#44424 - 31/10/2001 20:12
alternate UI suggestion
i've had my riocar with 2.0b3 installed for 2 weeks, and filled up most of the 10 GB drive. I also have been using a 20 GB PJB for 2 years and my feeling at this point is, the PJB is easier to use. here are a few comments:
i don't use the remote because after the first time i tried to use it i found it almost impossible to tell if the button-press had registered or not (even with beeps), and it was too dangerous to watch the menu while i am driving, so i have been limited to functions i know from memory.
many of the cool features (search, skip visuals, info) aren't available without the remote unless you press a lot of buttons. there should be more parity between remote UI and 4-button UI
It takes me an average of 8 clicks to get to a certain song on the pjb, but it takes more than 20 clicks (scroll through genre, scroll through artist, scroll through album, scroll through songs) to get to most songs on the car player, because the PJB has a flatter structure perhaps. it seems really difficult to me to skip from playlist to playlist, esp. while driving. I would LOVE to see the PJB folder UI on the car unit.
i still don't know what bookmarks are used for. i have looked around and not found any common use for them documented, and so they remain unused
i also don't understand insert/append and so i haven't used them at all. they also aren't documented in the booklet
in general, it's hard to move around in the music library. the past 4 days i have just left it on one playlist because i got tired of hitting so many buttons to find something else.
playlists seem to be the primary interface to all the music, but there is no guideline that i can fidn to suggest best practices for playlist heirarchy and organization. as a result, i'm not really sure i have mine organized in the best possibel way, and actually i question my organization when i struggle to find/play music but everyone else here never mentions that problem.
as i mentioned, i have a hacked PJB with 20 GB (bought it with 6) and i also have a hacked replaytv (160 GB) and i love both these items and the empeg/riocar. even with the trouble i have using it, i prefer it to any other head unit. But of the 3, the empeg, while boasting the most active user community by far, has the hardest-to-use interface and the least documentation.
i know you guys are all very smart, so maybe i'm just a dumb "end user" but i would love to see some of these issues addressed
joe
30102792, 10 GB, Blue
#44425 - 31/10/2001 21:00
Re: alternate UI suggestion
[Re: jlira]
I don't use the remote much either because I tend to just listen to entire albums at a time and I have a play list for each album so I just need to select that playlist.
if you want a flatter play list structure why not just make one you can organize the songs and play lists any way you want.
the features you are asking about are not documented because they have only just become avaliable in the beta version of the 2.0 software. I am sure there will be some kind of manual made when the final version of 2.0 comes out. the book with the player is for an older software version.
insert/ append modes are selected using the select mode button on the remote when searching and can be selected by pressing in and holding the knob while browsing the playlists. insert just inserts the selected song next in the play list you are currently playing append places the selected song at the end.
bookmarks are used to save the current position and playlist of the playlist you are currently playing. so for instance if you are playing all the songs on the player in random order then you decide you want to play a particular list you can save the one you were playing and go back to it later.
keep posting on here it you have questions or problems someone will probably be able to resolve them.
#44426 - 31/10/2001 22:19
[Re: jlira]
I'm wondering how the PJB is different in selecting playlists? What is it that makes the PJB faster at this selection? How is it organized?
Now, as far as improving the speed of selecting songs on the empeg, try this:
- Don't have a Genres tree at all. Put your artists at the root. That will save a step. Or, if you occasionally like to select an entire genre, you can do both (have a genres tree parallel to the artists). Remember that if you copy a playlist within emplode, you're only copying its link, you're not wasting disk space.
- You can spin the knob to scroll through menus, you don't have to press buttons. That might make it faster for you.
- I know you said you don't use the remote, but you can jump to a letter in the playlists menu by pressing the corresponding key on the remote.
They are in the FAQ at Riocar.org, though. Perhaps you ought to give that a once-over?
I agree that bookmarks are not documented, I didn't realize they needed documentation. They're bookmarks. You set it, you retrieve it. Just like... uh... like...
Okay, I'll put it in the faq.
I think that's probably because everyone just shuffles the whole player (down-down-down) and doesn't spend a lot of time on selecting specific songs.
