Page 2 of 2 < 1 2
#63880 - 30/01/2002 13:15 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
crazymelki
Loc: Switzerland
Mark,
I found the problem. in your example is written:
[ir_translate]
PopUp0=Info,Mark,Repeat,SelMode,Shuffle,Source,Tuner,Visual
But I did now only:
[ir_translate]
PopUp0=Info,Visual
And this is working! I think there is a little mistake on your documentation.
Because of the NextSrc. I did this only test here on my desk. But I haven't here a Tuner...I think this is the problem. Because you are writing that Player -> Tuner -> Aux are the steps.
bye
crazymelki.com
#63881 - 30/01/2002 14:49 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: crazymelki]
The problem with the Popup0 example was that I said "Visuals" instead of "Visual".
The "NextSrc" works for me, on a standalone player with no tuner.
#63882 - 30/01/2002 15:16 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
crazymelki
Loc: Switzerland
Sorry Mark,
But I have two (Mk2 and Mk2a) Players with 2.0B7 and V156. But If I choose form the "Knob Press Redefiniton" "NextSrc" there is no action on my quick press. But if I change to all other definitions it works.
Also if I have it on the PopUp0 Menu, I can see this name but after pressing the knob nothing happens. It goes back to the normal player screen.
I think that the Device have to go to the AUX mode, if the Tuner is not present. Or not?
Let me try it tomorrow in my car.
I really estimate your work! And the only think I try to do, is helping you to develop a great work.
bye
crazymelki.com
#63883 - 30/01/2002 15:30 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: crazymelki]
Okay, so you mean "NextSrc" on the knob-press menu (it also exists in [ir-translate]..).. Well, that works just fine for me, on both a Mk2 and Mk2a, with and without a Tuner.
Too bad for you.
And the PopUp0 requires that you add a line to your config.ini, and the example I originally posted said "Visuals" on that line, which is an error, it should have said "Visual". Fix that, and it also works fine.
#63884 - 30/01/2002 15:41 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
crazymelki
Loc: Switzerland
Yes I know
I changed also the mistake in the config.ini. If there is a mistake like "Visuals" the PopUp0 is not working.
But anyway. I have thousand of of more features because of Hijack. So there is no problem, if only one is not working.....
crazymelki.com
#63885 - 30/01/2002 16:38 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
ellweber
Loc: Saratoga, CA, USA
Two questions:
1) If knob press is redefined to activate "Details" and the Empeg is left displaying details should a redefine of knob press to something else still work. I got into this trap inadvertantly and when I tried to redefine knob press as a popup it wouldn't! Not a big deal, but I had to go back to details and back out to a regular display mode before I could use the knob press linked popup.
2) Would it be possible to create a symbolic name for cycling through the auto volume adjust modes that could be included in a popup menu as is available in the regular Hijack menu with "VolAdj+"?
Playlist browsing is GREAT!!!
Lynn
#63886 - 30/01/2002 18:30 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: ellweber]
1) Yes, other knob press definitions should still work when Details are displayed.. or at least that's what happened when I tried it just now.
2) I'll add a "VolAdj" buttoncode as part of v157 tonight.
#63887 - 30/01/2002 18:46 Hijack v157: .m3u support in playlist browser [Re: mlord]
Okay, v157 is out. New this time around:
-- new syntax for playlist browsing:
http://your.empeg/drive0/fids/101?.html
-- two drive systems will still have troubles (not fixed yet).
-- .m3u (mp3 playlist) files are generated now, for individual tunes as well as albums. But not for nested playlists. Let me know if it works or not.
-- A "VolAdj" virtual button code has been added for ir_translate. Completely untested. Again, feedback will be useful.
-- The missing button name for "Source" has been added.
Have fun!
Edited by mlord (30/01/2002 18:57)
#63888 - 30/01/2002 18:51 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
ellweber
2) Thanks, who could ask for anything more (responsiveness wise at least).
1) Working now for me too, just had to wait for "Details" to time out.
