Page 2 of 2 < 1 2
#57287 - 28/01/2002 12:34 Re: Added HD: doesn't work in car [Re: mlord]
eternalsun
Loc: San Jose, CA
How many total flash bits are there?
Calvin
#57288 - 28/01/2002 12:55 Re: Added HD: doesn't work in car [Re: eternalsun]
The flash savearea is 128 * 8 = 1024 bits in size. Hijack "hijacks" 64 of those bits, and could be kicked out at any time if the Rio player software ever claims those bits (looking more likely by the day..).
#57289 - 28/01/2002 13:07 Re: Added HD: doesn't work in car [Re: mlord]
So maybe it's time to think about that "raw writes to a file on the disk while mounted read-only" strategy you have on your to-do list?
#57290 - 28/01/2002 13:24 Re: Added HD: doesn't work in car [Re: tonyc]
Someday soon. But that doesn't help with the data that MUST be read before the config.ini file can be read in (most of the bits)..
#57291 - 28/01/2002 13:35 Re: Added HD: doesn't work in car [Re: mlord]
True... That's a dilly of a pickle...
#57292 - 29/01/2002 10:05 Re: Added HD: doesn't work in car [Re: doug316]
Is this working for you now with the latest Hijack kernel?
#57293 - 02/02/2002 11:57 Re: Added HD: doesn't work in car [Re: mlord]
doug316
Nope, still have to manually reboot.
#57294 - 02/02/2002 16:35 Re: Added HD: doesn't work in car [Re: doug316]
Okay, I'll bump up the timeout some more for v168. Once we get a timeout that works for you, it should be fine.
#57295 - 04/02/2002 21:12 Re: Added HD: doesn't work in car [Re: mlord]
doug316
Still no dice...you think maybe you could build me a special image with a rediculously large delay and we can see if that solves the problem? I'm thinking maybe the delay isn't in the right place.
Page 2 of 2 < 1 2
