#63813 - 28/01/2002 03:08 GSM and Nav system connection
Dava
Loc: Bucks UK
I have the empeg working fine into 3 amps; 1 for the fronts, 1 for the rear fill and 1 for the sub. I have a speaking nav system and also a GSM phone car kit. I would like to feed the GSM and nav output to both channels of the front amp in parallel with the empeg.
So far I have put a potentiometer across the nav speaker level output with the slider connected to the signal line of the left speaker. This allows me to dial in the voltage to this channel and it all works well. The empeg hushes and the nav system can be heard above the music.
I would ideally like to output this signal (and the phone signal later) to BOTH channels but if I do this by linking the left and right input it works but obviously I loose the stereo signal from the empeg as both channels are bound together giving mono.
Question: What components would be required so that the Nav mono output can be fed into the 2 separate L-R channels without binding them together?
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#63814 - 28/01/2002 11:16 Re: GSM and Nav system connection [Re: Dava]
Is there any way to use one of those Sony XA39 switching relays in this setup? Then you wouldn't be combining channels at all.
#63815 - 29/01/2002 02:59 Re: GSM and Nav system connection [Re: tfabris]
Dava
Loc: Bucks UK
My last resort is a home made varient of this, but was sure that someone with a good electronic engineering background here would be able to suggest a discreet component alternative.
If all else fails, I will have a relay 'bind' the 2 channels and the 2 external outputs when the mute signal goes low.
I was hoping to avoid relays due to the unpleasent clicking.
#63816 - 29/01/2002 03:04 Re: GSM and Nav system connection [Re: Dava]
Not to mention the possibility of introducing noise and ground loops if it's a homemade system. I don't know if that Sony box "clicks" or not, but I'd lay you odds that it's less likely to induce noise than a homemade system.
