#38259 - 07/09/2001 19:29 displayserver on MKI?
bamboo
Can DisplayServer work on MKI or just MKII?
Also does anyone have Tony's Logo Editor anymore? His site isn't working.
Thanks.
John
MKI and proud of it (if DisplayServer works that is)
#38260 - 07/09/2001 19:32 Re: displayserver on MKI? [Re: bamboo]
Displayserver will probably run on a Mk1, but it won't do any good as it's ethernet-only and Mk1's don't have ethernet.
My ISP is screwing me over with regard to my web site. Temporarily you can find it at http://pweb.jps.net/~tfabris until things settle and then it's be at a new address (grr...)
BOYCOTT EARTHLINK !!!!
#38261 - 07/09/2001 19:43 Re: displayserver on MKI? [Re: tfabris]
bamboo
There is no work around for displayserver then? That sucks.
That is the one thing I want to do with my MKI (besides play music).
John
#38262 - 07/09/2001 22:21 Re: displayserver on MKI? [Re: bamboo]
What sort of work-around would you like? Displayserver is a web server running on the empeg. Last I heard, web servers required some kind of a network. If you don't have a network connection, what's the point of having a web server?
Now, it was rumored that it might be possible (with a LOT of work) to figure out how to get a PPP connection running over USB. But I never saw it come to light.
If the only thing you want to do is copy files back off the empeg, then there is a usb-only solution for you, but it's not the same as displayserver.
#38263 - 08/09/2001 01:03 Re: displayserver on MKI? [Re: tfabris]
Derek
Loc: NRW, Germany
Or you could run SLIP over the serial port. You would have to get this running and have it connected to a suitable host/router, but it is all possible. Anything is possible if you are determined enough If you look here there is an example of someone running a web server on a PIC!! and it connects directly to a router over a SLIP connection. If someone can do that with a PIC then it should be easy with an empeg!!
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 6GB blue)
#38264 - 15/09/2001 13:46 Re: displayserver on MKI? [Re: tfabris]
bamboo
What is the USB solution to copy files?
John
#38265 - 15/09/2001 17:48 Re: displayserver on MKI? [Re: bamboo]
It's in the FAQ section of this BBS under the heading "Can I copy MP3 files back onto my PC?"