Lynn
#63889 - 30/01/2002 18:58 Hijack v158 [Re: mlord]
Ooops small bug (m3u for single tunes was broken) in v157 -- v158 now replaces it.
#63890 - 30/01/2002 19:05 Re: Hijack v158 [Re: mlord]
charcoalgray99
v158
m3u for single tunes is working.
m3u for playlists comes up with a 404 for each tune inside winamp...
The file info for a tune inside winamp looks like http://192.168.168.20/drive0/fids/13920
but when I play it by itself it looks like http://192.168.168.20/drive0/fids/3660 and works ok. Looks like a wrong fid.
Tom
#63891 - 30/01/2002 20:08 Re: Hijack v158 [Re: charcoalgray99]
Yang
Loc: Raleigh, NC
Edit:.. ok.. easy solution.. the numbers generated in the playlist .m3u are in decimal, should be hexidecimal..
Edit: The times still appear to be 1 second too long.
Edited by Yang (30/01/2002 20:15)
#63892 - 30/01/2002 20:19 Re: Hijack v158 [Re: Yang]
cwillenbrock
Loc: Dover, NJ
The main problem is just a missing step in the conversion...he'll catch that one right quick. The one second thing could be a rounding problem. Certainly no biggie.
Thanks a lot for your time, Mark...it's coming along very nicely!
- Chris Orig. Empeg Queue position 2
#63893 - 30/01/2002 20:25 Re: Hijack v157: .m3u support in playlist browser [Re: mlord]
Mark is it possible PopUp menus got broken in v158? I flashed from v154 to v158 and my PopUp doesn't, well, pop up. Instead, I get this on the serial when I push the knob:
popup_activate(0fffff9): 00000000
The relvant lines in config.ini:
[hijack]
PopUp1=Tweak
[ir_translate]
PopUp0=Tweak,Info,Shuffle,Mark
Tweak=Artist,Album,Genre,Year,Swap,Cancel
#63894 - 30/01/2002 20:35 Re: Hijack v157: .m3u support in playlist browser [Re: tonyc]
Yang
Loc: Raleigh, NC
your lines:
should be:
PopUp0=PopUp1,Info,Shuffle,Mark
PopUp1=Artist,Album,Genre,Year,Swap,Cancel
Edited by Yang (30/01/2002 20:35)
#63895 - 30/01/2002 20:36 Re: Hijack v157: .m3u support in playlist browser [Re: Yang]
This must have changed then because it worked fine in v154. The line in the [hijack] section is supposed to substitute PopUp1 with Tweak
#63896 - 30/01/2002 20:52 Re: Hijack v157: .m3u support in playlist browser [Re: tonyc]
Yang
Loc: Raleigh, NC
What Mark said here is that the ir_translate section is read before the hijack to prevent the renaming from affecting the translations..
#63897 - 30/01/2002 20:55 Re: Hijack v157: .m3u support in playlist browser [Re: Yang]
Er um... Hmm. This worked in v154 and it doesn't in v158 so something changed... I'm sure Mark will be overjoyed to explain it to us.
In any event, changing it worked.
#63898 - 30/01/2002 20:59 Re: Hijack v157: .m3u support in playlist browser [Re: tonyc]
Already explained elsewhere.. it was a bug that it happened to work by accident in the early versions.. Note that if you actually tried it after a power-off in the early version, it would NOT work.
#63899 - 30/01/2002 21:05 Re: Hijack v157: .m3u support in playlist browser [Re: mlord]
OK.
#63900 - 30/01/2002 21:25 Hijack v159 [Re: cwillenbrock]
Yeah, couple've goofs in the sprintf() formatting..
v159 will be out shortly with fixes.
#63901 - 30/01/2002 21:27 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: ellweber]
Instead of "waiting for details to time out", just hit the knob again.. "Details" cancels "Details", so does the bottom button on the front panel (I think).
