#49269 - 06/12/2001 20:47 help no hdd found
help
I am getting the no HDD found error. I have removed the hdd cradle and the drive cable appears to be connected everywhere
what else can I check ?
thanks
#49270 - 06/12/2001 21:20 Re: help no hdd found [Re: msaeger]
ok now I connected my 2nd drive as the primary and it booted up fine but I had 1.03 on that drive so I installed the 2.0 beta on it everything worked fine then I connected both drives in the original order and everything works fine.
I wonder if my primary drive is dying I have two ibm travelstars the primary is the 10 gig that came with the player and the secondary is a 20 gig that I added
I am planning on driving from minnesota to chicago next week (about 7 hour drive) so it would really suck if the drive dies on the way.
oh yeah and one of the drives in my desktop died also so I would have to re-rip about half of my cd's if the drive in the empeg dies.
#49271 - 06/12/2001 21:53 Re: help no hdd found [Re: msaeger]
While you have the unit open, move the drives/cable around to see if it spins up/down. A bad cable and not simply a bad connection can make your drives come on/offline at seemingly random times.
I bought my MK2a recently and the drive cable was bad. After first playing with it and adjusting, the unit worked for a while. But moving the tray assembly around could cause it to stop. A new cable sent from empeg fixed it all up.
#49272 - 06/12/2001 22:37 Re: help no hdd found [Re: hybrid8]
thanks I tried doing that it didn't cause any problems
I put it back together now we'll see if it dies again.
#49273 - 07/12/2001 01:46 Re: help no hdd found [Re: msaeger]
Another possibility is a loose master/slave jumper, or a loose IDE cable connection at the motherboard.
#49274 - 07/12/2001 05:04 Re: help no hdd found [Re: tfabris]
I checked that too I have it taped on and none of the connectors were pulled offf
