#78283 - 07/03/2002 08:59 Disabling rotary control, but only for volume +/-
Bagpuss
Hi All,
I've just installed my Empeg in my new car, and am using a second head unit to provide amplification.
Once I've set the volume level on the Empeg, I'd really like to be able to disable the rotary for volume +/-, but leave it enabled for all other uses.
I think it may be possible to do this with Hijack, but I'm wondering if anyone has tried this, or might know how to do it.
I think that the following would work, but I'm guessing that it will disable the knob completely, which is not what I would like:
[ir_translate]
knobleft.n=null
knobright.n=null
Does anyone else have any suggestions?
Thanks,
Andy.
#78284 - 07/03/2002 09:21 Re: Disabling rotary control, but only for volume +/- [Re: Bagpuss]
There's a thread just a little further down in this exact forum, entitled Re-programming volume controls! which seems to be discussing a similar issue..
#78285 - 07/03/2002 10:28 Re: Disabling rotary control, but only for volume +/- [Re: mlord]
Bagpuss
I only spotted that thread, after I'd posted my new one.
Thanks for pointing it out, Mark.
Andy.
#78286 - 07/03/2002 11:42 Re: Disabling rotary control, but only for volume +/- [Re: Bagpuss]
You don't need to do any IR translation to lock the volume in place.
There is a feature in the default version 2.0 software which allows you to lock the volume at a fixed point. This setting is remembered independently for home and car personalities, too. Quite useful.
Check out the menus, it's in there somewhere.
#78287 - 07/03/2002 13:10 Re: Disabling rotary control, but only for volume +/- [Re: tfabris]
Bagpuss
You are a star, Tony.
The option is under 'Settings -> Volume'.
That's just what is needed.
Andy.
