#77982 - 05/03/2002 21:15 Instant Playlists
visuvius
I think it would be incrediby handy to be able to make playlists outside of emplode. It would be nice to just pick songs as you go and add them to a playlist, then be able to name it and save. Sometimes you get really good song combinations and want to keep them.
#77983 - 05/03/2002 23:46 Re: Instant Playlists [Re: visuvius]
You can create lists of songs on-the-fly using the insert and append features on the player, then you can save the current running order as a bookmark.
#77984 - 06/03/2002 07:13 Re: Instant Playlists [Re: tfabris]
elinenbe
Loc: New York, NY
Where is there more information on this? I was hoping for a queue type function where you could choose one song at a time and it just keeps adding it to the end of the queue. The player will play until the end of the queue is reached.
-eric
#77985 - 06/03/2002 11:20 Re: Instant Playlists [Re: elinenbe]
mtempsch
If you when you do a search for for instance Titel press the Select Mode button on the remote, the mode will cycle between Insert, Append and Replace.
Insert: Inserts search result after current song, or if you already have something Inserted, just after the last item you previously Inserted
Append: adds search result to the end of the current playlist. It does not add itself to the playlist as generated by emplode but only to the current running order.
Replace: drop current playlist and use search result for new playlist
Read more here
#77986 - 06/03/2002 11:29 Re: Instant Playlists [Re: elinenbe]
The information is the FAQ, right here and here. Enjoy.
#77987 - 06/03/2002 16:52 empeg FAQ [Re: tfabris]
Diznario
Loc: Portland OR
Hey Tony,
Speaking of the FAQ, how come there isn't a link to it under "Quick Links" at the top of the BBS?
I see links to the BBS FAQ, and RioCar.Org, but no link to the Holy Grail of info, the one and only, empeg FAQ.
Whasssupwitdat?!?
Dario
MK2 in an Impreza 2.5RS
#77988 - 06/03/2002 16:58 Re: empeg FAQ [Re: Diznario]
Done. Also removed the link to the Geek site as it's been supplanted by the RioCar.org site.
#77989 - 06/03/2002 17:00 Re: empeg FAQ [Re: tfabris]
Diznario
Loc: Portland OR
Quick on the draw as always!
Another job well done.
Dario
