#48012 - 26/11/2001 16:40 config resync
dewdman42
Is this a bug in 2.0b3 or a problem specific to me? basically, during sync, the config player part doesn't work. It caues a failure. I am now using the Developer 2.0b3 image with no hacks added.
#48013 - 26/11/2001 16:59 Re: config resync [Re: dewdman42]
If you are referring to the specific error message regarding a "timeout while writing player configuration", this is a known bug in 2.0b3 that has been reported about two dozen times in the Bug Reports section of this BBS.
It is a cosmetic error only. If you actually test this assertion, you will see that the player configuration change did indeed get written to the player.
This bug will be fixed in the next release.
#48014 - 26/11/2001 17:01 Re: config resync [Re: tfabris]
dewdman42
great. Thanks. I don't read all the posts on this BBS unfortunately, but I just wanted to report the issue just in case.
