#80132 - 13/03/2002 10:57
HiJack and "Play" link on the web playlist
I just updated to the latest version of the HiJack tool and when I click the "Play" link next to things, I would expect that it would start playing that on the player itself. Am I wrong in thinking this? I thought this because theres a Stream button now for those of us that would rather stream the data vs play it on the player.
#80133 - 13/03/2002 11:00
Re: HiJack and "Play" link on the web playlist
[Re: Allistah]
Yeah, did you try clicking on the link? Did it not do what you expected it to do?
#80134 - 13/03/2002 11:09
Yeah when I clicked the link it didn't do anything. The player just sat there at the end of a playlist. :-/
#80135 - 13/03/2002 11:18
[Re: Allistah]
Strange. Worked fine for me when I tried it. Mess with it some more and see if there's something else wrong. Do the other links work?
#80136 - 13/03/2002 11:22
All the other links work fine. I can navigate the playlist fine, and stream just fine. Just Play doesnt work.
#80137 - 13/03/2002 11:24
[Re: Allistah]
Have you tried pressing the Play link when the player is already playing something else? What happens?
#80138 - 13/03/2002 11:40
I tried to click Play when the player was already playing something and it didn't do anything either.
#80139 - 13/03/2002 11:42
[Re: Allistah]
Very odd. Don't see why this wouldn't work, it works fine on mine and no one else has reported this. Have you tried playing several different songs/playlists to see if it's an issue with that particular one?
#80140 - 13/03/2002 11:45
Yes Sir. Moved all around my playlists and tried all kinds of Play links.
#80141 - 13/03/2002 11:47
[Re: Allistah]
Question:
Do you have hijack serial commands disabled through your config.ini? If possible, post your config.ini so that we can rule out configuration issues. Thanks!
#80142 - 13/03/2002 11:48
[Re: pgrzelak]
Good call. Hijack uses the serial interface to send commands to the player. It must be related to that.
#80143 - 13/03/2002 11:50
[Re: pgrzelak]
Here is the config.ini. I replaced some of the data like my name and phone number and stuff but other than that, this is it.
[hijack]
kftpd_password=password
khttpd_files=0
;@WORK disable_emplode=1
[synchronise]
seq_num=51
[Options]
Name=Name Here
[User Info]
Email=email@domain.com
Phone=111-111-1111
Name=Name Here
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[controls]
stalk_side=none
[hush]
hushpercent=10
[display]
visual_names=1
caching=0
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[tuner]
region=us
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
#80144 - 13/03/2002 11:51
[Re: Allistah]
See if it works when you remove khttpd_files=0 from the list.
#80145 - 13/03/2002 11:51
[Re: Allistah]
Well, I dont think I have the serial interface disabled because I just uploaded the latest HiJack this morning using the serial port. Unless thats not what you guys are talking about.
#80146 - 13/03/2002 11:52
Actually, that one was experience... I was listening to the player at work and someone (through the hijack playlist interface) changed the song. A bit of a surprise, but I knew what happened - I was running snoop on my Sun box watching for inbound connections to the empeg. I shut the command options off for that reason...
#80147 - 13/03/2002 11:55
I changed it to khttpd_files=1 and it still doesnt work. Then I removed the line totally and it still didn't work. Any other ideas?
#80148 - 13/03/2002 11:55
[Re: Allistah]
No, the config looks fine. Do you have anything else running on the serial port? An open hyperterm connection?
#80149 - 13/03/2002 11:57
[Re: pgrzelak]
Or some other installed software that wants the serial port, something internal to the empeg?
Also try removing everything under the [hijack] section in config.ini and see if it works.
#80150 - 13/03/2002 11:58
[Re: pgrzelak]
Nope. I even unplugged the serial cable and rebooted it just to be sure.
#80151 - 13/03/2002 12:00
Another thought, do ANY of the commands work? Can you feed in, say, a reboot command from the http interface?
#80152 - 13/03/2002 12:00
[Re: Allistah]
Well, I'm out of ideas. Mark?
#80153 - 13/03/2002 12:02
[Re: pgrzelak]
I'll try and remove everything under the HiJack menu now. In he meantime, how to I send a reboot command via the http prompt?
#80154 - 13/03/2002 12:03
[Re: Allistah]
looking...
#80155 - 13/03/2002 12:04
[Re: Allistah]
Ok, I removed everything under the [hijack] title and still nothing.
#80156 - 13/03/2002 12:11
[Re: pgrzelak]
#80157 - 13/03/2002 12:12
[Re: pgrzelak]
Yes, reboot via http works fine.
#80158 - 13/03/2002 12:15
[Re: Allistah]
Hm! That implies that the structure (hijack and serial) is working, but that the playlist specific commands are not. Can you try just playing the root playlist? Also, can you try a slightly older revision of hijack. Maybe a bug was introduced in the latest changes.
#80159 - 13/03/2002 12:22
[Re: pgrzelak]
Question:
Do you have any style sheets, html or other data, or are you just using the generated playlist display? Can you put a sniffer (snoop, etc.) in place to watch the command as it hits the empeg? If not, I don't know if this one will work, but try enabling http logging and have an open hyperterminal session to watch the command if it is correctly formed. You might also want to hover over the link, verifying that it is in the correct format...
What browser are you using? What does the link look like? i.e., http://empeg/?FID=blah&SERIAL=blah&EXT=.htm ...
#80160 - 13/03/2002 12:31
Well, the serial "play FID" command does not work in beta7, and possibly not in earlier betas either. So if the person is using anything other than beta11, all bets are off.
#80161 - 13/03/2002 12:32
The relevant option is "khttpd_commands=1", which happens to be the default setting.
