#41843 - 17/10/2001 12:44 clock display in 2.0b3
trevorp
Loc: Ft Lauderdale, FL
The clock display on the Track screen is only in 24hr format, no matter what I choose. Now, I can figure it out, but some of my passengers may not be able to do the math.
edit: I am using the developer image, if this helps.
-Trevor
Mk 2, Green 12GB, Tuner 080000349
Edited by trevorp on 17/10/01 09:39 PM.
-Trevor
Mk 2, Green 12GB, Tuner, 2.0b11, 080000349
#41844 - 17/10/2001 12:46 Re: clock display in 2.0b3 [Re: trevorp]
Hmm. In five minutes, I'll see if mine does the same thing.
#41845 - 17/10/2001 12:58 Re: clock display in 2.0b3 [Re: trevorp]
Hmm, works fine for me. Anyone else?
#41846 - 17/10/2001 13:19 Re: clock display in 2.0b3 [Re: tfabris]
synergy
Showing 12 hr format here....
#41847 - 17/10/2001 13:22 Re: clock display in 2.0b3 [Re: trevorp]
schofiel
You need a better class of passenger!
#41848 - 17/10/2001 13:26 Re: clock display in 2.0b3 [Re: tfabris]
phaigh
Nope, I get 24h clock no matter what.
Process:
Settings -> Clock Format -> 12 hour
Settings -> Timecode -> Clock
Clock appears, but is in 24 hour format.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#41849 - 17/10/2001 13:30 Re: clock display in 2.0b3 [Re: phaigh]
synergy
Doh! You're right...
The VISUAL clock shows 12 hour format, but the timecode clock does NOT. It seems to be locked into 24.
#41850 - 17/10/2001 13:31 Re: clock display in 2.0b3 [Re: schofiel]
trevorp
Well, I knew that, but I figured it's easier to fix the time format than to find new friends...
-Trevor
Mk 2, Green 12GB, Tuner, 2.0b3, 080000349
-Trevor
#41851 - 17/10/2001 13:37 Re: clock display in 2.0b3 [Re: synergy]
phaigh
Groovy!
I get exactly the same!
Did you notice how the individual numbers appear to move when the ':' character comes and goes?
Weird!
Paul.
#41852 - 17/10/2001 14:54 Re: clock display in 2.0b3 [Re: synergy]
Yeah, I was checking the visual as well. I never use the Info screen clock (always on countdown or elapsed/remaining).
If none of the alpha folks have put that into the internal buglist yet, I'll do it now.
#41853 - 17/10/2001 14:58 Re: clock display in 2.0b3 [Re: tfabris]
Okay, it's on their internal bug list. Case closed. NEXT?
#41854 - 18/10/2001 03:52 Re: clock display in 2.0b3 [Re: tfabris]
debauch
Loc: West Midlands, England
OK. I'll be picky. When time format is set to 24 hour, the analogue clock still displays a 12 hour face.
Hmm. Sounds trivial, but I actually like a 24 hour analogue clockface..
Nicholas.
18GB red s/n 080000299, original pos'n 8724. Reproduction of this post is not permitted.
-- 18GB red s/n 080000299
#41855 - 18/10/2001 04:47 Re: clock display in 2.0b3 [Re: debauch]
trevorp
Wow, and I was worried about my passengers not being able to do the math. Imagine them trying to figure out where "the little hand" is pointing to on a tiny clock like that.
-Trevor
-Trevor
#41856 - 18/10/2001 05:31 Re: clock display in 2.0b3 [Re: phaigh]
That's deliberate -- it's dithering the numbers. It alternates the dither, to reduce screen burn-in.
#41857 - 18/10/2001 05:35 Re: clock display in 2.0b3 [Re: debauch]
You must be very rarely satisfied then! I vaguely remember seeing a 24h analogue clockface once, but I can't remember where (Crewe Station?).
The Fitzwilliam Museum in Cambridge has a longcase clock showing French Revolutionary time: 10 hours in the day, 100 minutes in the hour. (As Eric Hobsbawm put it, the only lasting effect of the French Revolution was metrication.)
