#50322 - 17/12/2001 06:22 Details from the front panel
tms13
Loc: Lochcarron and Edinburgh
Perhaps holding the "down" button when Info is selected in the top-level menu should bring up the Details box, like holding the Info button on the remote?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#50323 - 17/12/2001 10:08 Re: Details from the front panel [Re: tms13]
Holding the "Down" button already has a function. A few different ones, actually.
If you don't like its function, I think it might be possible to remap it using Mlord's hijack kernel. Anyone know if that's possible?
#50324 - 17/12/2001 10:22 Re: Details from the front panel [Re: tfabris]
tms13
I thought it only had functions for "Playlists" and for items under that (and outside of menus, of course). I couldn't find anything to say what it would do on "Info", and trying it just gave me the usual key-repeat behaviour.
Perhaps you've got something that's changed since beta3? (In which case, what's the new behaviour?)
Toby Speight
#50325 - 17/12/2001 10:26 Re: Details from the front panel [Re: tms13]
Its behavior when on an info screen should be the same as it was in 1.03: It should toggle between a visual mode and a text mode.
If it isn't doing that toggle, then it's either a bug or something is odd about your player.
#50326 - 17/12/2001 10:34 Re: Details from the front panel [Re: tfabris]
tms13
Ah, it looks like you've misunderstood:
I wasn't talking about an info screen.
I was talking about the "Info" menu item on the top-level menu.
When you press-and-hold the "Playlists" menu item, you get special behaviour (the last playlist you selected).
I'm suggesting similar special behaviour for the "Info" menu item.
Toby Speight
#50327 - 17/12/2001 11:07 Re: Details from the front panel [Re: tms13]
Ah, thanks for clarifying. Interesting idea.
