#84300 - 30/03/2002 13:07 jEmplode 34 - Autoupdating jEmplode + Updates UI
mschrag
Loc: Richmond, VA
This is a relatively small release, but I just wanted to get this out there so it can be used for a 35 release in a couple days... Basically, you've got autoupdating jEmplode in there (turn it on in the Tools.. Options) and a UI on updates (Hijack and jEmplode) that shows the ChangeLog for the version and lets you optionally upgrade or not.
34 added VersionTracker UI that shows changes before updating
34 JEmplodeVersionTracker
34 added jEmplode auto update options to Tools...Options
#84301 - 30/03/2002 14:37 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
Cool features! Haven't seen them work yet, because I'm up to date on both of them.
One note. There is but one menu item which requests manual updates, and it seems to try to update both Jemplode and Hijack (good), but the name of the menu item is still "Update Hijack" (bad).
#84302 - 30/03/2002 14:42 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: tfabris]
mschrag
Loc: Richmond, VA
Oops .. you're right.
#84303 - 31/03/2002 02:50 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
Nosferatu
Loc: France, Champagne
Yeah that rocks !!!
I 'll have one request for the update (JEmplode and Hijack).
Could we have a folder to fill in the options , this folders to save the kernels and Jemplode Archives.
Actually, I am doing that, cos I want to keep all kernels versions and Jemplode also.
That would be nice ....
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#84304 - 31/03/2002 06:05 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: Nosferatu]
mschrag
Loc: Richmond, VA
Yep .. Can do ...
#84305 - 01/04/2002 10:04 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
Nosferatu
Wow Thanks !!!!
#84306 - 02/04/2002 08:08 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
Mike,
I'm trying to figure out how Tony's player sometimes skips the (custom) animation on start-up. The one thing I can think of is "alignment" in memory.
Is it at all possible in any way for JEmplode to use non-4byte alignment for either the start of the offset table, and/or for any entries within the offset table?
Hijack v253 now disallows animations whose offset table is not 4byte aligned, but it doesn't bother looking at the table entries themselves.
#84307 - 02/04/2002 08:24 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mlord]
mschrag
Loc: Richmond, VA
If it does, it's a bug ... I can't really think of how it would happen.... Do you have a particular animation that consistently fails, or just randomly?
#84308 - 02/04/2002 08:43 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
I've asked Tony to see if he can send me his flash image.. he has had animations fail to play a few times now (still rare, though), and I've looking at everything to try and figure how the heck that could possibly happen.
#84309 - 02/04/2002 08:47 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mlord]
mschrag
Loc: Richmond, VA
I'll take a more thorough look at the code tonight too ...
#84310 - 02/04/2002 12:20 Re: jEmplode 34 - Autoupdating jEmplode + Updates UI [Re: mschrag]
I just looked through a flash dump tfabris sent me, and all of the offsets look just peachy fine. So that's not it.