Remember that the playlist heirarchy is totally free-form. If you want something with less branches to the tree, then simply make the playlists however you want them. What are they like on the PJB?
#44427 - 01/11/2001 03:56
[Re: jlira]
Loc: Manchester, UK
If you don't use the remote because it is dangerous to watch the menu whilst driving, then why are you bothered about changing the visual/info mode without a remote whilst driving?
Your post appears to contradict itself.
#44428 - 01/11/2001 06:51
[Re: jlira]
Loc: Ipswich, MA
I have to agree with Joe.
After sending my unit back to get the IR checked out and a new remote. I have found the remote a bit of a bother, and I would rather see some of the functions implemented on the remote put into the UI. I also have to agree with Joe's point about not knowing if the button was pressed. If I push one of the 4 nav buttons I know it worked with the remote I'm not always sure.
Also on Tony's point about the rotary knob. I have always felt that this was very poorly implemented. It's too short to grab hold of and it binds on the facia too frequently, requiring a facia adjustment every so often.
As far as the organization is concerned, I don't have a lot of time on my hands to play with the playlists and try new techniques. I have longed for a "Best practices" way of organizing the music I'm sure this kind of implementation would require more attention to ID3 tags, but it would be useful.
I too generally just hit down down down to shuffle the whole player, and since the implementation of the most/least recently played shuffle life is better. I have yet to try bookmarks, but I'm sure I will love those as well.
John
___
John Turner
"It's easier to ask for forgiveness than to ask for permission"
#44429 - 01/11/2001 06:54
[Re: jlira]
Well, in response to remotes being dangerous, maybe you should consider a steering wheel remote. The Sony stalk remote plugs right into your Empeg, so no worrying about whether it registered or not. And the Pioneer CD-SR77 steering wheel remote (which I use) works great as well, though it uses IR and is somewhat subject to extremely bright light hitting the remote sensor. I never really have to look down at the player unless I'm doing something really complicated like a search... To do my root playlists is easy because I know how many button presses each one is.
I don't know what a PJB is and I don't know how it's working for you, but I can't imagine you're able to choose playlists without looking at it for at least a brief moment.
Maybe you can enlighten us on how this PJB unit structures playlists, and thus makes it easier to find stuff?
#44430 - 01/11/2001 07:04
[Re: tonyc]
Question,
I've just bought a RioCar and am considering a Sony Stalk Remote. How does this work exactly ? Is it via IR or is it wired ?
Considering the RMX4S. What functions does it control ? I don't have a tuner ...
LTJ
#44431 - 01/11/2001 07:09
[Re: LTJBukem]
the sony remote is wired it plugs into the tuner module or you can make an adaptor with a pic that plugs into the serial port although I don't know if that works with 2.0 or not
#44432 - 01/11/2001 07:10
[Re: LTJBukem]
The Sony stalk remote is wired IF you have a MkII with a tuner module. The Sony stalk interface actually lives on the tuner module, not the Empeg. I don't actually own one because I don't have a convenient location to mount it. I went with the Pioneer model which "clips on" to the steering wheel itself. So in terms of what functions it controls, maybe some RM-X4S owners can chime in.
#44433 - 01/11/2001 07:23
[Re: jlira]
I would like to see a way to skip playlists easily - so you could have all your albums seperated into their own playlist, and could skip to the next one like you would change cd's on a changer. Then maybe the ability to shuffle all by playlist instead of individual tracks.
I know one of the ideas of the empeg is to not be restricted in the same way as you are with a CD-Changer, but I often like to listen to a whole album and the ability to skip around albums would be kewl.
RioCar 40GB RGB - can never decide
#44434 - 01/11/2001 07:23
[Re: tonyc]
So, given I don't have a preference for remotes, which Pioneer model do you have and what functions does it control.
Is it IR or wired, and how reliable is it ?
LTJ
#44435 - 01/11/2001 07:33
[Re: LTJBukem]
My Pioneer is the CD-SR77. A decent drawing of the remote can be found here and you can buy one from many online resellers.
