#42594 - 19/10/2001 03:12 Search by Track Problem
Dava
Loc: Bucks UK
Loaded 2.0b3 without problems.
I've had a few lockups on the player as reported by others, mainly when playing with Wendy filters. Emplode has been quite stable but I would like to have the option of a flags column so that I can easily see which Wendy flags are set for a particular tune without going to properties.
I have also had the horrible garbled bass on a tune which palyed fine in 1.03. (sounded like a 2KW amp feeding tranny speakers!!!).
The only unreported gripe is that if you have 2 artists with the same trackname ("Under the influence" by both Eminem and Chemical Brothers). When you select search by name and type U-N-D-E-R, you can see "Under the Influence (2)" appear in the display. Pressing OK on this in any of the modes (append,insert,replace) just adds one of the tracks to the playlist.
I would expect it to either add both or present a new dialog to choose which you want(preferred).
MK2 Home made smoked 32Gb S/n 090000949
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#42595 - 19/10/2001 03:24 Re: Search by Track Problem [Re: Dava]
It's supposed to add both. I just tried it and it works for me. Is there anything different about what you're doing?
#42596 - 19/10/2001 03:34 Re: Search by Track Problem [Re: Dava]
Yes, as Roger said, it should add both. Perhaps one is "Under the Influence" and the other "Under The Influence", or something? That would narrow down where the bug must be...
#42597 - 19/10/2001 04:11 Re: Search by Track Problem [Re: peter]
Dava
Loc: Bucks UK
Quite right peter!
Just looked in emplode and one was "The", the other "the". I guess it should still add both though ??
#42598 - 19/10/2001 04:22 Re: Search by Track Problem [Re: peter]
Dava
Loc: Bucks UK
This new version of emplode is horrible! It makes it so easy to see that a lot of my tags have missing track nos, years, wrong case etc. The old version made this much harder, this must be a bug!
I know what I will be doing this weekend...
find The, replace with the
find On, replace with on
Joking aside, I don't know which I like more, emplode or the new player. Top notch chaps.
#42599 - 19/10/2001 04:41 Re: Search by Track Problem [Re: Dava]
Yes, it should. It's a bug.
