#357790 - 07/03/2013 10:58 Mains voltage (quality) monitor?
julf
Can anyone recommend a computer-readable (IP, USB, RS-232) mains voltage (quality) meter? I have long periods of no light bulbs burning out in the house, and then suddenly several at the same time, indicating transients or overvoltages....
#357793 - 07/03/2013 13:31 Re: Mains voltage (quality) monitor? [Re: julf]
A ("smart") UPS?
#357794 - 07/03/2013 13:35 Re: Mains voltage (quality) monitor? [Re: mlord]
For transients/spikes, you could miss them regardless -- dunno how often the logging in a UPS records samples for the PC.
But ditto for a voltage meter. They take/report samples a few times per second, but a spike/transient could still be missed.
The $40 UNI-T UT61C meter I got off eBay (China) has serial output for a PC, and can keep min/max readings. Dunno if it would catch brief spikes or not. Sampling interval is 3/second I think. Would need to supply it with power though -- the batteries wouldn't last long enough, and the meter has auto-shutdown as well (to save batteries) -- kinda ruins it for this use. smile
There are other, similar meters from UNI-T with differing features / capabilities. Good bang for the buck.
Edited by mlord (07/03/2013 13:37)
#357795 - 07/03/2013 13:39 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
A ("smart") UPS?
Hmm... Hadn't thought about that!
I have an APC Black Smart UPS keeping the house control computer up, guess I need to look at what it sends!
#357796 - 07/03/2013 13:56 Re: Mains voltage (quality) monitor? [Re: julf]
julf
Forget that one - as soon as I plug in the RS-232 cable, the UPS switches off, taking down the computer...
#357797 - 07/03/2013 15:15 Re: Mains voltage (quality) monitor? [Re: julf]
Lovely. USB-connected UPSs do have an advantage there.
    APC      : 001,045,1087
    DATE     : 2013-03-07 12:14:54 -0500
    HOSTNAME : zippy
    VERSION  : 3.14.10 (13 September 2011) debian
    UPSNAME  : zippy_UPS
    CABLE    : USB Cable
    DRIVER   : USB UPS Driver
    UPSMODE  : Stand Alone
    STARTTIME: 2013-03-04 22:37:17 -0500
    MODEL    : Back-UPS RS 900
    STATUS   : ONLINE
    LINEV    : 125.0 Volts
    LOADPCT  :   9.0 Percent Load Capacity
    BCHARGE  : 100.0 Percent
    TIMELEFT :  94.2 Minutes
    MBATTCHG : 5 Percent
    MINTIMEL : 4 Minutes
    MAXTIME  : 0 Seconds
    OUTPUTV  : 120.0 Volts
    SENSE    : Medium
    DWAKE    : 000 Seconds
    DSHUTD   : 000 Seconds
    LOTRANS  : 097.0 Volts
    HITRANS  : 139.0 Volts
    RETPCT   : 000.0 Percent
    ITEMP    : 29.2 C Internal
    ALARMDEL : No alarm
    BATTV    : 27.6 Volts
    LINEFREQ : 60.0 Hz
    LASTXFER : Low line voltage
    NUMXFERS : 0
    TONBATT  : 0 seconds
    CUMONBATT: 0 seconds
    XOFFBATT : N/A
    SELFTEST : NO
    STESTI   : None
    STATFLAG : 0x07000008 Status Flag
    MANDATE  : 2006-07-04
    SERIALNO : QB0628132519
    BATTDATE : 2006-09-10
    NOMOUTV  : 120 Volts
    NOMINV   : 120 Volts
    NOMBATTV :  24.0 Volts
    NOMPOWER : 540 Watts
    FIRMWARE : 9.o1 .D USB FW:o1
    END APC  : 2013-03-07 12:15:22 -0500
#357799 - 07/03/2013 15:28 Re: Mains voltage (quality) monitor? [Re: julf]
Are you using the cable that came with the UPS? I seem to recall that some of them are only-kinda-standard.
#357801 - 07/03/2013 15:36 Re: Mains voltage (quality) monitor? [Re: Roger]
julf
Yes, using cable that came with the UPS - but I thought the special cables were only for the pre-smart UPSes that used some strange signalling instead of sending ascii text.
#357802 - 07/03/2013 15:37 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
Definitely. There was a reason I got mine cheap :-/
#357804 - 07/03/2013 15:41 Re: Mains voltage (quality) monitor? [Re: julf]
I think they still use one of the RS232 control lines for "turn off now."
Need to have the serial port configured correctly and all before plugging in that cable -- eg. by having apcupsd all set up and running on the computer. Not a bad thing to do regardless, as it'll enable controlled shutdown/restart on battery exhaustion during power failures too.
