#86332 - 09/04/2002 21:26
ok to cut about 4mm off front of docking sled?
Loc: Houston, TX, USA
If I were to bolt/screw the docking sled to the cage in the dash would there be any reason why I couldn't cut a few mm from the front of the whole sled so the metal lip wouldn't show and so the empeg will mount completely flush against the dash?
Well, I guess the only problem may be the latch that locks/snaps the empeg into the sled itself.
Since I don't have it handy, how far is it from the sled "lip" to the front edge of the anchor slot?
John M
#86333 - 09/04/2002 21:36
Re: ok to cut about 4mm off front of docking sled?
[Re: jnmunsey]
Since the empeg sled is a hard-to-replace item, I would tend to want to protect it in favor of anything else. I'd mod the car before I'd mod the sled. You will be able to get a million replacements for the car parts many years into the future, but a replacement empeg sled is going to be a pretty rare item soon (already is, for the Mk1 sled).
If the player does not sit flush with the dash, I would re-do the bolt holes in the right place rather than try to cut the sled. In fact, it might be a problem because the docking connector needs to be at a certain depth to work properly.
If you do not like seeing the metal lip, I would suggest doing this trick from the FAQ rather than cutting the sled.
#86334 - 10/04/2002 11:09
Loc: Lincoln, NE
I actually cut off the right and left lip when I got my first Mk2, The original empeg only had lips on the top and bottom, so I modified my new sled. So you can do it, but like Tony said, now they are hard to come by so you might not want to.
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#86335 - 11/04/2002 07:19
[Re: bmihulka]
Ok so what happens if something happens to my sled in 3 years(stolen car/broken/worn out and not fixable)?
#86336 - 11/04/2002 07:26
Bolt holes? Yeah I'm kinda pissed the installer used just the tabs... I could have done it myself but I didn't have time.
There are no gaps but rather I can see the metal sled peeking out of the edge of my unit.. The metal tab usage means the sled will move a little, so the plastic racial-rigged(don't wanna offend Jerry) trick might come loose easily..
I may have to tear it up and bolt the sucker... I hope I can remove the sled without disconnecting any wires(via cutting)..
-John M
#86337 - 11/04/2002 12:29
[Re: jnmunsey]
That's actually ``jury-rigged'', not ``Jerry-rigged''. Although I'm sure some people intentionally started saying ``Jerry'' during a World War somewhere. It seems to come from the nautical term ``jury mast'', which was a temporary mast erected when another failed, IIRC. In fact, ``jury'' is now an adjective that means ``temporary and makeshift''.
#86338 - 11/04/2002 13:05
Very interesting. I though Jerry-rigged was the correct one. Thanks for setting us straight.
#86339 - 11/04/2002 14:43
Yeah I knew about jury-rigged, but because of its misuse 'jerry-rigged" was added to the dictionary(most I believe), and thus made my joke possible..
#86340 - 12/04/2002 12:03
Loc: San Jose, CA
I actually never heard of Jerry-rigged. Jury-rigged yes, jerry no. Strange... I wonder if it's because I'm from New York originally? Is the jerry mutation a west coast phenomenon?
Calvin
#86341 - 12/04/2002 14:26
[Re: eternalsun]
Nope. I hear them about equally, and I'm in Raleigh, NC (and was back when it was mostly populated by Southerners).
#86342 - 12/04/2002 19:32
I won't even mention how i heard it growing up in Louisiana from my relatives... hell, how i STILL hear it from my grandpa.
Actually, i heard someone use that term recently and it really caught me by surprise out here on the West coast.
#86343 - 13/04/2002 04:16
[Re: loren]
Loc: Petaluma, CA
i use the term trick-f*cked, over jury-rigged, i guess im just hip like that.
Edited by justinlarsen (13/04/2002 04:16)
Justin Larsen
#86344 - 13/04/2002 11:57
[Re: justinlarsen]
And here in the (relatively) deep South, I still occasionally hear ``n****r engineered''. Or the only slightly less offensive ``Afro-engineered''. Isn't racism lovely? (sarcasm)
#86345 - 13/04/2002 16:14
"Isn't racism lovely? (sarcasm) "
It's really sad that we have to put thsoe disclaimers in there. Even though it was completely obvious to anyone with an inkling of intelligence someone will find offense to it and raise a stink. Possibly someone without an inkling?
-John M
#86346 - 13/04/2002 17:53
[Re: jnmunsey]
Inkling? Inkling!? Your reference to black writing fluid can only be interpreted as a vile, racist slur!
Shame on you!
#86347 - 15/04/2002 12:58
No, no, he's obviously an ageist, since as everybody knows, an inkling is an immature ink.
Patrick.
