#51563 - 28/12/2001 19:42
Re: Restoring Car Visual mode
Mark, with great great pleasure, I am honored to help!
So, here's the data you're asking:
I am using 2.00b7 Developer
In DC/Car Mode I am in Info-Off. Enter Hijack v.87, select Show Flash Savearea and read the following:
40 0001 0101 6005 0000
48 0A3F 0000 0003 0000
50 0000 0000 0000 0000
In DC/Car Mode I am in Info-Line. Enter Hijack v.87, select Show Flash Savearea and read the following:
40 0101 0101 0000 0000
48 0000 0000 0003 0000
In DC/Car Mode I am in Info-Transient. Enter Hijack v.87, select Show Flash Savearea and read the following:
40 0201 0101 0000 0000
In DC/Car Mode I am in Info-Track. Enter Hijack v.87, select Show Flash Savearea and read the following:
48 0000 0000 0403 0000
In DC/Car Mode I am in Info-Seek Tool. Enter Hijack v.87, select Show Flash Savearea and read the following:
48 0000 0000 0404 0000
In DC/Car Mode I am in Info-Now & Next. Enter Hijack v.87, select Show Flash Savearea and read the following:
48 0000 0000 0405 0000
In DC/Car Mode I am in Info-Track Detail. Enter Hijack v.87, select Show Flash Savearea and read the following:
40 0001 0101 0000 0000
#51564 - 28/12/2001 19:50
Re: Restore Visuals Problem
Loc: Portland OR
Awesome Mark, 88 works just fine!
Now if I could only get that "Volume Ramps Up" thing to work... Hmmm...
DarioMK2 in an Impreza 2.5RS
#51565 - 28/12/2001 19:57
Version 88 Now.
In DC/Car Mode I am in Info-Off. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Line. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Transient. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Track. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Seek Tool. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Now & Next. Enter Hijack v.88, select Show Flash Savearea and read the following:
In DC/Car Mode I am in Info-Track Detail. Enter Hijack v.88, select Show Flash Savearea and read the following:
#51566 - 28/12/2001 19:58
[Re: Taym]
Thanks! Note that v88 is likely "broken" for you, but using your data I've fixed it for the next release (tomorrow sometime).
We need more contributions.. anyone else?
#51567 - 28/12/2001 20:00
I confirm, It works! Bravo!
#51568 - 28/12/2001 20:02
Broken? Meaning? I was in transient info mode, DC/Car mode forced. Unplugged, plugged, back in transient mode! Seems to be working! :)
#51569 - 28/12/2001 20:10
[Re: Taym]
Taym,
In your case, v88 is broken if you set Info==OFF and then reboot.
I'll fix it in v89 in 30-40minutes from now -- say 10:45EST (currenly 10:12EST).
#51570 - 28/12/2001 20:30
Oh! Ok, I'll test all the modes and report as soon as I finish this upload session. Unfortunately I have to wait 15 minutes at least before I can test, it's a big upload. Sorry, I thought you would release 89 tomorrow, I hope my post will be early enough to be actually useful. Anyway... THANK YOU!
#51571 - 28/12/2001 20:31
v89: Improved "restore visuals"
Okay Hijack v89 is out. The "Restore DC/Car Visuals" function is now working for everyone who has reported back on it. If it works (or not) for you, I'd like to hear from ya.
Thanks all!
#51572 - 28/12/2001 21:10
Re: v89: Improved "restore visuals"
Test HiJack v.89 on 2.00b7
DC/Car Mode Forced
Unplug/Plug Performed
Info-Off - OK
Info-Line - OK
INfo-Transient - OK
Info-Track - OK
Info-Seek - OK
Inf0-Now Next - OK
Great!
#51574 - 28/12/2001 22:06
Loc: Portland OR
89 works fine for me.
One comment... When the player boots in AC mode, it goes instantly to the assigned visual, but in DC mode, it flashes through a few screens really quickly before switching to the visual. This is expected behavior, due to the nature of your fix, right?
#51575 - 28/12/2001 23:16
[Re: Diznario]
Actually it's much simpler than that. In AC mode the player doesn't bother to switch to Track info mode because it's assuming you're not in your car while you're on AC power. The whole reason the player switches to Track info mode is to make the user explicitly turn on the "distracting" visuals, thereby absolving them of legal responsbility when someone runs their car off the road whilst engrossed in a Hula Hoops-induced trance.
So we are only concerned with switching info modes if we're in DC mode. In AC mode, the info mode will already come up correctly.
Sadly, there seems to be no easier way to switch to the correct info mode besides faking some IR presses. At least none that we've found yet... Someone who is handy with GDB and a hex editor might be able to locate (and possibly skip past) the code where the player does the info mode switch, but that would be a hefty assignment... Borislav, are you listening? I would think doing this would be similar to the unsorted menus hack... And it would provide a lot of benefit... The hijack solution is, in my opinion, less than ideal (though effective.)
#51576 - 28/12/2001 23:41
Re: v89: Improved
[Re: tonyc]
Of course if you don't want to hack the software to force-restore a visual in-car, you can feel free to run your car off the road while trying to read the info track display.
I had to slam my brakes tonight (didn't lock up or kick on ABS) to slow down and avoid smashing a raccoon, but it didn't have much to do with the empeg. Though I did think about it when it happened. "Mmmm, good thing I wasn't checking out the display just then..." :)
#51578 - 29/12/2001 07:04
[Re: tonyc]
Right. "restore visuals" is currently only working correctly for the mp3/wav player function, not for AUX or TUNER. I'll try to remember those two when I get back home next week, where my Tuner is hiding.
#51579 - 29/12/2001 07:09
[Re: Diznario]
Correct. Basically, Hijack forces "Info-Track" mode, and then waits for the horiztonal line to appear from "Info-Track", which lets it know that the player is now up and running. Note that "Info-Track" is the ONLY Info mode that can be easily "recognized" in such fashion. Then, Hijack injects the required number of "INFO" button press/releases to restore the original mode.
Concept stolen from a much older patch, forwarded to me by somebody else in this group. Good idea, and simple to implement.
#51580 - 29/12/2001 07:10
Oh yeah, this "restore visuals" feature is ONLY invoked when in "DC/Car" mode, since the player software itself handles the "AC/Home" situation -- that's why there's no "flicker" in "AC/Home".
