#86498 - 10/04/2002 11:28 Stereo phono plug to 2 RCA schematic
I was thinking about hardwiring the aux in connectors on my sled to a phono jack mounted in my car, but I can't seem to find an appropriate schematic anywhere. I realize that the RatShack could probably sell me a cable that will do that without me needing to deal with it, but I'd rather get a mountable jack, and that won't be possible with their cable (of course, it now occurs to me that I could get such a cable and cut it open, but I've already typed this much now).
Can anyone point me to such a schematic? It should be quite simple, I imagine. I just don't know how to go from the separate to a shared ground.
#86499 - 10/04/2002 11:35 Re: Stereo phono plug to 2 RCA schematic [Re: wfaulk]
genixia
In all probability, the 'separate' grounds of the RCA jacks are actually common in the empeg anyway, so joining them (or only using one) should not be problem - but you should probably get pca or altman to confirm this first. If they are not, then you could probably connect them to a common point using a resistor (1k should be fine), and using that common point as a shared ground.
#86500 - 10/04/2002 11:40 Re: Stereo phono plug to 2 RCA schematic [Re: genixia]
Right.
Outer sleeve = RCA grounds (common).
Tip and Ring = Left and right positive.
Don't know which is which for the tip and ring, though. Anyone?
Also, you might want to have a defeatable chassis ground on the sleeve to compensate for different ground loop issues depending on what device is plugged into the jack.
#86501 - 10/04/2002 11:40 Re: Stereo phono plug to 2 RCA schematic [Re: genixia]
So that would be one resistor for each separate ground, or join the separate grounds and put a resistor between that common point and the common?
#86502 - 10/04/2002 11:42 Re: Stereo phono plug to 2 RCA schematic [Re: tfabris]
I can figure out left and right by trial and error if I can't find it elsewhere. (Thanks, though.) But I actually had another project where I wanted to do this where I couldn't join the grounds or I'd get this weird crossover between the channels. And now that I'm doing it again, I might as well figure out what I did wrong the first time.
Edit: Supposedly, tip is left and ring is right. I suppose that works out well with Right == Red == Ring.
Edited by wfaulk (10/04/2002 11:48)
#86503 - 10/04/2002 11:54 Re: Stereo phono plug to 2 RCA schematic [Re: wfaulk]
genixia
The first ---- but Tony has confirmed that you can just join them together and not worry about any resistors.
#86504 - 10/04/2002 11:56 Re: Stereo phono plug to 2 RCA schematic [Re: genixia]
Well, I'm only assuming that they're joined. I don't see why they wouldn't be. But I could be wrong.
#86505 - 10/04/2002 11:58 Re: Stereo phono plug to 2 RCA schematic [Re: genixia]
But it wouldn't be wrong to do it that way just to be safe, right? Especially considering that a pair of resistors costs next to nothing.
