#60809 - 18/01/2002 12:57 2 emplode questions
jlira
1. i have a track that somehow is in 4 playlists. but it should only be in 2. is there a way to find all the playlists that reference this track so i can "clean" it out of them?
2. is there a way to reset the "times played" statistic on a selected track?
thx
joe
30102792, 10 GB, Blue
#60810 - 18/01/2002 13:06 Re: 2 emplode questions [Re: jlira]
1. Not easily. Simplest thing is to delete the track (but don't sync), then type 'changed' into the advanced box (assuming 2.0b7 here). Note these playlists down. Bail out of emplode, without synchronising, and then go investigate these playlists.
2. Not easily. emplode has very little in the way of facilities for resetting the statistics. You can delete the whole lot (and your EQ, and your bookmarks) by zeroing the contents of /dev/hda3. Don't do this unless you know what you're doing, though.
#60811 - 18/01/2002 13:45 Re: 2 emplode questions [Re: Roger]
tms13
Loc: Lochcarron and Edinburgh
Or use JEmplode as I suggested .
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#60812 - 18/01/2002 13:47 Re: 2 emplode questions [Re: tms13]
Yep, that's certainly an alternative .
#60813 - 18/01/2002 15:40 Re: 2 emplode questions [Re: Roger]
jlira
unfortunately i can't get jemplode to find my player via USB or ether
