#73654 - 21/02/2002 07:18 Shuufle on Long Right
dda
Loc: Belgium
Gurus,
I'm trying to program a Shuffle when doing a long press on the Right Button.
My config.ini file contains :
[ir_translate]
Right.L=Shuffle
But nothing happens !
Where is the mistake ?
My Bottom.L=PopUp0 works fine.
DDA
#73655 - 21/02/2002 11:34 Re: Shuufle on Long Right [Re: dda]
Is "Shuffle" a command which Hijack recognizes as something it can do?
Maybe you need to tell it to be a press of the 0 button on the Rio remote or something.
#73656 - 21/02/2002 11:43 Re: Shuufle on Long Right [Re: tfabris]
loren
Yeah, that command should work.
Try
[ir_translate]
000002.LM=Shuffle ; if in the Mp3 player, a long press of the right button = shuffle
failing that....
[ir_translate]
000002.LM=20DF0D ; if in the Mp3 player, a long press of the right button = 0 on rio remote
oh, and make sure you don't have any other translations for the right button before the Long one.
|| loren ||
#73657 - 21/02/2002 19:36 Re: Shuufle on Long Right [Re: dda]
You're probably hanging on to the button too long.
Counter that with this, and fix the menu use of Right as well:
[ir_translate]
right.L=shuffle.N,right.UL,null
#73658 - 22/02/2002 08:37 Re: Shuufle on Long Right [Re: mlord]
dda
Loc: Belgium
Thanks Mark
This works fine.
DDA
