Page 6 of 14 < 1 2 ... 4 5 6 7 8 ... 13 14 >
#87779 - 07/05/2002 03:52 Re: Tuners, empeg, for the use of (update 2) [Re: mail2mm]
Yeah, Australia. Brisbane to be precise
#87780 - 08/05/2002 18:44 Re: Tuners, empeg, for the use of (update 2) [Re: pca]
Anymore updates on the kits, Patrick? You seem to have gone quite lately...
#87781 - 09/05/2002 02:22 Re: Tuners, empeg, for the use of (update 2) [Re: Shonky]
Patrick has been away - I know he's still working on the project (awaiting delivery of sample parts).
#87782 - 09/05/2002 03:01 Re: Tuners, empeg, for the use of (update 2) [Re: rob]
thinfourth2
Okay here is a question.
Given that some of us out here have some flakey soldering is there any chance of a test rig some where with some one to test units before plugging them into our beloved empegs.
Also what would the support issues be with us plugging home made tunners into our empegs
P.S. i'll have two
#87783 - 09/05/2002 03:13 Re: Tuners, empeg, for the use of (update 2) [Re: thinfourth2]
I don't know, I'm not involved in the project. I daresay the instructions will include some post build tests.
If you plug any third party product into your empeg which damages the player, your warranty will not cover the repair!
#87784 - 09/05/2002 12:26 Re: Tuners, empeg, for the use of (update 2) [Re: rob]
matthew_k
So what's the worst that can happen if we put 12V down any of the pins in the tuner harness? No more tuner possibilities? No more empeg? Fuse replacement?
#87785 - 09/05/2002 12:47 Re: Tuners, empeg, for the use of (update 2) [Re: thinfourth2]
lamer
Loc: Texas
What kind of "homemade" tuner were you planning on hooking up to the empeg?
Cory
MK2a 160GB
11 Years later, these Mk2a units still rock...
#87786 - 09/05/2002 12:54 Re: Tuners, empeg, for the use of (update 2) [Re: lamer]
You have actually read this thread that you're posting to, right?
#87787 - 09/05/2002 13:16 Re: Tuners, empeg, for the use of (update 2) [Re: matthew_k]
lamer
Loc: Texas
I assume the bulk of the tuner harness is occupied by a serial interface and line level audio. A serial (rs232) receiveer will typically handle about +/- 20 to 25 V without permanent damage. A serial driver will typically drive about +/- 13V (take care not to damage your "homemade" tuner). Line level audio inputs really should be driven no higher than 2-3V max. Line level audio inputs can be sensitive; driving them to 12V could (and for extended periods of time probably will) cause permenent damage. Driving any 12V ac signal to line level inputs will also sound terribly distorted... Rework with fine pitch surface mount IC's (A/D converters for instance) requires some skill and specialized soldering tools...
Cory
MK2a 160GB
#87788 - 09/05/2002 13:30 Re: Tuners, empeg, for the use of (update 2) [Re: rob]
lamer
Loc: Texas
Yes, I have. I thought he was implying an interim truly home-made tuner. The more I think about it was a strange assumption to make. Take this into consideration when reading this
Cory
MK2a 160GB
#87789 - 09/05/2002 13:50 Re: Tuners, empeg, for the use of (update 2) [Re: rob]
elvis
Loc: Arizona USA
lol! Is there a RTFM thread equivalent? RTFT?
Elvis
#87790 - 09/05/2002 16:08 Re: Tuners, empeg, for the use of (update 2) [Re: lamer]
No, the serial on the tuner is TTL level not full rs232. Put more than 5v down a pin and you're likely to blow the buffer on the main board - and hopefully not blow anything else.
The audio inputs are probably ok to about 3.3v which is the analogue supply to the ADCs in question.
#87791 - 10/05/2002 13:20 Re: Tuners, empeg, for the use of [Re: pca]
philip2002
Put me down for a tuner, guys! Am prepared to pay in advance. Cheers.
#87792 - 12/05/2002 11:08 Re: Tuners, empeg, for the use of [Re: pca]
Guschti
Loc: Zurich, Switzerland
It's getting quiet here... is there any update?
Do you know when we can expect the tuner kits?
