#357267 - 24/01/2013 08:33
Player crash when uploading playlists
Hi, I'm using v3.00b11 with the latest hijack kernel (I also applied the max_fid v7 patch) with my 500GB drive, and till now everything has been good. I've uploaded ~26K tunes successfully, but now whenever I try to add additional tunes/playlists, the player crashes.
On the "Uploading playlists" task, I'm getting 0x800400d3, which AFAIK is a result of the crash. Is this correct?
On the player screen, I'm getting "0000.0 sigkill err".
Looking at the terminal, I see the following (it ends with me going to the shell):
Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000 Adding Swap: 16028k swap-space (priority -2) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hda4 is mounted. show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... show_message("0000.0 nomem err") VM: do_try_to_free_pages failed for player... no room for private writable mapping error: -12 /sbin/fsck.ext2: Memory allocation failed while retrying to read bitmaps for /de v/hda4 EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended show_message("0000.0 segfault err") player(74): user memory violation at pc=0x020f1020, lr=0x00000000 (bad address=0 x00000000, code 0) pc : [<020f1020>] lr : [<00000000>] sp : bdfffb80 ip : 00000000 fp : bdfffbd8 r10: 000555d0 r9 : 0004f380 r8 : 00040c70 r7 : 0000aac0 r6 : 0000aab0 r5 : 0000aaa0 r4 : 0000aa90 r3 : 0000aa80 r2 : 00000010 r1 : 022466dc r0 : 00000000 Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user Control: C0F3517D Table: C0F3517D DAC: 00000015 Function entered at [<020584f4>] from [<02058f28>] r10 = BDFFFC88 r9 = 02227390 r8 = BDFFFBFC r7 = 00000001 r6 = 00000004 r5 = 022466A8 r4 = 00000000 Function entered at [<02058eac>] from [<02058ab4>] r10 = 0001D4C0 r8 = 02227470 r7 = BDFFFC88 r6 = 02227650 r5 = 022274F0 r4 = 022466A8 Function entered at [<02058934>] from [<02057d40>] r7 = 00000005 r6 = 02227648 r5 = BDFFFCDC r4 = BDFFFCD8 Function entered at [<02057c88>] from [<020dcff0>] r6 = 0000000C r5 = 00000003 r4 = 02227464 Function entered at [<020dce54>] from [<020581b8>] r10 = 02227648 r8 = 02227670 r7 = 0000000D r6 = 00000029 r5 = 02227464 r4 = 02227390 Function entered at [<02058144>] from [<020dead4>] r10 = 020DEA00 r8 = 0000340E r7 = 00000080 r6 = 0000000E r5 = BDFFFD4C r4 = 02227390 Function entered at [<020dea9c>] from [<020dea8c>] r5 = 021D40FC r4 = 02227390 Function entered at [<020dea00>] from [<0211c970>] r5 = 022273A8 r4 = BDFFFE40 Function entered at [<0211c8a8>] from [<0215334c>] r4 = 00000000 Function entered at [<02151ac0>] from [<0211c6ec>] r8 = 021E74CC r7 = 021E74B8 r6 = 020DEA00 r5 = 00000005 r4 = 00000000 Function entered at [<0211c63c>] from [<0215334c>] r5 = 00000000 r4 = 00000000 Function entered at [<bffffab0>] from [<bffffad0>] Function entered at [<fffffff4>] from [<02149030>] Function entered at [<e1a0c001>] from [<e91ba800>] Function entered at [<223ffff4>] from [<2240ff00>] show_message("0000.0 sigkill err") Unable to handle kernel paging request at virtual address 223ffff8 memmap = C0F34000, pgd = c0f34000 *pgd = 00000000, *pmd = 00000000 Internal error: Oops: 2 CPU: 0 pc : [<c00e6b70>] lr : [<c0019950>] sp : c0665f44 ip : c0665f00 fp : c0665f90 r10: 00000000 r9 : c0fa1160 r8 : 0000000c r7 : 00000000 r6 : 223ffff4 r5 : 