#43768 - 25/10/2001 14:07 Changing config.ini?
alear
Loc: Montana, USA, Bozeman
I am trying to change my config.ini file to remove the timecodes/notify options. I couldn't get empegTaxi to work this time around (not sure why because its been very good in the past). Is there a text editor on the empeg? I didn't see vi.
Thanks,
Alex Lear
#43769 - 25/10/2001 14:14 Re: Changing config.ini? [Re: alear]
You can now change your config.ini in Emplode version 2. Check the FAQ at riocar.org for details.
#43770 - 25/10/2001 14:33 Re: Changing config.ini? [Re: alear]
bonzi
Either follow Tony's advice (easier), or use sed, which is included in developer image
sed -e'/pattern-in-a-line-to-delete/d' config.ini > c
mv c config.ini
#43771 - 25/10/2001 15:06 Re: Changing config.ini? [Re: bonzi]
alear
Great, thanks guys!
Alex Lear
