#58255 - 12/01/2002 16:23 track grouping
kday
Loc: Boston, MA
Maybe this is already possible and I haven't figured out how yet...
I'm in the process of ripping and uploading 6 CDs worth of Shostakovich string quartets. I would like to put them all in a playlist and be able to play a random piece when the mood strikes me. However, right now I will get a random movement, since each piece is a number of tracks long. I'd rather not jump into the middle of a piece.
Can I do this with sub-playlists now?
#58256 - 12/01/2002 19:04 Re: track grouping [Re: kday]
No.
But just recently seang made a very good suggestion for a "Never Shuffle" option (see here) that would do what you want.
#58257 - 12/01/2002 19:40 Re: track grouping [Re: tanstaafl.]
smu
Loc: Germany (Ruhrgebiet)
Hi.
Actually, I made just that suggestion quite a while ago (had to search for it) right here, along with some other suggestions regarding randomize/shuffle modes.
cu,
sven
#58258 - 14/01/2002 06:13 Re: track grouping [Re: tanstaafl.]
No.
Are you sure? What happens if you organise the mp3s into one playlist per quartet, then organise those playlists into a playlist called "Quartets" (or "Shostakovich"). Then set the Quartets playlist to be always-randomise (in Emplode's properties window).
Then, with shuffle turned off on the player, select the Quartets playlist. What you should get, is quartets in a random order, but with the movements in the right order within each one. If you don't, it's a bug!