22400000 r4 : e24cb004 r3 : 60000013 r2 : c0106284 r1 : 00000001 r0 : e24caff4 Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user Control: C0F3517D Table: C0F3517D DAC: 00000015 Process player (pid: 74, stackpage=c0665000) Stack: c0665f20: c0019950 c00e6b70 600000 13 c0665f40: ffffffff c0fa1178 c0fa01a0 c0664000 c0665fb8 00000000 c0011be0 000000 00 c0665f60: 00000000 00000000 c0665fb8 0000000f 00000000 00000000 00000000 0004f3 80 c0665f80: 000555d0 c0665fb4 c0665f94 c0012134 c0011984 c010497c 0000aaa0 0000aa b0 c0665fa0: 0000aac0 00040c70 00000000 c0665fb8 c000a0c8 c001205c 00000000 022466 dc c0665fc0: 00000010 0000aa80 0000aa90 0000aaa0 0000aab0 0000aac0 00040c70 0004f3 80 c0665fe0: 000555d0 bdfffbd8 00000000 bdfffb80 00000000 020f1020 20000010 ffffff ff Backtrace: Function entered at [<c0011978>] from [<c0012134>] r10 = 000555D0 r9 = 0004F380 r8 = 00000000 r7 = 00000000 r6 = 00000000 r5 = 0000000F r4 = C0665FB8 Function entered at [<c0012050>] from [<c000a0c8>] r8 = 00040C70 r7 = 0000AAC0 r6 = 0000AAB0 r5 = 0000AAA0 r4 = C010497C Code: ebfccaf3 e2440010 (e5961004) e1a035a1 e59f20cc Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Abnormal player termination Player received signal 11 Starting bash.
I think I'm hitting some kind of limit (memory etc.).
Any idea?
Thanks, Ury
#357271 - 24/01/2013 15:02
Re: Player crash when uploading playlists
[Re: ury]
Hopefully, Mark Lord or Roger will see this thread.
If they don't answer within a few days, just ping them with at private message and tell them to look at this thread.
#357272 - 24/01/2013 15:18
[Re: JBjorgen]
#357275 - 24/01/2013 17:58
[Re: ury]
Some variables to consider here, as possibilities: 1. 26,000 tunes is a lot. It's possible that, even with the MaxFid patch, you're hitting some kind of limit, such as database size. 2. 3.x alpha software was never finished and is still buggy. I stopped using it because of crashes like that (on a much smaller number of tunes), each crash would trash my FIDs and playlist structure when they happened. 3. Which software did you use to try to synch with your player? Did you use the 2.10 Emplode software? That's known to be buggy. You should be using Jemplode instead. If you can get the player back to a working state, see if a manual database rebuild fixes the issue temporarily, then, see if you can successfully upload a single tune into an existing playlist. Manual database rebuild instructions: http://www.riocar.org/modules.php?op=mod...;faqent=220#220
#357280 - 24/01/2013 21:14
Thanks guys! - I'm using emplode v2.00 (v2.10 keeps crashing). Where can I grab jemplode from these days?
- I'll revert to v2.01 to improve my odds.
- I've been building the database manually over and over, after each failed sync. The following sync fails when uploading a single playlist or tune.
- I'll look for maxfid clues on the forum. Thanks for the leads.
- If I enable the swap file from the shell (I *think* it's already enabled), will it remain enabled during sync? Should I disable it afterwards?
#357281 - 24/01/2013 23:09
[Re: ury]
jemplode is mirrored on RioCar.org here: http://riocar.org/upload/jemplode/Looks like jempeg.org is still borked.
#357282 - 25/01/2013 01:42
[Re: ury]
If you can work out how to keep swap enabled all of the time, I believe that would be best.
