#68726 - 08/02/2002 15:49 Emplode 2.00b11 failed to restart player
robricc
Deleted two empty playlists and uploaded an album. Got the attched error during the sync (wouldn't restart player). The player went into standby and didn't wake up. Needless to say, all desired operations were completed.
#68727 - 08/02/2002 16:04 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
beaker
Loc: England
Empeg MkII
2.0b11
Hijack v193 (should I be using this yet?)
Win '98 SE
Ethernet
I've done three syncs with 2.0b11 and every time I've had this error (attached). Everything seems to be ok though.
#68728 - 08/02/2002 16:29 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
Hmm. I haven't gotten any synch errors with either betas 10 or 11. I would suggest getting a log from emplode (turn on its logging feature).
#68729 - 08/02/2002 16:40 Re: Emplode 2.00b11 failed to restart player [Re: tfabris]
robricc
Will do, but I've sync'd twice since and it all went good.
#68730 - 08/02/2002 16:51 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
loren
Same here. During the first sync i got that exact error, but now it's syncing fine.
|| loren ||
#68731 - 08/02/2002 16:54 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
beaker
Loc: England
I tried another sync with logging turned on and guess what? Yep it synced fine that time. I'll keep logging on just in case it decides to play up again.
#68732 - 08/02/2002 16:57 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
The first synch I made with beta11 was uploading a 120Mb file. The file uploaded correctly too, but when the player had to restart I got an error and the player locked up. Don't know if it's the same error you guys had, but I suspect it is.
Manually cold rebooting the player did the trick. I didn't even have to resynch to rebuild the database. All continued like nothing had happened.
All my other synchs I've tried since then have been successful.
#68733 - 08/02/2002 17:11 Re: Emplode 2.00b11 failed to restart player [Re: BartDG]
NicolasW
Loc: USA
I got the same "failed to restart player" error. It seems to be intermittent.
#68734 - 09/02/2002 00:13 Re: Emplode 2.00b11 failed to restart player [Re: NicolasW]
Neutrino
Yep, I got the same error. Not the first time I synced, but the first time I synced after deleting and adding songs to the unit.
#68735 - 09/02/2002 11:03 Re: Emplode 2.00b11 failed to restart player [Re: Neutrino]
Ah! That's right! I forgot about that. Prior to uploading that file to the player when it didn't reboot, I DID remove a file. Maybe that's the cause?
#68736 - 09/02/2002 15:21 Re: Emplode 2.00b11 failed to restart player [Re: tfabris]
753
Here.
67340-emplode.log (144 downloads)
_______ Thomas
#68737 - 10/02/2002 15:22 Re: Emplode 2.00b11 failed to restart player [Re: beaker]
bonzi
Let me add my own:
MkIIa, 2.0b11, Hijack v196, ReserveCache=16
No big deal (fails after everything is done, while re-connecting to the player), but still annoying.
#68738 - 10/02/2002 18:50 Re: Emplode 2.00b11 failed to restart player [Re: bonzi]
SE_Sport_Driver
Yep, it was a one time thing for me too....
#68739 - 11/02/2002 03:54 Re: Emplode 2.00b11 failed to restart player [Re: robricc]
This is a known bug in beta 11. Your music has been synchronised, but then the player wandered off into a wibbly wobbly world of its own. Hopefully this will be fixed soon.
#68740 - 11/02/2002 11:07 Re: Emplode 2.00b11 failed to restart player [Re: peter]
You just gotta love those technical terms.
