#364095 - 01/06/2015 12:45 Getting forced back into it...
mtempsch
It's been wayyyy to long since I last updated HiJack or loaded any new music onto the player - despite it being in daily use in my car.
Now I'm being forced to - car was broken into; smashed passenger window, bent in and took what they could reach - including my empeg... frown
Keeping an eye on the local trading/auction sites, but doubt it'll show up, most likely it's in a dumpster or a ditch somewhere.
So, time to break out one of the two spares and getting it updated/configured/loaded, and/or actually getting my act together repairing my main unit (mem. expansion board, smoked buttons w/lights, alu fascia and knob) that's collecting dust due to (AFAICT) busted fuse[s] after a misaligned display connector reconnection.
Since they're only 20 and 10+30 GB in capacity - anyone have a link to a known working IDE->SATA adapter? Recall there being issues with some working, others not.
A quick Look at one of the bigger Swedish stores shows no IDE 2.5" drives, SSD or spinners. Will look at a few more places and talk to the guys at work that are more current on storage though.
Or is IDE -> SD possibly easier?
Edited by mtempsch (01/06/2015 13:10)
#364096 - 01/06/2015 13:13 Re: Getting forced back into it... [Re: mtempsch]
I'd be tempted to go with this IDE to compact flash adapter or something similar.
#364098 - 01/06/2015 14:52 Re: Getting forced back into it... [Re: DWallach]
IF it will work with the empeg motherboard. Looking at the reviews, it might be a little bit picky about motherboard compatibility.
Cost per gigabyte seems to be comparable to an SSD, so is there a big advantage to this?
#364101 - 01/06/2015 16:21 Re: Getting forced back into it... [Re: mtempsch]
I've got a Transcend PATA SSD in my empeg. See http://uk.transcend-info.com/Products/No-418. Specifically see if you can find the SKU numbers for sale where you are:
- TS32GPSD330 (32GB)
- TS64GPSD330 (64GB)
- TS128GPSD330 (128GB)
In the UK, Pixmania have them, sold by MemoryC who -- I think -- I got mine from. Amazon also seem to have them.
#364104 - 01/06/2015 22:26 Re: Getting forced back into it... [Re: mtempsch]
I'm picking this one up this weekend while I'm back in the States for a wedding. I can let you know if it works by early next week.
I imagine I'll have to use double sided foam tape instead of screws to mount, but the SSD is so light, I'm sure it will be fine.
#364105 - 02/06/2015 00:11 Re: Getting forced back into it... [Re: mtempsch]
Yeah, forget about IDE-to-SATA converters --> too much unknown there, some work, some don't.
The straight PATA SSDs (Kingspec or Transcend) seem to be the ticket. IDE-to-CF adapters are also very good, since CF is just IDE in a different form factor.
#364106 - 02/06/2015 06:24 Re: Getting forced back into it... [Re: mtempsch]
Sadly I have to report that when I tried what should have been an equally cunning wheeze, putting a 128GB PATA SSD in a Rio Karma, it didn't really work. Props to Kingspec for even making SSDs in that somewhat unusual form-factor, but the Karma firmware just doesn't deal with song databases that big -- not even when they're built on the PC and copied on over Karma's pseudo-mass-storage interface frown
#364107 - 02/06/2015 13:14 Re: Getting forced back into it... [Re: peter]
mtempsch
That would have been... good smile
Guess you'd need a memory expansion board for the Karma - and a place to put it (assuming it could handle more RAM at all)
#364108 - 02/06/2015 13:19 Re: Getting forced back into it... [Re: Roger]
mtempsch
Many thanks for those - simplified searching... Found that Pixmania is in Sweden too, but looking at prices I think I'll temporarily go with the drive it's got and scout around a bit more before buying.
#364109 - 02/06/2015 13:29 Re: Getting forced back into it... [Re: mlord]
mtempsch
Yes. leaning more and more towards a PATA SSD.
But if one were to go the CF route, what sort of speed would be required, or would pretty much anything on the market today be fast enough?
#364110 - 02/06/2015 14:45 Re: Getting forced back into it... [Re: mtempsch]
Pretty much any CF card is more than fast enough for the empeg. The only place one might ever have a speed issue, is when installing new audio files during a "sync".
One of my players has a pair of really old ADATA 16MB CF cards, which can be read much faster than a mechanical drive ever could inside the empeg. But writing bulk data to them is really, really, really, really, really, SLOW. So dumping new tracks to that player takes 10-30X as long as it did with the old mechanical drive.
My other players have more modern CF cards, which support 5-10MBytes/sec write speeds. Much better.
Note that the network interface, used for installing tunes, operates at only about 1MB/sec.