#357805 - 07/03/2013 15:50 Re: Mains voltage (quality) monitor? [Re: julf]
Speaking of which. I recently installed a CyberPower UPS for the MythTV box here, and am quite impressed by it all. Everything works in testing: auto shutdown, restart on power return, etc.. I got one of the "PFC" models with "pure sinewave output" (gotta verify that on a scope someday..). It is much more power efficient on AC than the APC units we've had, enough so that we'll probably even notice the savings on our electricity bills.
Very easy to set up in Linux. I'm hoping it will be more reliable long-term than the APC UPS we've tried here over the years. Those all seem to die with non-battery issues after 3-6 years.
The one whose stats I posted above is the last of the APC UPS models for me. It has had one battery replacement, and seems to still be good. But the transformer has been making crackling noises for the past 18 months, and I'm slightly worried that this might turn into something worse. Thus far it hasn't.
#357811 - 08/03/2013 08:40 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
Now I have visions of my electrical cabinet catching fire in the middle of the night frown
#357813 - 09/03/2013 11:22 Re: Mains voltage (quality) monitor? [Re: julf]
While you are sorting out the UPS signaling/software, do not have the computer plugged into the UPS. Plug the computer directly into wall power.
#357814 - 09/03/2013 12:54 Re: Mains voltage (quality) monitor? [Re: K447]
julf
Good advice - and that was my plan, but I have to wait until a suitable chance to take down the system again to switch it over to the regular wall plug.
#357819 - 10/03/2013 11:14 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
But... But... How do you ensure apcupsd is running when you turn on the UPS - if the computer on which apcupsd is running is powered by the UPS?
#357820 - 10/03/2013 15:16 Re: Mains voltage (quality) monitor? [Re: julf]
My (now fuzzy) recollection is that the 'serial port' on older APC units accommodated both serial communications and direct wire voltage level signaling.
Some pins were used for simple RS-232 data (send and receive), other pins were used with DC voltages to signal 'on battery power' and 'turn the UPS off', and perhaps some other functions. I seem to recall that there was no hardware flow control or handshaking for the serial data.
The special APC cable separated the functions so the 'serial data' mode would work with a normal PC serial port. I do not recall if there was a different APC cable for using the voltage signal method.
APC tweaked the port configuration over the years, so not all models had the exact same port configuration. And I think there were different versions of the serial cable too.
#357821 - 10/03/2013 15:41 Re: Mains voltage (quality) monitor? [Re: K447]
julf
Yes, looking at the apcupsd web pages shows there was quite a variety of cables... Until now I was convinced the cable I was using was the original cable that came with the unit, but I can't see any product/manufacturer name or product number on it, and it is supposed to be embossed into the plastic.
#357823 - 11/03/2013 01:45 Re: Mains voltage (quality) monitor? [Re: julf]
[quote=mlord]But... But... How do you ensure apcupsd is running when you turn on the UPS - if the computer on which apcupsd is running is powered by the UPS?
You don't. Instead just ensure apcupsd is up and running (and all configured) before plugging in the serial cable. smile
#357824 - 11/03/2013 07:47 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
Sure - what I am concerned about is how vulnerable the system becomes. Will everything come up in the right sequence when the power comes back? I am afraid the answer will be "usually"... smile
#357825 - 11/03/2013 12:25 Re: Mains voltage (quality) monitor? [Re: julf]
You can check the cable pin connections using a multi-meter and a thin paperclip. If it is a standard serial cable, the meter will tell you.
Without checking the Interwebs, I recall that the genuine APC 'serial cable' uses only a few pins, several pins will have no connection.
#357826 - 11/03/2013 13:59 Re: Mains voltage (quality) monitor? [Re: julf]
Oh, I get the point now. smile
Yes, things do work 100% in the correct sequence.
But only if the correct UPS cable is used!
Which means.. the reason it switched off when you plugged it in earlier can only be that the wrong cable was used. Bummer.
#357827 - 11/03/2013 15:40 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
Yes, just verified I have the wrong cable. Guess I need to make a new one.
#357873 - 20/03/2013 15:58 Re: Mains voltage (quality) monitor? [Re: mlord]
julf
Got a Digitek DT-4000ZC for s similar price. The good thing is it does not turn off automatically when the RS-232 port is connected.
So far I have learned that the mains voltage drops 6 V when I turn on the oven smile
#357875 - 20/03/2013 16:10 Re: Mains voltage (quality) monitor? [Re: julf]
Looks like a good deal. Oh, and I've just discovered that I can disable the "turn off automatically" feature on mine when required -- press and hold "blue" button while turning it on. smile
Cool.. err.. hot!
