#374221 - 27/12/2023 16:00 Making new images for Image Pan Visual?
The FAQ says:
You can replace the graphic used in the Image Pan visual. This is done with the EmRAWerter utility. The file must be RLE compressed, and then uploaded to the player using one of these methods. The file to be edited is /empeg/lib/visuals/escher.raw. Examples of modified Image Pan files can be found here.
But the link to sample images no longer works, and the EmRAWverter utility also isn't there now. Anyone have a copy, or more information on the actual image format required?
#374229 - 01/01/2024 23:36 Re: Making new images for Image Pan Visual? [Re: mlord]
Faolan
http://www.riocar.org/FAQ/7.html#213 has been updated to fix download links. Fixed up various links to Hijack around the site as well.
#374230 - 02/01/2024 03:44 Re: Making new images for Image Pan Visual? [Re: mlord]
Thanks!
