#56272 - 07/01/2002 23:56 Waving Tux animation on RioCar Mk2A - How?
number6
Hi,
I've got my new RioCar Mk2As, and as part of the 'set up proces' I want to make my RioCar have the Waving Tux animation like my empegs have.
I've searched the FAQ and the forum here without much success - I recall a discussion about this some time ago I also looked at the FAQ & RioCar.org and couldn't find it.
Anyway, if someone can point this out to me - I'm sure some of our new RioCar owners may like to see the waving tux animation when they boot their empegs too.
#56273 - 08/01/2002 00:41 Re: Waving Tux animation on RioCar Mk2A - How? [Re: number6]
Grab Tony's logo editor from the downloads on RioCar.org. Open it, go to "File, Select your player type". Ensure it says empeg, then do a "File, Delete logos from player"
Thats the easiest way.
#56274 - 08/01/2002 01:14 Re: Waving Tux animation on RioCar Mk2A - How? [Re: drakino]
muzza
also make sure you're running v2 of player and emplode. this intro is not on v1.x
#56275 - 08/01/2002 02:55 Re: Waving Tux animation on RioCar Mk2A - How? [Re: drakino]
number6
Done all that and it works fine.
Can we get this in the FAQ for next time?
#56276 - 08/01/2002 13:06 Re: Waving Tux animation on RioCar Mk2A - How? [Re: number6]
It's already in the FAQ. Right here. Been there for months.
#56277 - 08/01/2002 13:17 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
number6
You're right Tony,
And I read that section aty least twice before I post *AND* I searched the FAQ for Waving Tux (with no luck).
That last sentence in the FAQ explains it - perhaps we should make a reference to Waving Tux in that sentence as thats what most people change the official boot logo to if they change it at all, that way it would show up in FAQ searches related to waving tux.
I think its good that some of the newer folks here realise that they don't have to live with the Rio animation on start up and can easily change it to the reallly, really cool Waving Tux animation in about 15 seconds.
#56278 - 08/01/2002 13:21 Re: Waving Tux animation on RioCar Mk2A - How? [Re: number6]
SE_Sport_Driver
You guys are going to shoot me, but I just changed my year old (I joined almost exactly a year ago!) empeg to the Rio boot up logo ... just for a change. And I wanted somthing a little less... cartoony for a few weeks.
#56279 - 08/01/2002 13:30 Re: Waving Tux animation on RioCar Mk2A - How? [Re: SE_Sport_Driver]
BOOOOOOOOOOOOOOOOOOOO!!!
(heh heh heh.. HTML works now... This could be a bad thing.)
#56280 - 08/01/2002 13:46 Re: Waving Tux animation on RioCar Mk2A - How? [Re: number6]
Good idea. Will do.
#56281 - 08/01/2002 14:47 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tonyc]
It always has, except in the Off Topic form when it was initially created. I still use the HTML tags for my quotes most of the time instead of UBB code.
"Fill out the form below to post a message on the forum. HTML is enabled. UBBCode is enabled, so you may use UBBCode in your posts"
#56282 - 08/01/2002 15:00 Re: Waving Tux animation on RioCar Mk2A - How? [Re: drakino]
The one cool thing about UBBCode I've noticed is that if you use the (url) tags, it automatically does the right thing to make the link pop open in a new window.
#56283 - 08/01/2002 16:20 Re: Waving Tux animation on RioCar Mk2A - How? [Re: wfaulk]
Fogduck
Loc: BC
Woohoo! No more Rio logos in my player! Walking-up-sitting-and-waving tux is way more cool/friendly.
I didn't see a menu option to remove the logo on the outside of the case...
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
#56284 - 09/01/2002 21:18 Re: Waving Tux animation on RioCar Mk2A - How? [Re: drakino]
jlira
when i try to do this it says either "couldn't find manufacturer ID" or "couldn't find product ID"
it makes me unplug/plug the unit every time i try too
any suggestions?
joe
30102792, 10 GB, Blue
#56285 - 10/01/2002 12:24 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
jlira
blank
Edited by jlira (10/01/2002 12:24)
#56286 - 10/01/2002 14:20 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
Make sure the Com port is set right in the logo program, and that you have any other devices using a com port turned off (like a modem, or Palm Sync software). Have you been able to do an upgrade on the unit? Also, try connecting with Hyperterminal to see if you can watch the bootup messages on the empeg. This should help to determain if it's a com port problem.
