/2002 23:26 Re: "clock" time format crashes 2.0b11 player app? [Re: peter]
i've figured out that this is what was happening to me in this thread.
here's the thing. if i leave it on clock time format, with Line INFO and visual Spectrolog128 (i haven't tried this w/ any other visual, but i will tonight), i get a player segfault in serial output but without the dump.
but if i use transient instead... i've been able to play all night without a crash.
this is in b13 version... i've seen it happen with or without hijack.
#88276 - 30/10/2002 00:59 Re: "clock" time format crashes 2.0b11 player app? [Re: image]
Now bug 1868 in the internal database.
#88277 - 30/10/2002 07:52 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
overnight playing using funnelweb, line, and clock = crash.
interestingly, this time i had preinit loaded, and it showed that it went thru the M##scripts again (not the begining tho. didnt echo "empeg-preinit starting..." after the crash. the first line was the first M##script echoing "emptris v1.3 starting..."
#88278 - 30/10/2002 08:08 Re: "clock" time format crashes 2.0b11 player app? [Re: image]
nice. just happened to me again in AC mode. this time, a dump was echoed, but it didnt start from preinit. it just restarted the player. the only other post that included a code 0 and Unable to handle kernel paging request at virtual address 0000fff4 is here.
player(42): memory violation at pc=0x0207b538, lr=0x02073a94 (bad address=0x0436
8970, code 0)
pc : [<0207b538>] lr : [<02073a94>]
sp : bdfffc08 ip : bdfffc18 fp : bdfffc14
r10: 00000020 r9 : 00000000 r8 : 0214fa30
r7 : 0219cac0 r6 : 00000000 r5 : 02169810 r4 : bdfffc64
r3 : 021b44f0 r2 : 00000000 r1 : 021b4480 r0 : bdfffc64
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0D9D17D Table: C0D9D17D DAC: 00000015
Function entered at [<0207b520>] from [<02073a94>]
Function entered at [<02073a48>] from [<0201a678>]
r4 = 02118BC4
Function entered at [<0201a1d8>] from [<02067804>]
r10 = 0214F884 r9 = BDFFFD0C r8 = BDFFFD20 r7 = 0214FA30
r6 = 02168724 r5 = 00000001 r4 = 02168680
Function entered at [<02067774>] from [<020647c8>]
r7 = BDFFFD1C r6 = 0214F7A8 r5 = 0214FA30 r4 = 0214F7A8
Function entered at [<0206476c>] from [<02064f50>]
r5 = 0214F884 r4 = 0214F7A8
Function entered at [<02064f24>] from [<0206526c>]
r4 = 00000000
Function entered at [<02065030>] from [<02064f88>]
r10 = 020AAF94 r9 = 0214F7A8 r8 = 0000340E r7 = 00000080
r6 = 0000000E r5 = 0214F7A8 r4 = BDFFFD64
Function entered at [<02064f78>] from [<020ab04c>]
Function entered at [<020aaf94>] from [<020b18b0>]
r5 = 0214F7C0 r4 = BDFFFE40
Function entered at [<020b17e8>] from [<020e6c4c>]
r4 = 00000000
Function entered at [<020e53c0>] from [<020b162c>]
r8 = 0215306C r7 = 02153058 r6 = 020AAF94 r5 = 00000007
r4 = 00000000
Function entered at [<020b157c>] from [<020e6c4c>]
r5 = 00000000 r4 = 00000000
Function entered at [<021ad284>] from [<00000003>]
memmap = C0D9C000, pgd = c0d9c000
*pgd = c0f2f801, *pmd = c0f2f801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00f0c78>] lr : [<c00197d0>]
sp : c07adf44 ip : c07adf00 fp : c07adf90
r10: 00000000 r9 : c0f8b160 r8 : 0000000c
r7 : 00000000 r6 : 021ad284 r5 : 00010000 r4 : 00010000
r3 : 0000435b r2 : 001d25bb r1 : 021adc00 r0 : bffffbf8
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 42, stackpage=c07ad000)
Stack:
c07adf20: c00197d0 c00f0c78 600000
13
c07adf40: ffffffff c0f8b178 c0f8aae0 c07ac000 c07adfb8 04368970 c0011a88 02073a
94
c07adf60: 04368970 00000000 c07adfb8 00000005 04368970 00000000 00000000 000000
00