#87793 - 13/05/2002 02:10 Re: Tuners, empeg, for the use of [Re: Guschti]
He's still waiting for samples of the tuner module (which goes inside the tuner module).
#87794 - 13/05/2002 04:10 Re: Tuners, empeg, for the use of [Re: rob]
Phew! Deep! Great philosophers have thought for centuries about stuff like that!
#87795 - 13/05/2002 12:01 Re: Tuners, empeg, for the use of [Re: BartDG]
philip2002
Is there a recognised sign-up sheet somewhere for getting these tuners? It would be a shame to come this far and not get one.
#87796 - 13/05/2002 12:05 Re: Tuners, empeg, for the use of [Re: philip2002]
"No, Neo. We're saying that, when they're ready, you won't need to sign up."
#87797 - 13/05/2002 12:11 Re: Tuners, empeg, for the use of [Re: tfabris]
philip2002
I'm getting the Matrix here. Or maybe i'm just very wrong!
#87798 - 13/05/2002 12:19 Re: Tuners, empeg, for the use of [Re: philip2002]
Yeah, I like to do the occasional Matrix reference.
#87799 - 14/05/2002 10:20 Re: Tuners, empeg, for the use of [Re: tfabris]
puckalicious
There is no tuner.
#87800 - 14/05/2002 10:39 Re: Tuners, empeg, for the use of [Re: puckalicious]
Do not try and make a tuner. That's impossible. Instead... only try to realize the truth, Patrick is making them
See... Matrix quotes fit every occasion!
Anyway, back to work...
- Trevor
#87801 - 14/05/2002 11:14 Re: Tuners, empeg, for the use of [Re: tman]
#87802 - 16/05/2002 18:06 Re: Tuners, empeg, for the use of [Re: tfabris]
Satan_X
Loc: Ramsey, NJ
As the french say......Le Bump...
VW R32 Empeg 50gig 'Stormy 3 has snuck in a dodgeball' - Stormy 1
#87803 - 18/05/2002 13:47 Re: Tuners, empeg, for the use of [Re: pca]
nikko
Hmmm....well, I'd certainly be interested. I'm sorry, there are so many posts I might have missed it - do I need to sign up somewhere to reserve a tuner or spot in one of the first batches? Thanks.
#87804 - 18/05/2002 19:32 Re: Tuners, empeg, for the use of [Re: nikko]
Alexander
Loc: SF Bay Area
If the "kit" tuners become reality, you won't need to have signed up anywhere.
If you hope for pre-manufactured tuners, you can sign up at http://www.eden2.com/empeg/ if you want, but the outlook is looking more and more grim as time goes on.
If the kits come out, it sounds like there will be people who will assemble them for you.
Regardless, if you sign up at the above page, I'll fire off an email when (if) tuner kits become available, so you won't accidentally fall out of the loop. Can't hurt.
Alex
#87805 - 19/05/2002 05:36 Re: Tuners, empeg, for the use of [Re: Alexander]
It isn't getting more grim - we stopped researching a new manufacturing run when Patrick announced his project. With a bit of luck Patrick will be at the European owners meet next month, maybe with a prototype!
#87806 - 20/05/2002 02:01 Re: Tuners, empeg, for the use of [Re: rob]
Alexander
Loc: SF Bay Area
But the outlook for pre-manufactured tuners (and hence my little web site, sniff) is more grim as a direct result of Patrick's project, right? Because that's what I was trying to say.
Or is it easier to produce small (~300) batches of populated through-hole boards than SMT? (i.e. have someone sit there with a soldering iron)
Alex
#87807 - 20/05/2002 06:37 Re: Tuners, empeg, for the use of [Re: Alexander]
lopan
Loc: Manassas VA
Um... I think what they mean is that "grim" isn't the word for the pre-manufactured tuners, because it's not going to happen at all.. Nada... Zilch... Zero... Our only chance for a tuner is to buy Patricks kit or Ebay....
Brett 60Gb MK2a with Led's
#87808 - 20/05/2002 10:10 Re: Tuners, empeg, for the use of [Re: rob]
thinfourth2
That is excellent news but
Will he bring his jet engine as well now that would be real good fun.
