#77885 - 05/03/2002 12:22 DRAM and Tuner Module questions.
lamer
Loc: Texas
1. If the FPM DRAM chip is replaced with a 64Mb, will the Firmware automatically utilize the additional space? Is the device x8 or x16?
2. Are the tuner modules (within the AM/FM tuner modules) 16 pin or 22 pin?
3. Is there a way to rid/change the MK2a of the RIO logo at boot time?
MK2a 160GB
11 Years later, these Mk2a units still rock...
#77886 - 05/03/2002 12:25 Re: DRAM and Tuner Module questions. [Re: lamer]
Questions 1 and 3 are answered in the FAQ at www.riocar.org , so please give that a read.
Question 2 is moot, because there's no way you could build your own tuner module. This probably should be a FAQ entry, too.
#77887 - 05/03/2002 13:01 Re: DRAM and Tuner Module questions. [Re: tfabris]
jane
Loc: Copenhagen SW, Denmark
It is possible to make your own tuner... it is not really "difficult", but it would take a lot of time and be rather expensve and probably require several attempts.
Marius (Escort Cab + Mark II)
#77888 - 05/03/2002 13:27 Re: DRAM and Tuner Module questions. [Re: jane]
Sounds like a fairly good description of "difficult" to me...
#77889 - 05/03/2002 13:33 Re: DRAM and Tuner Module questions. [Re: andy]
eternalsun
Loc: San Jose, CA
Tony didn't say difficult, he said there was "no way."
Calvin
#77890 - 05/03/2002 13:35 Re: DRAM and Tuner Module questions. [Re: andy]
jane
Hehe. It is quite a long way away from "There is no way".
The input to to the tuner is a standard multiplexed stream. "Any" radio chip desgned for a RDS radio would do, and you would need something to control it, probably a PIC, talking RS-232 to the empeg and I2C or something to the radio chip, and then a handfull of "glue logic" and some consideration to RF and Audio parts (noise for instance).
Hugo had a short comment somewhere.
The easiest way... is to get a radio with line-out which is controllable through the serial port (or an external panel) and plug it to the AUX-in.
#77891 - 05/03/2002 14:12 Re: DRAM and Tuner Module questions. [Re: tfabris]
lamer
Loc: Texas
I found the 16Mb FPM DRAM in the spec, but I cannot find information on the device data bus width or attempting to upgrade it to 64Mb. Maybe I need my vision checked?
MK2a 160GB
#77892 - 05/03/2002 14:37 Re: DRAM and Tuner Module questions. [Re: lamer]
64MB FPM chips have more pins than 16MB fpm chips. Not an easy upgrade, and will generally require bootrom changes too.
Also, as has been pointed out, the player software won't recognise the extra memory.
#77893 - 08/03/2002 22:00 Re: DRAM and Tuner Module questions. [Re: altman]
ashmoore
Loc: TX
obviously, the gap between "no way" and "difficult" is a little fuzzy.
Would several attempts at a design for a tuner, that may or may not blow up your now irreplaceable empeg be classed as "difficult" or "no way" or how about "not with my empeg you don't sunshine"?
That could be the empeg equivelant of a NIMBY (Not In My Back Yard) !?
Thought I should ask......
========================== the chewtoy for the dog of Life
