#42767 - 19/10/2001 20:01 Emplode Sync error
94cobra
Whenever I try and sync Emplde fails. It gives this message. Syncronise failed while writing player configuration. Connection timed out(error 0x8004003e)
It stop the process at this point. I have noticed that if you change the config data and sync that it does indeed change the data on the player. Close and open Emplode agian and the data is changed. It will also upload songs. But with the same error.
Proud Owner of MK2 080000558 - 18gb Blue
Sonic Blue 03 Cobra Vert Owner!!!
#42768 - 19/10/2001 23:40 Re: Emplode Sync error [Re: 94cobra]
alex25
Loc: Switzerland
I have the same problem, but only if I sync over USB. Ethernet works fine.
#42769 - 19/10/2001 23:45 Re: Emplode Sync error [Re: alex25]
dionysus
Loc: San Francisco, CA
...Mine was with ethernet..
-m
This space used in memory of the victims from 09/11/01
#42770 - 20/10/2001 03:19 Re: Emplode Sync error [Re: dionysus]
Hopefully, FITNR.
#42771 - 20/10/2001 07:29 Re: Emplode Sync error [Re: alex25]
94cobra
Yuo are correct. The ethernet works fine. Thanks.
#42772 - 20/10/2001 09:42 Re: Emplode Sync error [Re: 94cobra]
ineedcolor
Loc: Windsor, Ontario Canada
I have seen the same error as well. It has happened every time I upload new tunes to my player over USB (three so far). It doesn't seem to affect the upload however....
John
Technoweenie
12 GB Blue / Grey MK II
#42773 - 22/10/2001 13:18 Re: Emplode Sync error [Re: 94cobra]
pache
Loc: Switzerland
I find the same problem on Mark I, over serial or USB.
I don't know how to fix it.
Daniel
Mark I, 10+30Go
Daniel Mk1 40go and MK2 30go
#42774 - 22/10/2001 13:47 Re: Emplode Sync error [Re: 94cobra]
falcos
I also get the same error with USB - but fortunately the upload went through ok.
#42775 - 22/10/2001 18:02 Re: Emplode Sync error [Re: falcos]
morrisdl
Loc: Rochester, NY USA
Ditto - incase you are counting effected parties
-Doug
Mk2-12G Blue (Now A/R Green)
#42776 - 23/10/2001 15:27 Re: Emplode Sync error [Re: morrisdl]
srhodes
Loc: Derbyshire, UK
I get the same over USB. I have to reboot my machine before I can load emplode again otherwise I get a message telling me I have a wrong cookie session.
I've also noticed that when I delete tracks, they are still there on the player but not in the playlist section of emplode but you can still find them using search or looking in the new areas of emplode. I seem to have to do a couple of deletes and synchs before they actually go.
___________________________
Steve - 18GB Mk II Sssmokey
Steve
2x80GB Mk II with Illuminated buttons