#63902 - 30/01/2002 22:23 Re: Hijack v158 streaming bug? [Re: mlord]
number6
I have V158 of hijack on my mk2 Empeg, while testing the mp3 streaming to winamp [which works well] after I'd played a few songs (and I had closed winamp) -
Then I tried another song (and I hit the stop button in winamp after it had restarted itself) and within a few seconds of a song starting playing.
Then any song I tried to play from them on via the http interface would stop streaming at the same few seconds point where the song I stopped stopped playing.
Once I rebooted the empeg, problem went away again.
[variable not reinitialised properly or at all?].
Not sure if the problem is a bad error code returned from Winamp or what. The Winamp I'm using is 2.78
[Edit]
Try as I might I can't reproduce it now on V158 - and now I've upgraded to V160. I assume its related to some weirdness with Winamp as I had the Moodlogic plugin enabled at the time and it popped itself up when winamp did and when I closed the plugin it must have caused Winamp to spit back a bad error code to the hijack http server causing it to serve later mp3 files to that point only]. I've no idea what the problem is. I'm not worried by it as a reboot fixed it. However it could be a potential bug in the http server that should be fixed. If needed I will try and reproduce on a later version of the kernel to see if its still there].
[/Edit]
Edited by number6 (30/01/2002 22:51)
#63903 - 30/01/2002 22:44 Re: beta version number [Re: mlord]
number6
I just noticed on my system [running hijack V160 now], that the version reported on boot up from the Empeg software
[player?] is 2.0Beta3
[the screen that appears after waving Tux which has text at the top left hand side that looks like:
empeg-car
Version 2.0 Beta3
empegcar
And has the small empeg logo on the right hand side.
I also notice that Marks kernels are now named in this format:
vXXX.hijack.v200b8.mkY.zImage
with the orange text being b8 for presumably beta 8?
[b8 was b7 a while ago].
Is the Beta3 version number in the Player software or in the kernel as a hangover from Beta 3 or what?
I assume its the player software which if it is the case is not Something that Mark [or any kernel hacker] can do much about.
#63904 - 31/01/2002 01:16 Re: beta version number [Re: number6]
That text comes from the player software. Mine says "beta 7 (internal)" as it should. I think you should make sure you really do have the beta7 version of the player installed.
#63905 - 31/01/2002 03:19 Re: beta version number [Re: andy]
number6
I am sure I upgraded my software from B3 to B7 on or during Christmas [about 5 weeks ago now].
I also upgraded my emplode at the same time - and it reports as Beta 7a.
I could swear on a stack of bibles that I upgraded my player as well as my wifes one to beta 7 - but mine shows beta3 for the player and my wifes (correctly) shows beta 7 (internal).
Anyway. I've [re]applied 2.00 Beta 7 [it now says beta7 Internal in the player version# too].
Then I put Mark Lords latest Hijack kernel on - all seems well.
And you know what - I now get that flashing dot in the solid line when playing a tune with Info enabled - which I recall everyone commenting on when beta7 came out, but I never saw on my player - now I know why [D'uh].
#63906 - 31/01/2002 06:16 Re: beta version number [Re: number6]
If you see "bet3", then that's the player software that you have installed. You should probably upgrade to beta7. The kernel is independent of all of this.
#63907 - 31/01/2002 11:13 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: mlord]
crazymelki
Loc: Switzerland
hello Mark,
Now if found where the bug is . I had enabled in the emplode under ->File->Configure Player->Advanced the checkbox "Disable Kennwood Remote Control". And with this settings the NextSrc is really not working on MK2 and MK2a.
Hopefully you trust in my something more ....
crazymelki.com
#63908 - 31/01/2002 13:48 Re: Hijack v154: User-Defined Pop-Up Button menus [Re: crazymelki]
Ahh good one. I will modify the NEXTSRC implementation to use RIO codes instead of Kenwood codes.. it will work slightly differently as a result, though, be should be fine (the Kenwood remote has more functionality than the Rio for this purpose).
Page 2 of 2 < 1 2
