#70641 - 12/02/2002 22:42 Empeg won't boot
ninti
Loc: Los Angeles
I was trying to change kernals tonight when it errored during the upgrade (I don't remember the error). I then tried it again and it is now completely hosed. It looks bad. When I look at it through Hyperterminal I get this:
e000 v1.04
Copying kernel...
Calling linux kernel...
If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
It then repeats the above text over and over again. I don't know much about Linux admin stuff, but my guess is that the Kernal is trashed. Anything I can do or is sending it in the only option at this point? Lucky I have other Empegs now.
Edited by ninti (12/02/2002 22:43)
#70642 - 12/02/2002 22:46 Re: Empeg won't boot [Re: ninti]
All you gotta do is reapply an .upgrade file (consumer or developer) available at the Empeg downloads section. It'll fix your kernel, re-do your partitions, etc.
It's truly idiot-proof. I hosed my kernel one night and thought the world was going to end. It didn't.
#70643 - 12/02/2002 23:09 Re: Empeg won't boot [Re: tonyc]
ninti
Loc: Los Angeles
I can't, it doesn't apparently get far enough into the boot sequence for the upgrader to do anything, and the program just stops. I can hear the hard drives when the upgrader is trying to find it, it just reboots over and over again every 1.1 seconds just like it does in Hyperterminal.
Edited by ninti (12/02/2002 23:11)
#70644 - 12/02/2002 23:34 Re: Empeg won't boot [Re: ninti]
The reflasher is in a protected area, so it should always be possible to get to it. You can see it - the bit that says "let fly the penguins of linux".
Are you sure your machine trying to apply the upgrade is ok? You can't run hyperterminal and the upgrader at the same time. Also check for other programs using the com port, eg palm sync.
#70645 - 12/02/2002 23:41 Re: Empeg won't boot [Re: altman]
ninti
Loc: Los Angeles
Yeah, I am upgrading another one of my Empegs right now and it is working fine.
I figured. The upgrader is all by itself.
The Empeg is the sole user of any com ports on this computer. Don't even have a modem.
Thanks for the help.
#70646 - 13/02/2002 11:25 Re: Empeg won't boot [Re: ninti]
1) Remove power from the player.
2) Run the upgrade software.
3) When the upgrade says to apply power to the player, do so.
It should work then.
#70647 - 13/02/2002 11:48 Re: Empeg won't boot [Re: ninti]
Maybe you've got a bad HD cable, so the update util isn't able to access the disks. Are your HD's spinning?
#70648 - 13/02/2002 12:09 Re: Empeg won't boot [Re: tfabris]
ninti
Loc: Los Angeles
YEAH! Doing it exactly in that order worked. I had always plugged it in and then ran the upgrade program and didn't realize the order might make a difference.
Thanks a bunch Tony. You're the man.
