Page 18 of 18 < 1 2 ... 16 17 18
#372504 - 18/12/2019 21:40 Re: BlueGigaEmpeg [Re: tfabris]
Yeah, it was totally spur of the moment, because the Empeg usually lives on my desk at work. One of my co-workers brought in all his soldering stuff and set it up to repair some Christmas ornaments with bad capacitors on his lunch break. Since it was there and all setup, I figured I would go ahead and do the internal wiring for the BlueGigaEmpeg. I never got back to it today as things got busy at work, so I'll let you know when I finish up.
#372508 - 19/12/2019 14:33 Re: BlueGigaEmpeg [Re: tfabris]
Anyone have a good way to clean up the work after fluxing and soldering?
I just use Q-Tips (cotton swabs) doused in alcohol. If the joints have rough bits, I smooth them over with more solder/heat (and FLUX!) first.
#372510 - 19/12/2019 17:56 Re: BlueGigaEmpeg [Re: mlord]
Yeah, I have tried Q-tips as well, but it inevitably leaves little cotton strands all over my work, so I have to go scanning for them. smile
#372511 - 20/12/2019 14:06 Re: BlueGigaEmpeg [Re: tfabris]
gmarsh
Loc: NS, Canada
Day job method:
I usually give everything a good soak in good flux remover (eg, MG Chemicals 413B) using a brush or Q-tip to get any burnt or big 'goobers' of flux loose. Then dab off as much of the flux remover as possible using a paper towel, and give a second soak in flux remover.
Then finish with a wash in deionized water, finally blow the water off with compressed air.
#372512 - 20/12/2019 21:41 Re: BlueGigaEmpeg [Re: gmarsh]
And.. how is the RAM upgrade? laugh
#372513 - 22/12/2019 04:28 Re: BlueGigaEmpeg [Re: mlord]
gmarsh
Loc: NS, Canada
The Empeg (and RAM) is current sitting in a box in my basement.
Just moved into a new house today smile Still got a bunch of moving and setup and other stuff to get up to, when that's done I'll do the RAM upgrade and try out the SATA adapter.
