#68074 - 07/02/2002 00:34 Hijack Problem
JAbraham
Loc: Western Australia
Hi ,
When using winamp to listen to the files on my Empeg the files cut short and don't complete playing.
Has anyone else had this problem??? If so is there a fix
Any help would be great
Jamie
MKII 12GB Blue 080000438
#68075 - 07/02/2002 01:25 Re: Hijack Problem [Re: JAbraham]
I'm not getting this problem. My files play through. When you say "cut short", be more specific. How far do they get and what exactly does WinAmp do when they get cut short?
#68076 - 07/02/2002 17:46 Re: Hijack Problem [Re: tfabris]
JAbraham
Hi Tony,
It changes - It will play for 10 seconds somtimes 30 then it is like it reaches the end of the song and goes on to the next one.
Thanks for getting back to me
Jamie
#68077 - 07/02/2002 18:47 Re: Hijack Problem [Re: JAbraham]
number6
What version of HIjack are you running?
I had a similar problem with earlier HTTP streaming capable Hijack kernels whereby if you stopped a file from within (or Winamp got a error/crashed etc) then Hijack would only ever serve all subsequent files to this point and then stop, until it was rebooted.
The variable length between songs before they are cuyt off could be because of different bitrates in the mp3 files and whether the file has CBR or VBR recording in it (ie. Hijack stops at file offset X, but how long this is terms of elapsed play time will depend o nthe above factors and may differ for each song you play).
I would strongly suggest trying (a) a reboot of the Empeg - then see if the problem goes away and if so (b) try the latest Hijack kernel (and if its the latest hijack kernel you have, try a earlier one to see if the problem existed then as it may be a recent Hijack bug).
#68078 - 07/02/2002 19:17 Re: Hijack Problem [Re: number6]
TheAmigo
Are you sure it's hijack and not WinAmp? I can't say I know what would be causing it, but here's another test: If WinAmp is caching the song length, it could be the one closing the stream. Once you have a song that cuts short, load up WinAmp on another computer and see if it cuts short at the same spot.
--The Amigo
#68079 - 07/02/2002 20:10 Re: Hijack Problem [Re: number6]
JAbraham
I Have upgraded to version to the latest and the problem still occurs.
Goes away when I reboot then if a few users start streaming it comes back.
Jamie
#68080 - 07/02/2002 20:21 Re: Hijack Problem [Re: JAbraham]
Well, hook up the empeg serial port and watch for error messages.
#68081 - 07/02/2002 20:29 Re: Hijack Problem [Re: mlord]
JAbraham
thankyou mark will do that tonight and see what happens.
May be a resource issue as I have an old MK2 player
cheers
Jamie
#68082 - 07/02/2002 20:35 Re: Hijack Problem [Re: JAbraham]
>I have an old MK2 player.
Me too.
Are you playing by clicking on "play" (correct), or by clicking on the song title (not correct)? I get chopped tunes when I do the latter.
#68083 - 07/02/2002 20:38 Re: Hijack Problem [Re: mlord]
JAbraham
Hi,
I am using the play link - others may be using the name link.
once this is done would it cause the normal streaming to also chop???
Jamie
#68084 - 07/02/2002 20:47 Re: Hijack Problem [Re: JAbraham]
Well, neither should chop, unless there's a bug in the client (web browser or mp3 player software).
#68085 - 07/02/2002 20:50 Re: Hijack Problem [Re: mlord]
JAbraham
do you have the player software on the unit running at the same time as Serving???
Jamie
#68086 - 07/02/2002 20:57 Re: Hijack Problem [Re: JAbraham]
I had the same problem happen the other day at work. I might have had 3 streaming connections plus the player running. Issuing a serial=q to quit the player fixed it right up.
#68087 - 07/02/2002 21:53 Re: Hijack Problem [Re: hybrid8]
The only possible thing is maybe the network layer ran out of memory.. the kftpd/khttpd pre-allocate what they need up front to avoid such problems, but the network stuff..
Anyway, if that's all it is, then this ought to fix it
[Startup]
ReserveCache=8
#68088 - 08/02/2002 10:44 Re: Hijack Problem [Re: mlord]
beaker
Loc: England
The guys at work have been listening to my tunes via WinAmp & Hijack since you got it working a few days ago and they haven't reported any cutting off of tunes or any other odd behaviour. However I'm pretty sure I've got
[Startup]
ReserveCache=8
in my config.ini already. Maybe that's why I haven't experienced any problems. Mine's also an Empeg MkII.
