#80744 - 14/03/2002 13:52 Editing Config.ini
GeoffT
Loc: Coventry, UK
I have recently bought a Riocar player and have just upgraded the Software to 2.00-beta 11 and the latest version of Hijack. I have bought a Kenwood steering wheel remote to operate it in the car. I now want to customise the remote commands by editting the config.ini.
I have read the instructions and added the line in the Windows registry as stated, but the edit config.ini option does not appear under "Tools" in Emplode. I even downloaded and ran a macro which automatically edits the registry just to be certain, but the "edit config" option still does not appear in Emplode.
I'm running Windows98.
Any suggestions ?
VW Golf MKIV GT-TDI 130 MK2a 10GB blue
#80745 - 14/03/2002 13:54 Re: Editing Config.ini [Re: GeoffT]
Terminator
Loc: Dallas, TX
it may be that the registry hack only works for windows 2000?
Sean
#80746 - 14/03/2002 13:56 Re: Editing Config.ini [Re: GeoffT]
The only ways I could see this happening is if:
- You are running the wrong version of Emplode. Check it in Help/About. Must be 2.0 something.
- The entry did not get into the registry correctly. Triple check that. Run Regedit and fish for it
- You did not exit emplode before making the edit to the registry. First, exit emplode, then make the registry change, then run emplode.
#80747 - 14/03/2002 13:59 Re: Editing Config.ini [Re: Terminator]
No, assuming the correct registry entry was edited, then it should work for any 32-bit version of windows.
#80748 - 14/03/2002 14:01 Re: Editing Config.ini [Re: tfabris]
GeoffT
Loc: Coventry, UK
Emplode is 2.0 beta11
I quit Emplode before editing the registry and later re-started the computer completely. The correct registry entry is still there when I look in regedit now, but still no edit config option.
#80749 - 14/03/2002 14:05 Re: Editing Config.ini [Re: GeoffT]
When you restarted the computer, did you log in as a different user? The option is under the CURRENT_USER key, so if you switch users, you have to re-add the option for that user.
Are you 100 percent certain it's the right setting for the right key? For instance, are you sure it's under 2.0/settings instead of emplode/settings? Are you sure it's all spelled correctly? Is it a DWORD? Does it have a value of 1?
#80750 - 14/03/2002 14:15 Re: Editing Config.ini [Re: tfabris]
GeoffT
Loc: Coventry, UK
No I am the only user on this machine.
Yes to all , I even used the macro from the downloads page to automatically make the change and it just put a duplicate entry underneath the one I had added manually. (I deleted my original one in case the duplicate entry would cause problems)
I've just had a thought - I only downloaded the consumer version of the software not the developer version as I didn't think editting the config would count as developing the software - is this the problem ?
#80751 - 14/03/2002 14:33 Re: Editing Config.ini [Re: GeoffT]
There's the problem.
The original edit wasn't correct. If it had been correct in the first place, running the .reg file would have not made any visible change in the registry.
#80752 - 14/03/2002 14:42 Re: Editing Config.ini [Re: tfabris]
GeoffT
Loc: Coventry, UK
OK - just to be absolutely sure, I've cleared my registry hack and then re-run the .reg macro which has added the entry back in, but there is still no "edit config" option in the Tools menu of Emplode.
#80753 - 14/03/2002 14:57 Re: Editing Config.ini [Re: GeoffT]
GeoffT
Loc: Coventry, UK
Eureka,
I've just un-installed Emplode, deleted the registry entry for it completely, re-installed Emplode, re-run the registry editor macro and I've now got edit config.ini !!
Thanks for the the help
Geoff
#80754 - 14/03/2002 15:02 Re: Editing Config.ini [Re: GeoffT]
That's strange. It doesn't make any sense. I don't know why a re-install of emplode would have been needed.
#80755 - 14/03/2002 15:04 Re: Editing Config.ini [Re: GeoffT]
sancho
download a copy of jemplode from http://www.jempeg.org
sancho
band-aid
#80756 - 14/03/2002 15:06 Re: Editing Config.ini [Re: sancho]
sancho
you boys running "forum sniper"?
sancho
slow
#80757 - 14/03/2002 18:34 Re: Editing Config.ini [Re: sancho]
It's FAQ-Sniper...
#80758 - 15/03/2002 08:58 Re: Editing Config.ini [Re: hybrid8]
sancho
there's a "FAQ-Sniper", too?
sancho
behind the times