#56287 - 10/01/2002 14:37 Re: Waving Tux animation on RioCar Mk2A - How? [Re: drakino]
jlira
yeah i have no problem connecting, whether for flash upgrade or to start the logo process. i get to the message
- READY TO BEGIN SENDING DATA -
- The player should reboot and the data -
- transfer should begin automatically. If -
- this doesn't happen within the next few -
- seconds, then do the following: -
- UNPLUG the power from the empeg car player, -
- then PLUG IT IN again to begin the data -
- transfer process. -
- Please do this now. -
then i cycle power
then i get this:
found empeg unit: entering program mode
Error: Couldn't find manufacturer ID!
Press the Enter key to continue.
i have hyperterminal (as well as secureCRT) but i don't know how to connect with them. i tried a com1 session with HTerminal and it counted up the connected clock but the cursor just hung in the upper left ... nothing happened and it didn't respond when i typed "ls" for example
what's wrong with my empeg?
joe
#56288 - 10/01/2002 14:40 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
I've had problems with HyperTerminal wher it won't see the data coming from the empeg if you ``Connect'' before you plug the empeg in. So try clicking connect after you plug in the empeg. I don't have this problem with SecureCRT. But my version of SecureCRT seems to have a problem with sending ZModem in that it's really slow (like 100 Bytes/sec).
#56289 - 10/01/2002 15:02 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
Assuming you set the correct options in hyperterminal, then the problem lies with the COM port, the PC's settings, or the cabling. You should be able to see what you're typing at the shell prompt.
If Hyperterminal won't work then the logo editor won't work either, as they use the same communication method.
Try it on a different computer and see if it works.
#56290 - 10/01/2002 15:08 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
jlira
i have tried it from 3 different PC's with the same result. it DOES recognize the empeg, and it does flash upgrades like a champ, so i'm inclined to think it has nothing to do with the COM port or the cable.
should i give up?
#56291 - 10/01/2002 15:16 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
But at the very least Hyperterminal should work.
If you can do full player upgrades but Hypterterminal does not work, I don't see how that can be? I would think it would be the other way around.
Now there is a known problem on some computers with the "download.c" code (which I did not write by the way) where it doesn't work on some systems. Someone else had a version of download.c that was slower because it printed debugging information to the screen, and that slowed it down enough to work on their system. Unfortunately, I am waiting for someone who's having that problem to mess with different timings in download.c, and find out exactly where the delay needs to be inserted, before I make any changes to my copy in the logo editor. I can't reproduce the bug so I can't experiment with it myself.
#56292 - 10/01/2002 15:16 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
jlira
when i connect via hyper, i get a few meesages, like this:
dhcp_thread.cpp :1447:Sending DHCP discover (eth0)
dhcp_thread.cpp :1425:Extensions present: 61 53 55 57
and a blinking cursor. but if i type anything on the keyboard, such as ls, nothing happens.
when i cycle power i get this:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #5 Sat Dec 22 10:18:24 GMT 2001
empeg-car player (hardware revision 9, serial number 30102792)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:e
8
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 550:empeg-car 2.00-be
ta7 (internal) 2001/12/22.
