#79662 - 11/03/2002 19:03 Inverted headlight sense logic.
theory
Loc: Victoria, BC, Canada
What exactly does this do?
#79663 - 11/03/2002 19:25 Re: Inverted headlight sense logic. [Re: theory]
If you have installed the "button LED hack" to light up the controls on your player, the "headlight sense logic" automatically dims the LEDs when your automobile headlights are turned on (presumably because it is dark outside). The "inverted" just refers to fixing a bug whereby the original implementation was backwards.. dimming for daytime, full brightness for darkness. Doh!
#79664 - 11/03/2002 19:55 Re: Inverted headlight sense logic. [Re: mlord]
theory
how does it know if the headlights are on?
#79665 - 11/03/2002 20:07 Re: Inverted headlight sense logic. [Re: theory]
peterk
Loc: California (Ex NZ)
It can't tell when the headlights are on, per se, but it can tell when its dark outside. It just assumes that if its dark out, the headlights are on........
Peterk
#79666 - 11/03/2002 20:09 Re: Inverted headlight sense logic. [Re: peterk]
theory
I'm assuming it uses the time stored onboard?
#79667 - 11/03/2002 20:28 Re: Inverted headlight sense logic. [Re: theory]
peterk
No, IIRC it modulates the input from the IR sensor. Its not terribly accurate, for example there is a reference in the FAQ saying not to enable this feature if you have tinted windows. Some guy posted bugs@empeg that every time he lit a cigarette, the display on his empeg got brighter. Turned out to be the same problem.
PeterK
#79668 - 11/03/2002 21:26 Re: Inverted headlight sense logic. [Re: peterk]
theory
whoa, high tech!
#79669 - 11/03/2002 22:02 Re: Inverted headlight sense logic. [Re: peterk]
That's nothing compared to the hygrometer sensor we enabled last week.
#79670 - 11/03/2002 23:54 Re: Inverted headlight sense logic. [Re: hybrid8]
theory
I won't even ask what that is
I'm just a lowly web developer
-B
#79671 - 11/03/2002 23:57 Re: Inverted headlight sense logic. [Re: hybrid8]
loren
meanies! LOL.
|| loren ||
#79672 - 12/03/2002 04:05 Re: Inverted headlight sense logic. [Re: theory]
Nosferatu
Loc: France, Champagne
In the wires of your Car Sled , there is a wire connected to the light sense.
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#79673 - 12/03/2002 11:26 Re: Inverted headlight sense logic. [Re: peterk]
Just in case a newbie comes along to read this thread in the distant future, I would like to point out that we're joking about the IR sensor and the Hygrometer.
#79674 - 12/03/2002 13:05 Re: Inverted headlight sense logic. [Re: tfabris]
peterk
I'm glad you pointed that out Tony. I was about to email Mark and tell him that hygrometer_enable=1 in config.ini was causing a HiJack error.
peterk
#79675 - 12/03/2002 13:10 Re: Inverted headlight sense logic. [Re: theory]
peterk
Hi Theory
Yeah as Tony pointed out, we were taking the pi*s. (er thats a kiwi/english phrase - If you're american "we was just foolin with ya").
On a serious note, some of the best new stuff to come out recently on the client side for the empeg has been the html/xml interface.
Theres nothing lowly about web developers, in fact we need more of them.
PK
#79676 - 12/03/2002 14:48 Re: Inverted headlight sense logic. [Re: hybrid8]
Hey!! Shhhssh! I've still got a patent pending on that. Keep it quiet until it gets approved! Nobody else has ever used an IRDA tranceiver to detect moisture reflections of its own transmissions to measure humidity levels, and I want all of the royalties!
