#51483 - 25/12/2001 14:55 Emplode properties cut and paste
thinfourth2
Has any one else seen this one
Open up some track properties and try and cut and paste between fields like cut from the title field and paste it into the artist field for example i can't get it to work.
#51484 - 25/12/2001 15:00 Re: Emplode properties cut and paste [Re: thinfourth2]
Works fine for me running Windows 2000. Works with both CTRL-C and V as well as CTRL-INSERT and SHIFT-INSERT.
#51485 - 28/12/2001 06:37 Re: Emplode properties cut and paste [Re: hybrid8]
Janosch
Loc: Berlin, Germany
Yeahh but only if you use Keyboard. Would be really fine if the Small context menu when pressing the right mouse buttion containing cut,copy,paste and insert would be appearing like it does in emplode 1.xx !
May i should put this on the wish List ?
janosch
#51486 - 28/12/2001 15:20 Re: Emplode properties cut and paste [Re: Janosch]
Oh, I didn't even notice that. Yes, it's something that should be standard any time someone makes a text field. It always pisses me off in other software (like MP3 Tag Studio) when basic Windows functionality is missing.
I've been doing a lot of external macros to manipulate playlist properties so I've been mostly concerned with what's available from the keyboard.
I'd also like a key command to be able to switch focus from the tree pane over to the list pane.
#51487 - 31/12/2001 15:36 Re: Emplode properties cut and paste [Re: hybrid8]
smu
Loc: Germany (Ruhrgebiet)
Hi.
Seconded. I just hate having to use both keyboard and mouse when doing (especially when huge amounts of) data editing.
TAB would be pretty standard when switching between panes, CTRL-TAB when switching between MDI windows.
cu,
sven
#51488 - 31/12/2001 20:25 Re: Emplode properties cut and paste [Re: smu]
Yeah, there's no context menu. Give that man a cigar. Except that it's already on the bug list.