#357311 - 29/01/2013 19:35
[Re: ury]
I'm using emplode v2.00 (v2.10 keeps crashing). As far as I know, emplode 2.0x cannot work successfully with the 3.x alpha player firmware. And yeah, 2.1x is crashy. So yeah, try Jemplode. That might have been your only problem.
#357317 - 30/01/2013 06:51
As far as I know, emplode 2.0x cannot work successfully with the 3.x alpha player firmware. Wrong. I use 2.0x with 3.0alpha11. Yeah, it crashes sometimes, but I wouldn't call it "cannot work".
#357337 - 31/01/2013 16:04
[Re: Roger]
Why did I think it was required?
Hmmmmm.
Let me think....
OH! I KNOW!
It's because 3.0x Alpha supported OGG/FLAC, and in order to load OGG/FLAC you needed Emplode 2.1x. Gotcha.
#357342 - 01/02/2013 17:05
I think it would get the tag encoding wrong, as well. Old Emplodes wouldn't know that car-v2 is Latin-1 but car-v3 is UTF-8. So it won't do the Right Thing for non-ASCII characters.
#358378 - 28/04/2013 18:36
[Re: peter]
I'm having a similar problem. After some other problems with my car stereo which I finally got working again I came back to look at my Empeg, and to add some more music to it. It is an early MkII with 12MB of RAM and now has 2x256GB disks in it. Anyway it was fine with about 100GB of music but then I added a load more and now it boots up to a "0000.-1 segfault err" every time.
Any help would be most appreciated.
Here is the boot:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg55-hijack-v515 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Wed Jul 20 09:24:02 EDT 2011 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c0c00000: wrote ffffffff, read e28cc001 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 7, serial number 80000452) 12MB DRAM Command line: mem=12m Calibrating delay loop... 207.67 BogoMIPS Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is ffffffff 'ÿÿÿÿ' Tuner: loopback=0, ID=-1 show_message("Hijack v515 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005b80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 hdb: WDC WD2500BEVE-00WZT0, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xffff hda: WDC WD2500BEVE-00WZT0, ATA DISK drive hdb: WDC WD2500BEVE-00WZT0, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD2500BEVE-00WZT0, 238475MB w/8192kB Cache, CHS=30401/255/63, LBA48 hdb: WDC WD2500BEVE-00WZT0, 238475MB w/8192kB Cache, CHS=30401/255/63, LBA48 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c4 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: GB Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" kftpd: listening on port 21 khttpd: listening on port 80 player.cpp : 385:empeg-car 2.01 2004/07/06. ! tags.cpp : 61:Failed to open tags (0xc0041002). show_message("0000.-1 segfault err") player(8): user memory violation at pc=0x020e16c0, lr=0x0207cc44 (bad address=0x4056c000, code 0) pc : [<020e16c0>] lr : [<0207cc44>] sp : bffff7c0 ip : bffff7e0 fp : bffff7dc r10: 00000000 r9 : bffffc24 r8 : 00000000 r7 : 4056bff8 r6 : 4056c000 r5 : 02153559 r4 : 0000000a r3 : 00000030 r2 : 00000002 r1 : 02153550 r0 : 4056bff8 Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user Control: D033D17D Table: D033D17D DAC: 00000015 Function entered at [<020e1630>] from [<0207cc44>] r7 = BFFFFC60 r6 = 02153550 r5 = 0000000A r4 = BFFFFC60 Function entered at [<0207cbf4>] from [<0205642c>] r6 = 02135B80 r5 = 0214DA74 r4 = 00000000 Function entered at [<020560b0>] from [<0206189c>] r10 = 00000000 r9 = 02112594 r8 = 0214DA68 r7 = BFFFFC60 r6 = 00000000 r5 = 02174E90 r4 = 00006301 Function entered at [<020617c0>] from [<020322fc>] r7 = BFFFFD0C r6 = BFFFFD04 r5 = 0214F1AC r4 = 02174E80 Function entered at [<02032258>] from [<0200881c>] r6 = BFFFFD08 r5 = 0214F1A4 r4 = BFFFFD04 Function entered at [<020087e4>] from [<0202fcbc>] r5 = BFFFFD04 r4 = BFFFFD10 Function entered at [<0202fa0c>] from [<0202f758>] r10 = BFFFFEE4 r9 = 00000001 r8 = 0214DA68 r7 = BFFFFEE8 r6 = 00000054 r5 = BFFFFD78 r4 = BFFFFD78 Function entered at [<0202f718>] from [<020316bc>] r6 = 00000054 r5 = FFFFFFFF r4 = BFFFFD78 Function entered at [<02031464>] from [<020317ec>] r10 = 02031788 r9 = 00000000 r8 = 02112280 r7 = 00000000 r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64 Function entered at [<02031788>] from [<020c90c4>] r5 = BFFFFF64 r4 = 00000001 Function entered at [<020c8fe8>] from [<02000104>] r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000 r5 = 00000000 r4 = 00000000 Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only Abnormal player termination Player received signal 11 Starting player Timezone: GB Hijack: intercepting config.ini
Hodge
Hodge #080000452
#358390 - 29/04/2013 11:47
[Re: hodge555]
OK - I fixed it by doing the following: I ran the set_empeg_max_fid which I hadn't previously done. I ran the fidsift.sh program. Still no joy. I then deleted the contents of all the _0005 & 6 fids directories to get the contents back to about 15k tracks (120GB used). This then let the machine boot OK and rebuild the database and then jEmplode (v69) managed to re-sync OK.
I'm now going back and putting in what I think is missing and we'll see if it craps out again.
Hodge #080000452
#358452 - 01/05/2013 20:01
[Re: hodge555]
Ah well, maybe not quite fixed then. Appeared to be OK but with 18,000+ tracks it could create a database but no playlists and then gave me a memory error.
I'm taking some tracks off and see if it can survive OK on less tracks. A bit annoying when I have the 2x 256GB disks and can get less than 130GB on the machine...
Hodge #080000452
#358453 - 01/05/2013 21:09
[Re: hodge555]
A bit annoying when I have the 2x 256GB disks and can get less than 130GB on the machine... You do realize that this device was originally designed with I believe 2GB storage in mind, unless you wanted to go all out and put in the 6GB option. I mean, who in their right mind would need more than 6GB? It is miraculous that people are stuffing nearly 50 times as much storage into these little boxes as they were originally meant to hold. tanstaafl.
#358455 - 01/05/2013 21:53
Well, the issue is also something the empeg engineers couldn't easily address. The computing industry long ago decided to choose IDE, a notoriously shortsighted specification. The number of "limits" that have been hit on IDE, or a combination of IDE and BIOS is pretty silly. The 128GB limit is one of those, and no workaround existed when the empeg shipped.
SCSI was far better about these limits, but never had mass consumer adoption. And still had it's own set, but nowhere near the degree IDE did.
#358460 - 02/05/2013 00:04
[Re: drakino]
SCSI is no better than IDE. Both protocols have had to add extensions to increase the number of addressable units on a drive. The difference is that SCSI has had to do this three times thus far, whereas IDE only had to extend it once twice ("LBA", then "LBA48"). Other "limits" were PC BIOS, MS filesystems, and MS-Windows issues. And the IDE drives are not the issue here anyway.
The problems here are due to the in-memory database of the player software becoming too large for available memory (RAM).
#358465 - 02/05/2013 05:11
The problems here are due to the in-memory database of the player software becoming too large for available memory (RAM). But isn't it the case that trimming extra tag information allows for more songs to fit in the RAM? What actually goes into the in-RAM database?