c07adf80: 00000020 c07adfb4 c07adf94 c0011fc0 c0011838 c011297c 02169810 000000
00
c07adfa0: 0219cac0 0214fa30 00000000 c07adfb8 c000a0a8 c0011ee8 bdfffc64 021b44
80
c07adfc0: 00000000 021b44f0 bdfffc64 02169810 00000000 0219cac0 0214fa30 000000
00
c07adfe0: 00000020 bdfffc14 bdfffc18 bdfffc08 02073a94 0207b538 20000010 ffffff
ff
Backtrace:
Function entered at [<c001182c>] from [<c0011fc0>]
r10 = 00000020 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 04368970 r5 = 00000005 r4 = C07ADFB8
Function entered at [<c0011edc>] from [<c000a0a8>]
r8 = 0214FA30 r7 = 0219CAC0 r6 = 00000000 r5 = 02169810
r4 = C011297C
Code: e1140007 1afffff7 (e814000f) e1a05000 e0436008
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Using non-standard cache size 102 (adjustment 32)
Vcb: 0x4066d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 1485
400, error=0xc0044000
#88279 - 30/10/2002 09:09 Re: "clock" time format crashes 2.0b11 player app? [Re: image]
Daria
Some other thread has where I reported the output from the player; I do suspect it's the same, and I should look, for curiousity. This is an issue which still plagues me, and I'm tempted to try to work up something to be LD_PRELOADed for Std::String::Terminate which as I recall was the guilty party.
#88280 - 30/10/2002 16:16 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
mrfixit
I have also noticed somthing like this, when I have the clock on, the display will flick off then on it is very fast maybe half a sec. but it only does this when I have the clock displayed. So far it has not crashed or rebooted but the display will flick maybe every 10 sec. or so. Oh also Im running b13 hijack 289 I know I know hijack is up to 300 now, Im just lazy.
Ben
hijacked
#88281 - 06/11/2002 12:26 Re: "clock" time format crashes 2.0b11 player app? [Re: image]
hoagy
Loc: Silicon Valley
Yup, this has been happening to me and my friend for a long time in b13. I use the scope visualization. Line info mode = crash, Transient = no problem. Twould be great if there were a fix since I like the Line info mode more than Transient most of the time.
-Ryan.
#88282 - 06/11/2002 12:29 Re: "clock" time format crashes 2.0b11 player app? [Re: hoagy]
Can you verify whether the problem is with the "Clock" time format specifically? Or any timecode in Info:Line mode?
#88283 - 06/11/2002 20:59 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
i've only seen it in clock mode. i'll leave it overnight at something else, and see what happens.
#88284 - 07/11/2002 10:50 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
hoagy
Loc: Silicon Valley
I ran it yesterday afternoon using both modes and never got a reboot. Since it's a random thing, it's going to be difficult to say for sure. I'll run the timecode in 'elapsed' mode for a while and report if I ever get a reboot.
-Hoagy.
#88285 - 07/11/2002 15:33 Re: "clock" time format crashes 2.0b11 player app? [Re: hoagy]
Okay, great. Thanks.
#88286 - 13/01/2003 04:16 Re: "clock" time format crashes 2.0b11 player app? [Re: tfabris]
FITNR: the timemode=clock thing, and the clock visual thing, and possibly also the flick-to-black thing. Altogether quite a nasty one.
#88287 - 13/01/2003 14:11 Re: "clock" time format crashes 2.0b11 player app? [Re: peter]
Biscuitsjam
Just so you know, I'm having the same thing happen in 2b13 (consumer and developer). I have line info with clock and visuals. The unit crashes about every 2 hours. It did the same thing with my old one before it was stolen.
It still crashes even if the song is paused.
-Biscuits
