#39660 - 27/09/2001 11:02 Error after synch
SE_Sport_Driver
After a sync, I got this message....
The synchronisation process failed during stage 10:
Player error 0xffffff92
32GB Mk. II in a WRX
Detroit, MI USA
www.PfeifferBeer.com
#39661 - 27/09/2001 11:43 Re: Error after synch [Re: SE_Sport_Driver]
Dearing
Loc: Florida
From Memory Stage 10 is rebuilding the music database? Just try to synch again.
Failing that, email support. (Sorry, glib )
_~= Dearing =~_
_~= Dearing =~_
#39662 - 27/09/2001 12:01 Re: Error after synch [Re: Dearing]
Greetings!
There is also a handy table of sync error codes around here somewhere. I am just too busy to search at the moment... I think Roger has it posted somewhere...
Paul G.
SN# 090000587 (96GB Smoke)
#39663 - 27/09/2001 12:10 Re: Error after synch [Re: pgrzelak]
mtempsch
Right here, as linked in the FAQ
#39664 - 27/09/2001 12:22 Re: Error after synch [Re: mtempsch]
Dearing
Loc: Florida
Yeah, OK. At least I was close. Anything after Stage 9 shouldn't be a big problem. just make another change and try another synch. I guess if it happens a lot, it's a bigger problem.
Jason
_~= Dearing =~_
_~= Dearing =~_
#39665 - 27/09/2001 13:59 Re: Error after synch [Re: SE_Sport_Driver]
SE_Sport_Driver
hmmm seems fine now. I am at about 500mb free out of 32GB.... when should I start to use caution when adding songs?
Detroit, MI USA
#39666 - 28/09/2001 06:45 Re: Error after synch [Re: SE_Sport_Driver]
Dearing
Loc: Florida
Caution when adding songs? As Emplode now creates the playlists before uploading the songs (it does do this now, right?), and you're nowhere near the DB limit, what do you mean caution?
I think Emplode has a good grasp of how much free space your player's got, so when it says it's full, stop. .
Or is there some other limitation I don't know about?
_~= Dearing =~_
_~= Dearing =~_
#39667 - 28/09/2001 10:11 Re: Error after synch [Re: Dearing]
I think Emplode has a good grasp of how much free space your player's got...
Heh. That's a good one. It's not actually that accurate. It should be less than 500Mb adrift, though.
