Page 2 of 2 < 1 2
#35601 - 03/08/2001 20:28 Re: MP3 Ripper [Re: Geoff]
Terminator
Loc: Dallas, TX
Ok heres something you could try. go download the binary from the following site:
http://www.animus-facticius.org/lame_dm/lame_dm_preset.zip
The presets are activated by "--dm-preset" followed by, "standard, xtreme, insane, metal"
Here is what the following presets specify:
Standard Preset = --nspsytune -V2 -mj -h --lowpass 19.5 -b112 --nssafejoint --athtype 4
--dm-highfreq 3
Xtreme Preset = --nspsytune -V2 -mj -h --lowpass 19.5 -b112 --nssafejoint --athtype 2
--dm-highfreq 3 -Y
Insane Preset = --nspsytune -V1 -mj -h --lowpass 19.5 -b112 --nssafejoint --athtype 2
I have been using the extreme preset and haven't had any problems so far. I have an amd duron running at 800mhz and i usually get 2x encoding speed. The nssafejoint switch is for a new more accurate joint stereo.
Sean
#35602 - 04/08/2001 00:15 Re: MP3 Ripper [Re: Geoff]
smu
Loc: Germany (Ruhrgebiet)
Hi.
Regarding encoding times of lame:
Using my settings posted earlier in this thread, lame encodes at about 80% of playing speed (or needs 72minutes to encode a 60 minute CD). If I use CBR encoding instead of VBR, it is much faster than this (but I can't remember exactly how fast, I think about 2x playing speed). That is on a PIII with 500MHz.
If you use EAC to rip, try using its backgroud encoding option (EAC -> EAC Options -> Tools -> On extraction, start external compressors queued in background). It really helps alot, especially when batch-encoding a whole bunch of CDs.
cu,
sven
proud MkII owner (12GB blue/green/smoked, #080000113)
#35603 - 04/08/2001 06:27 Re: MP3 Ripper [Re: tfabris]
Captain_Chaos
Loc: Amersfoort, The Netherlands
It does seem that MusicMatch generates bad headers though. I have to use Mp3-Tag Studio to fix my VBR headers before Winamp will work correctly with them (displaying the correct duration, accurate seeking, etc.)
#35604 - 04/08/2001 18:32 Re: MP3 Ripper [Re: jpski]
I haven't ripped any music for a while (getting my new computer set up). On the old machine, running Linux, I ran grip + lame and everything worked quite well.
On the new machine, I'm running Win2000 and I just spent the $20 on Audiograbber. I also have a snazzy Plextor 16/10/40A IDE CD-RW drive that allegedly does audo extraction at the full 40X. In practice, I'll get audio extraction at somewhere between 20 and 30x, and then lame (with the r3mix flags) runs at between 8x and 10x speed (on my 1GHz Athlon).
However...
My machine occasionally decides to just hang. Freeze. Hit the reset button. The problem seems related to the Plextor drive because when I switch to using my Toshiba DVD-ROM drive, everything works flawlessly (albeit much slower than the Plextor). I even upgraded my Plextor firmware to the latest release. No effect.
Anybody else had problems like this? Could my Plextor drive be flakey?
Also, of all the Windows extraction tools I've tried, they all pale in comparison to grip on Linux. grip is smart enough to run lame on the previous track while extracting the current one, and it has a GUI that doesn't drive you completely batty (unlike AudioGrabber which just gets all confused when CDDB hasn't heard of your CD). It's almost enough to make me want to set the machine up to dual boot -- purely to run grip. I actually tried running grip on Linux through VMware, but it turned out that audio extraction just doesn't seem to work that way at all. *sigh*
#35605 - 04/08/2001 19:44 Re: MP3 Ripper [Re: DWallach]
Terminator
Loc: Dallas, TX
Try installing an asapi driver. You can find a good free one here: http://www.vob.de/us/Downloads.htm
Sean
#35606 - 04/08/2001 19:50 Re: MP3 Ripper [Re: DWallach]
DarkStorm
Loc: Pompano Beach, Florida
Is the drive spinning up each time?
I used to have that problem when ripping, but Audiograbber has a feature that's called spin up disc before reading. It's under the rip offset tab under settings.
Don't know if that's your problem or not but maybe
Steve DarkStorm Designs
#35607 - 05/08/2001 08:05 Re: MP3 Ripper [Re: Terminator]
Amazing! This turned out to be the answer. I installed the ASAPI driver from the URL you listed, switched AudioGrabber to use the "ASPI Manager" instead of "Windows calls", selected "buffered burst copy", and everything now works great. (I already had "spin up disc" turned on.)
It even successfully ripped a used CD I have that my old computer couldn't even begin to rip properly.
Paging Mr. Fabris: please put this in the FAQ somewhere!
#35608 - 05/08/2001 10:29 Re: MP3 Ripper [Re: DWallach]
Terminator
Loc: Dallas, TX
I'm glad it worked, for some reason the versions of asapi that ship with windows and nt calls give plextor drives fits.
Sean
#35609 - 05/08/2001 12:17 Re: MP3 Ripper [Re: DWallach]
Done. Added it to the "Best way to rip" FAQ. Thanks.
#35610 - 05/08/2001 13:00 Re: MP3 Ripper [Re: Terminator]
EngelenH
Loc: Belgium/Holland
I bet that's why my sony 12x speed I use at work is choking too under W2k. Hmm, must try this.
Hans
PS. My plextor 16/10/40 at home burns cd's at 16 speed even while my DLT Tape drive is backing up and restoring stuff (at about 80 megs/minute)... Tried it today, never even got below 75 percent buffer. Gotta love Linux.
Mk2 - Blue & Red - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#35611 - 05/08/2001 20:18 Re: MP3 Ripper [Re: LTJBukem]
Akai
Loc: SF Bay Area, CA, USA
I've had good luck with "Media Box" + LAME.
Media box (www.e-soft.co.uk I believe) is a cool little ripper, but it also has fun playback features lilke auto-dj mixing (cross fade, etc)
The only two downers are:
1> It uses CDDB only, not any of the free alternatives (free as in speech that is)
2> it's $25 to register..
Otherwise I've been having great luck with it + 192k abr lame encoding.
Page 2 of 2 < 1 2