dhcp_thread.cpp : 413:name = lo
dhcp_thread.cpp : 414:index = 1
dhcp_thread.cpp : 415:flags = 0x8
dhcp_thread.cpp : 416:addr = 0.0.0.0
dhcp_thread.cpp : 417:bcast = 0.0.0.0
dhcp_thread.cpp : 418:mask = 0.0.0.0
dhcp_thread.cpp : 413:name = eth0
dhcp_thread.cpp : 414:index = 2
dhcp_thread.cpp : 415:flags = 0x1002
dhcp_thread.cpp : 886:Our mac is 00:02:d7:26:0a:e8
dhcp_thread.cpp : 888:Current IP address is 0.0.0.0
dhcp_thread.cpp : 890:Broadcast address is 0.0.0.0
dhcp_thread.cpp :1930:Attempting to open Autonet socket for eth0
dhcp_thread.cpp : 478:Adding interface eth0
dhcp_thread.cpp :1987:Testing Autonet address 169.254.101.198
Prolux 4 empeg car - 2.1335 Dec 22 2001
Vcb: 0x408cd000
! mp3_decoder.cpp :1052:Failed to seek to offset 1677640, error=0xc0044000
! mp3_decoder.cpp :1047:Failed to find valid sync after seeking to offset 1677
spindown_chunk_cache_runner.cpp: 292:Filling up space (109)
but still no reaction to typing ls[enter] or N[enter]
#56293 - 10/01/2002 15:21 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
That's very strange. You are able to receive characters from the player but are not able to send them. Are you absolutely sure your hyperterminal settings are correct? Triple-check that FAQ entry I linked.
And you say that you CAN perform upgrades? Because if you can, that's very VERY strange because the upgrades need to send a lot of characters to the serial port and they have to work.
#56294 - 10/01/2002 15:31 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
jlira
the only changes i made to default HTerm settings are:
115200 rate
no flow control
my AIM name is joe lira if anyone wants to walk me thru it. maybe there's some Hterm setting i don't know about that is disabling sending chars? i'll go look for a different shareware terminal program and try that out
joe
#56295 - 10/01/2002 15:33 Re: Waving Tux animation on RioCar Mk2A - How? [Re: jlira]
It won't respond to 'ls' because it's not sat at a shell prompt. Press 'q' followed by Enter to quit the player and bring up the shell prompt.
If that doesn't work, then something else is wrong.
#56296 - 10/01/2002 15:43 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
jlira
ok i tried it with SecureCRT. i can get a connection and see all the messages from the machine but i get an error
when i hit [enter] . what this error means, i have no idea.
#56297 - 10/01/2002 16:49 Re: Waving Tux animation on RioCar Mk2A - How? [Re: Roger]
Yeah, but it's not even echoing back the "L" and the "S" to him. Even if those commands did nothing, he should at least be able to see them echo on the screen, and he's not even getting THAT.
And he said that N doesn't work either.
#56298 - 10/01/2002 17:46 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
andygjones
Might want to check you dont have scroll lock on, on your keyboard - it wouldnt recognise anything i typed earlier today and i finally realised this was the problem.
As for the logoedit error, im not sure, but this is the same error i got when my home docking station serial connection was wired incorrectly, so maybe you have a bad serial cable?
RioCar 40GB RGB - can never decide
#56299 - 11/01/2002 09:45 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
Derek
Loc: NRW, Germany
Yep, I'm using a version of download.c with the debug code in and running from the command prompt. Can't remeber who was nice enough to put it together, but can go and have a look if you want. It works *most* of the time, whereas the logo editor never works for flashing kernals. Sometimes I have to try it a number of times though, and it almost seems I have to plug in the empeg at just the right moment. Haven't tried playing with logos yet.
I have a Mk 2 empeg, and the PC is an older twin processor PIII 600 (Gigabyte board). I guess I could get really keen and do some testing if you want. Have M$ Visual Studio 6 here, and at least some of the cygwin stuff, but I might need some tips on how to get download.c to compile on a Windoze box.
#56300 - 11/01/2002 10:09 Re: Waving Tux animation on RioCar Mk2A - How? [Re: Derek]
Careful of your semantics, there. Logo editor works most of the time for most people, from what I gather. I think you meant to say it never works for you.
Do you have the ability to re-compile Download.C and experiment with it? I need someone who can reproduce the problem reliably to locate the fault.
#56301 - 11/01/2002 10:42 Re: Waving Tux animation on RioCar Mk2A - How? [Re: tfabris]
Derek
Loc: NRW, Germany
Yeah, sorry Tony, flashing kernels in LogoEditor never works for me.
I shouldn't have toooo many problems compiling download.c here at work, but I haven't tried it yet. There is a small problem regarding time to do it at the mo though as I am in the process of hunting for another job among other things. If I get a chance to look at it I will post back here.
