#79905 - 12/03/2002 11:28 visual help
xxxpcpxxx
is there a way to set up the player in the car so that the same visual shows for each song unless manually changed?
#79906 - 12/03/2002 11:36 Re: visual help [Re: xxxpcpxxx]
Yes, that is the default behavior. If it's changing the visuals with each song, it's because you've activated the "auto change visuals" feature. Turn that feature off and you will be back to just one visual.
Unless you're referring to this single most frequently asked question...
#79907 - 12/03/2002 11:43 Re: visual help [Re: tfabris]
xxxpcpxxx
i looked around in the menus before but didn't find anything that refers to turning of the autochange feature. maybe i missed something. tony, if you know off the top of your head where this option lies maybe you can help out.
#79908 - 12/03/2002 12:09 Re: visual help [Re: xxxpcpxxx]
On the rio remote control, press the MENU button.
Scroll to the right to VISUALS and press MENU.
Scroll to the left to AUTO CHANGE and press MENU.
Scroll to OFF and press MENU.
#79909 - 12/03/2002 12:45 Re: visual help [Re: tfabris]
justinlarsen
Loc: Petaluma, CA
thats odd that it got turned on be defualt, but go where tony directed you that will solve it im assuming ur running v2-b11, at least i hope so if your player is doing that
---- Justin Larsen
#79910 - 12/03/2002 13:18 Re: visual help [Re: tfabris]
xxxpcpxxx
thanks a lot. yes i am running 2b11
#79911 - 12/03/2002 13:39 Re: visual help [Re: tfabris]
Of course Beta11 has a bug whereby autovisuals switches itself on whether you like it or not. It doesn't seem to affect everyone.