#358467 - 02/05/2013 12:27
And the IDE drives are not the issue here anyway. Fair enough. I saw the 130gb and due to some other distractions thought it was drive size limits he was wanting to be better. Leave it to the geeky mindset to get distracted on the little details of why instead of how to address Hodge's concerns  SCSI is no better than IDE. Both protocols have had to add extensions to increase the number of addressable units on a drive. The difference is that SCSI has had to do this three times thus far, whereas IDE only had to extend it once twice ("LBA", then "LBA48"). Can you provide a citation on the SCSI side, because I am curious about this. My understanding is that also eliminating all the crappy BIOS limitations, SCSI's initial implementation in 1981 from the Shugart Associates System Interface specs had a 1GB limit. (Due to the 6 byte CDB allowing a 21 bit LBA). The 10 byte CDB introduced in 1987 bumped the LBA to 32 bit and to a 2TB limit. SCSI then jumped to LBA 64, bumping the limit to ~ 8 ZBI also thought IDE started with a 22 bit LBA, presenting a 2GB limit before LBA28 jumping it to 128GB. Also thought IDE didn't fully switch to LBA until the mid 90s, so not sure what limits were in place in the initial IDE standard.
#358485 - 02/05/2013 20:06
[Re: drakino]
SCSI 6, 10, 12, 16, 64. IDE CHS, 28-bit LBA, 48-bit LBA.
28-bit LBA was there in the first ATA-1 spec, alongside CHS. But I don't think all drives supported LBA from day-0.
The empeg Hijack kernel supports 48-bit LBA. The factory one didn't originally, but I dunno what's in the v3alpha kernels.
#358494 - 02/05/2013 21:49
SCSI CDB increases didn't always include LBA increases though. The ones that did are:
6 byte CDB = 21bit LBA 10 byte CDB = 32bit LBA 16 byte CDB = 64bit LBA
After the initial fixed CDB sizes, variable sizes came into play, I believe all using 64bit LBA.
Looks like the 22bit LBA was in the initial IDE spec, as an optional addressing scheme prior to ATA-1. I guess it all depends on where one defines the start of IDE, either back in 1986 with the first IDE drives showing up in PCs, or 1994 with the first ATA-1 standard drives.
#358495 - 02/05/2013 22:19
[Re: drakino]
There is no such thing as "22bit LBA" for IDE. Never has been.
"IDE" began with Compaq Computers doing weird stuff. "Standardized" IDE began with ATA-1, 28-bit LBA and CHS.
#358548 - 07/05/2013 18:54
My Empeg originally was the top spec model with 2x 18GB drives (and £1500!) and I had heard before that the issue was down to only having 12meg of RAM installed to actually address it all being the problem, and I agree it's quite a marvelous achievement in itself to be running as well as it is, I'm sure an M$ product wouldn't be, however I thought that was a memory problem for a single playlist and not the entire collection. Is there a way for instance to cheat the RAM allocation using disk cache as there is plenty of space available?
Hodge #080000452
#358557 - 08/05/2013 15:28
[Re: hodge555]
Is there a way for instance to cheat the RAM allocation using disk cache as there is plenty of space available? IIRC, you can create, and mount, a swap partition, but the player does its best to keep the disks spun down as much as possible. The consequence of a swap partition is that disks will never spin down. I'm not sure if the swapping would lead to disruption during playback...
#358578 - 09/05/2013 18:58
[Re: canuckInOR]
What's the most number of tracks someone has put on a 12meg Empeg and still had it work properly?
I seem to get to near 18,000 and it's OK but then I put a few more on (still less than 19,000) and it barfs with a "failed to open tags" again.
Hodge #080000452
#358579 - 09/05/2013 19:02
[Re: hodge555]
And out of interest, how many can one get on a 16meg (or more?) machine?
Hodge #080000452
#358764 - 23/05/2013 16:02
[Re: drakino]
Yes but how many tracks can 16meg address? Is it linear, so 18,000 track on 12meg equates to 24,000 tracks on 16meg? How many have people managed to get on their machines?
Hodge #080000452
