#56546 - 08/01/2002 12:42 Sync failed / Backtrace: no frame pointer on empeg
jdandrea
Loc: New Jersey
Trying to synchronize a simple typo change. At the Removing Deleted Items phase, Emplode replies with "Synchronize failed while removing deleted items. An established connection was aborted by the software in your host machine. (error 0x80072745)"
Meanwhile, I have a terminal open on the empeg. I see this whiz on by, followed by a stalled empeg that won't turn on again (unless I unplug it - and when I do that and try a rwm I'm told the drives need fsck-ing, and when I do that, no problems are announced). Clues?
c08e9f00: 00000002 00000100 00ad8f76 00000000  00000000 c09ae3fc 00000000 c09ae330
c08e9f20: 00000000 c09ae400 c09ae3fc 02186620 c0127558 c004d310 c09ae330 c09ae330
c08e9f40: c09ae330 00000000 c09b07a0 c07a4000 00000001 c0047b44 c01044c4 c0040274
c08e9f60: c06c3650 c09ae330 c004a810 c09b07a0 c0b2b1e0 c0b23018 c06c3650 c09b07a0
c08e9f80: 00000000 c06c3650 c00398e8 c09b0020 fffffffe c09b07a0 c003999c be3ffc08
c08e9fa0: c000a0c8 0000000a c08e8000 c08e9ff4 c0009f20 be3ffc08 02163250 00000001
c08e9fc0: 00000000 00000000 be3ffc08 02163250 00000000 be3ffcc8 021a6c00 02186620
c08e9fe0: 00000001 be3ffc20 be3ffb34 be3ffc08 0202496c 02138254 60000010 02163250
Code: 1a000004 e28630dc (e7932107) e3520000 13a02000
Restored terminal settings
-- JD - SN# 040104008 (120GB Blue, Digital Out)
#56547 - 08/01/2002 13:08 Re: Sync failed / Backtrace: no frame pointer on empeg [Re: jdandrea]
jdandrea
Loc: New Jersey
Tried again, this time with logging on, and with another twist: I did the BARE MINIMUM synch and just did it w/o making any changes. It went through an fsck again, and this time it rebooted and all was well. Then I went and made my typo fix and synched. Worked perfectly!
So then ... might there have been an issue doing an fsck along with another change after it? No idea, but there you have it.
#56548 - 08/01/2002 13:10 Re: Sync failed / Backtrace: no frame pointer on empeg [Re: jdandrea]
Greetings!
There could have been. Did you put the drives back to read only? That might have caused problems, but I do not know if you would see those symptoms.
#56549 - 08/01/2002 14:15 Re: Sync failed / Backtrace: no frame pointer on empeg [Re: jdandrea]
Note that Hijack kernels are compiled with "no frame pointer" to reduce the memory footprint back to something similar to a "stock" kernel. But I do keep the System.map files around, so it should still be possible to figure out what was running if anyone is so inclined.
Dunno if you were using Hijack, though.
