#42756 - 19/10/2001 16:36 connection timed out
bamboo
I am using a Mk I with 2.0 and I get connection timed out all the time. I can upload one song at a time (most ofthe time) but if I try to upload more than one song or if I try to create one of the wendy filter, I get a connection timed out after about 1.5 second. Then I can't do anything until I close Emplode and unplug the empeg.
I love 2.0 so far but without the ability to upload songs it doesn't help. Has anyone had this problem with their Mk I?
Thanks.
John
#42757 - 19/10/2001 16:40 Re: connection timed out [Re: bamboo]
Enable logging in emplode, then zip up the log and send it to bugs@empeg.com.
#42758 - 20/10/2001 08:04 Re: connection timed out [Re: bamboo]
I get the same thing on a MK2a. USB doesn't see a player, or can't connect. If it does connect, I try to resynch the DB and it times out, or it times out using serial.
#42759 - 21/10/2001 05:56 Re: connection timed out [Re: bamboo]
Henno
Loc: Meije, Netherlands
How many connects (serial, usb, ethernet) are you using? When I'm using emplode with all three activated in the tools menu, it falls over frequently during syncs. With only one open, it appears to work without problems. Worthwhile to try, I think.
Henno
mk2 6 nr 6
#42760 - 21/10/2001 06:53 Re: connection timed out [Re: bamboo]
TommyE
Loc: NORWAY
I had the same think on my MKI with USB. The computer running WinXP.
Switched to one of my other computers running Win98SE, everything OK.
This happened with both USB and serial. Thing XP is the problem.
TommyE
#42761 - 21/10/2001 14:05 Re: connection timed out [Re: TommyE]
Nah - it's not OS. We're seeing a lot of "connection timed out" errors, under all flavours of Windows/connection method. Richard thinks he's fixed it, tho'.
#42762 - 21/10/2001 22:37 Re: connection timed out [Re: Roger]
TommyE
Loc: NORWAY
Good boy.
TommyE
