Page 2 of 2 < 1 2
#80162 - 13/03/2002 12:42 Re: HiJack and "Play" link on the web playlist [Re: mlord]
Allistah
That must be it. I'm using beta7. I tried beta11, but I had problems with it. It wouldn't stay on the Track info screen from what I remember.
#80163 - 13/03/2002 12:52 Re: HiJack and "Play" link on the web playlist [Re: Allistah]
Okay, people, please don't report bugs unless you're using the latest software, K?
Or things like this will tend to happen.
#80164 - 13/03/2002 14:41 Re: HiJack and "Play" link on the web playlist [Re: tfabris]
Or at least mention that you're using older software if you must report the bug.
The power of the FAQ Master compels you.
#80165 - 13/03/2002 20:27 Re: HiJack and "Play" link on the web playlist [Re: Allistah]
The bug in beta11 where it comes up in Info:Transient instead of Info:Track is easy to get around. You have a couple of options.
You can put an initial= line into the IR Translate section in your config.ini to inject one press of the info button, OR you can use Mark's temporary Hijack menu item that works around this problem by doing its own restore of visual mode for AC operation.
So... Try b11.
Page 2 of 2 < 1 2
