Page 5 of 5 < 1 2 3 4 5
#69539 - 10/02/2004 15:46 Re: Hijack v365 [Re: Chimaera]
Micman2b
Loc: Central, NC, USA
I have a question, how do you install the drivers? When trying winXP 'Add Hardware' wizard the driver is not detected so i cannot get it installed.. I am using the NXPFA101.INF file
Sean in NC
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#69540 - 10/02/2004 16:14 Re: Hijack v365 [Re: Micman2b]
Chimaera
Loc: DFW Area, Texas, US
My W2K machine detects new HW and then asks for the driver, I point it at the INF file and it "just works".
Although thinking about it I have always used the install CD and never tried the drivers from the Netgear site, I would assume they work the same way.
#69541 - 10/02/2004 16:36 Re: Hijack v365 [Re: Chimaera]
Micman2b
OK for the la(me)y man, Is this the install process?,
Install v369.hijack.mk2.zImage (latest HiJack as of now
Plug in USB to empeg
Install driver s where/if prompted by WinBlows(XP)
Sean in NC
_____________
Sean in NC
#69542 - 10/02/2004 16:40 Re: Hijack v365 [Re: Micman2b]
You must reconfigure and recompile hijack first -- the USB-ethernet stuff is not built-into the binaries I provide; rather, it is merely included in the sources.
#69543 - 10/02/2004 16:41 Re: Hijack v365 [Re: Micman2b]
Chimaera
The latest Hijack (369) doesn't have the support for this feature enabled, so you would need to rebuild the hijack kernel from its source after enabling the PEGASUS flag, flash that resulting kernel, then continue with the "plug in USB to empeg..."
The reason it isn't compiled in as default yet is that it is very buggy and will crash your empeg, when I get it working it will be up to Mark to decide if it is enabled by default or not.
#69544 - 10/02/2004 17:13 Re: Hijack v365 [Re: mlord]
Micman2b
Not ready for the masses yet then...
Sean in NC
_____________
Sean in NC