It's an infra-red remote so it has the problems of other IR remotes in that if you've got bright light shining directly on the remote sensor, forget about it. Ambient/reflected light hasn't caused me problems, but when direct sunlight hits it, it's useless. It's a small annoyance and certainly a wired remote would be nice, but the only wired one that works out-of-the-box are the Sony's, and they're not "steering wheel remotes" they're "steering column remotes." So I chose location/ergonomics over 100% reliability (mine works about 98% of the time, it's not all that sunny here.)
As for functions... Well with Frank's IR trans kernel, whatever you'd like it to control. And I actually hacked up the IR trans to allow for double the number of functions (minus one) by choosing one of the buttons to be a "toggle button" which toggles what each button sends. So there are 11 buttons, and normally 10 of them control things like next/prev track, volume, menus, source (tuner/player), info mode, etc. Then I hit the toggle button and the buttons all become the numbers 0 through 9. This lets me do searches from the steering wheel remote (a little clunky to remember which button means which number, but it works for me.) So the number of remote BUTTONS is 11, but the number of functions can be more if you don't mind hacking a little.
Really it's a matter of personal choice. My Pioneer works good for me and some others, but some people like the convenience of the wired Sony stalk remote. I just think I'd have to mount it in an odd location on my car.
#44436 - 01/11/2001 07:54
[Re: tonyc]
Loc: Florida
How did you hack the toggle into IRTrans? I'd be real interested in doing this on my Kenwood SWR.
Jason
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#44437 - 01/11/2001 08:05
[Re: Dearing]
Argh unfortunately my home DSL connection is down (I'm at work) so I can't get the code for you right now. I'll try to post something tonight, but right now mine is based on an IR trans from awhile back.. I'll have to get the 2.0b3 IR trans and see if I can create a patch that goes "on top of" his latest patch. Maybe tonight, if not, this weekend.
It changes the way the ir_codes files are structured (there's a third column for the alternate code) so you'll have to mess with that as well. And right now the toggle button is hardcoded to be the CD-SR77's "ATT" button. If I release a patch, I'll have to make this configurable, or everyone will have to hand-edit the patch or something.
#44438 - 01/11/2001 08:16
[Re: Dearing]
So Pioneer Remotes do not work without hacking.
Which remotes do ? Apart from the Rio obviously. I wanted a steering remote if possible but do not have the tuner to support the Sony Stalk.
LTJ
#44439 - 01/11/2001 08:20
[Re: LTJBukem]
Ummm there's a Kenwood steering wheel remote but I have a Kenwood head unit so its codes would cause problems in my setup. I also don't like the design of it compared to the Pioneer.
The hacking you have to do to get a Pioneer remote working is minimal. Frank's IR trans comes with basic IR codes for the Pioneer pre-programmed, so it's basically flash and go. I hacked mine to allow for twice the number of codes, that's purely optional.
#44440 - 01/11/2001 08:25
[Re: tonyc]
It is horrible isn't it.
I think the word hacking scares me. How exactly does this work. I think I would be confortable with changing the config.ini ? What would I have to do ?
LTJ
#44441 - 01/11/2001 08:27
[Re: tonyc]
Loc: Seattle, WA, U.S.A.
I seem to remember that Big John's RM-X2S serial interface would support the RM-X4S (without a tuner), but think that would be a DIY proposition at best. Plus, there'd be no room for the GPS!
Jim
Jim
#44442 - 01/11/2001 09:11
[Re: LTJBukem]
Well for starters, none of the hacking you do is going to damage your music files or your player's hardware. No matter how much you screw up an Empeg Linux kernel, unless you specifically program the kernel to overwrite all your music, you cannot damage anything important. The most you would have to do is re-flash an Upgrade file, which can be done even if your Empeg's kernel is unbootable. After the upgrade, everything is back to normal.
Having said that, if editing config.ini is about as far as you want to go with your own hacking, then you have to depend on some of the kernels that others have compiled and made available. The IR trans kernel is set up very nicely in that it's already got Pioneer codes in there by default. So you wouldn't need to do any compiling or anything, you'd just need to grab the kernel image from Frank's site, un-archive it (WinZip can extract tar.gz files.) Furthermore, Tony Fabris' Logo Editor makes the process of uploading a kernel pretty easy. Take a look at Frank's instructions and see if you think you'd be okay with following the steps he's listed, and remember, if you screw up, it's just a 20 minute or so setback to re-flash an upgrade file.
