#74384 - 23/02/2002 19:52 HTTP help now
acurasquirrel
Loc: Georgia
Alright I had this working the other night. Now when I try to connect to my empeg via http it cant find the page. In the config.ini file all the network settings are 0.0.0.0 Im thinking this may be the issue but if anyone could lemme know that would be great
#74385 - 24/02/2002 00:03 Re: HTTP help now [Re: acurasquirrel]
mtempsch
Well, did you previously set up an IP-adress, mask etc through emplode? Or tell it to use DHCP?
Or did you use the uPnP stuff?
#74386 - 26/02/2002 15:22 Re: HTTP help now [Re: mtempsch]
acurasquirrel
Loc: Georgia
Im not sure what I did I just plugged it in. I can see the empeg via emplode but I cannot FTP or HTTP to it.
#74387 - 26/02/2002 21:44 Re: HTTP help now [Re: acurasquirrel]
acurasquirrel
Loc: Georgia
Cmon now
#74388 - 26/02/2002 22:29 Re: HTTP help now [Re: acurasquirrel]
peterk
Loc: California (Ex NZ)
Questions:
When you connect via emplode, does it use tcp/ip, usb or serial.
On the player, select the "About" option. It will scroll through and tell you the IP address its using. THIS should not be 0.0.0.0 etc.
In my environment, config.ini shows ip addresses.
PeterK
#74389 - 26/02/2002 23:01 Re: HTTP help now [Re: peterk]
acurasquirrel
Loc: Georgia
Well I can get it too connect using all methods and when it connects via TCP i get a ip of 192.168.0.175 but i still cannot see it via HTTP or FTP
#74390 - 27/02/2002 00:12 Re: HTTP help now [Re: acurasquirrel]
mtempsch
Just checking off the basics lists: You have installed a Hijack kernel? And not applied an .upgrade file (for instance 2.0b11) afterwards, without reapplying Hijack?
#74391 - 27/02/2002 01:12 Re: HTTP help now [Re: mtempsch]
acurasquirrel
Loc: Georgia
Yes I have a post Beta11 applied Hijack. Are there any setting I should check?
#74392 - 27/02/2002 08:30 Re: HTTP help now [Re: acurasquirrel]
Back to basics, folks.
Hook up a serial cable, and watch for error messages over the serial link.
Also look for the startup messages from khttpd and kftpd. If you don't see them, they ain't running..
#74393 - 27/02/2002 18:18 Re: HTTP help now [Re: mlord]
acurasquirrel
Loc: Georgia
I ran hyperterminal and I didnt see anything about khttpd or kftpd but it wasnt hooked up to the network at the time so that may have been an issue
#74394 - 27/02/2002 19:49 Re: HTTP help now [Re: acurasquirrel]
peterk
It looks as though you are using DHCP.
If that is the case, then starting up without being on the network won't give you an IP address. This may/may not prevent the http/ftp from even bothering to start.
You should try troubleshooting this in the environment you will be using it. ie on a network.
I will be around for the next couple hours. If you want, email me offline at peter.kerr@zeacom.com
It shouldn't be too hard to sort out (famous last words )
PK
#74395 - 27/02/2002 20:19 Re: HTTP help now [Re: peterk]
acurasquirrel
Loc: Georgia
Alright I hooked it up the the network ran hyperterminal and still no khttpd of kftpd. GRrrrrrrrrrrrrrrrrrrrrrrrrr
#74396 - 27/02/2002 20:37 Re: HTTP help now [Re: acurasquirrel]
1. install Hijack (again!).
2. Run off AC power, not DC.
3. Ensure the Hijack menu pops up.
4. Go into the Hijack menu and ensure the "Force Power Mode" is set to "Normal".
5. go pull some more hair out.
#74397 - 27/02/2002 21:03 Re: HTTP help now [Re: mlord]
acurasquirrel
Loc: Georgia
Im doing that as we speak dont worry I have no possible way to run it of DC my car is most likely totalled but I think I had the empeg in DC mode. SO thats it im sure. THanks
#74398 - 27/02/2002 21:07 Re: HTTP help now [Re: mlord]
acurasquirrel
Loc: Georgia
Now I get a
You are not authorized to view this page message so it works but it wont let me see it.....stupid empeg
#74399 - 27/02/2002 21:36 Re: HTTP help now [Re: acurasquirrel]
acurasquirrel
Loc: Georgia
Well after a few email from PeterK everything is up and running finally.
#74400 - 27/02/2002 22:37 Re: HTTP help now [Re: acurasquirrel]
Well, so what was it?
Doesn't do any good to post the problem here, but not post the solution when you find it. That's not fair.
#74401 - 27/02/2002 22:42 Re: HTTP help now [Re: tfabris]
acurasquirrel
Loc: Georgia
Oh well first off I had the empeg set to Car mode in Hijack, and my bookmark for the http was old and apparently it was changed.
#74402 - 27/02/2002 23:09 Re: HTTP help now [Re: acurasquirrel]
Right, you gotta pay attention to the Hijack release notes. He did change the URLs.
#74403 - 28/02/2002 00:30 Re: HTTP help now [Re: tfabris]
peterk
Yeah, that one caught me for a while too. I went from ~190 something to 217
Who reads release notes?
PK