In summary, one need not be a hacker to install other peoples' hacks.
#44443 - 01/11/2001 12:18
[Re: tonyc]
Loc: Florida
Yes, Thank $DEITY for that!!
#44444 - 01/11/2001 19:29
ok glad to see at least one person out there agrees with me :)
i think i can sumarize the improvement as: move to the next playlist in the same folder without starting at the top of the playlist hierarchy
I'll try to describe the PJB: it has 3 folder levels, no more. but all 3 are displayed at the same time.
example:
Set: rock
Folder: Randy Newman
Disc: 12 Songs
I can move the cursor to the Folder level and LEFT/RIGHT to select different Folders in the Rock Set. Or I can move it to the Set level or the Disc level and sroll through my Sets and Discs respectively. In some cases the empeg would be faster, for example to move to the first entry listed at the top level takes 3 clicks (right, down, down) but to get to most of the lower level items i can get there faster with the PJB.
as far as the remote being dangerous but the visualization/info is not, i don't use the info screen much but i like to choose the "blank" visualization so i don't burn out my screen and other times i like to show people the different vis options, and it's such a hassle to switch between them without the remote it hardly seems worth it (down, right 4 times, down, then select group, then select vis). i know you can turn some of the vis's off using the .ini file but i couldn't get it to work, so i'm out of luck.
just want to reiterate, the unit is wonderful and i don't have buyer's remorse, but i feel it is lacking a few "idiot" features to make it simple and easy to move around in my music or change my display
thx for responding :)
joe
#44445 - 01/11/2001 19:43
[Re: jlira]
AH, okay, I see what you're saying.
A feature that is oft-requested for the empeg is a "next playlist" button.
The only problem is, when you're playing the whole player from the top, it has no concept of playlists. It flattens the structure and simply plays a shuffled/de-duped list of 1200 songs.
The other issue is, what if the song was in more than one playlist? When you hit Next Playlist, which of the several possible Next Playlists should it choose for the next one?
#44446 - 01/11/2001 21:17
[Re: jlira]
Loc: Dallas, TX
I know this is besides the point, but why are you afraid of your screen burning out?
Sean
#44447 - 01/11/2001 21:57
[Re: Terminator]
Because phosphor burn really happens on VFD displays.
I left "now and next" up on my Mark1 nonstop for a few weeks and now the timecode portion of the screen glows slightly more dimly than the rest of the screen.
It's very faint and you can hardly notice it unless there is a visual up with large areas of flat color such as Caledonian or Image Pan. But it is there.
#44448 - 01/11/2001 22:01
Loc: Dallas, TX
Yes I know that, but from what I understand, he wants the screen completely blank unless he has the menu pulled up. I usually just leave a visual running and have info:transient selected now.
Sean
#44449 - 01/11/2001 22:53
[Re: Terminator]
i read in another thread that it happens, and when it happens to me, the unit wil be effectively dead so i want to postpone it as long as possible. i keep dimmer down to 10-40% and no vis on most of the time for this reason
#44450 - 01/11/2001 23:02
[Re: jlira]
Loc: Dallas, TX
The display will not burn in unless it has some bit of text or numbers up on it for a long time. As long as a visual is running that is fairly dynamic, you won't have a problem. You should turn the screen up! Its a cool screen, you should enjoy it! I have had my player for a year now and haven't had a problem with screen burn in at all. Maybe others can comment on this, but I think that dimming the screen and turning off visuals entirely is an unnecessary precaution.
Sean
#44451 - 01/11/2001 23:29
[Re: Terminator]
if the screen get too bad can't we just replace it anyway ? I know someone on here did that when their screen was broken
#44452 - 01/11/2001 23:36
[Re: msaeger]
Loc: Dallas, TX
Yes it can be replaced, it will just cost some money to do so. :-)
Sean
#44453 - 01/11/2001 23:53
[Re: Terminator]
but i want to be using this thing for years, and if it's EOL now, i doubt i will be able to get spare parts or repair in 2-3 years. just my assumption, i would love to be wrong though :)
