Page 2 of 2 < 1 2
#35446 - 09/08/2001 09:49 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
Rewind on the kenwood does backspace; not sure which key it is on a rio remote, though I suspect it's cancel?
#35447 - 09/08/2001 09:50 Re: Search controls (was: Visuals on 2.0) [Re: altman]
Yes, I'm pretty sure that it's Cancel on the Rio Remote as well.
#35448 - 09/08/2001 09:54 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
how are we supposed to type the hex digits a-f when entering PINs?
Um, I'd say that you should choose to only name your PINs with decimal digits.
Since: a) you are the one making the PINs (you have to enter them yourself into emplode), and b) you can only enter PINs with the remote control, then it's a self-correcting system. Assign PINs that work.
The only odd thing is that Emplode shouldn't allow you to enter alphabetic PINs. Does it?
#35449 - 09/08/2001 11:02 Re: Search controls (was: Visuals on 2.0) [Re: tfabris]
tms13
Loc: Lochcarron and Edinburgh
Doh! I thought PINs were FIDs! TLA overload!
Toby Speight
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#35450 - 09/08/2001 11:08 Re: Search controls (was: Visuals on 2.0) [Re: altman]
tms13
You're half right: rewind deletes in the numeric entry fields (year and PIN), but not in the textual ones (the ones I'm most likely to mis-type!). For those,n rewind and ffd move through the displayed search results.
Cancel returns straight to your current visual (or info) in all cases AFAICT.
Toby Speight
Toby Speight
#35451 - 10/08/2001 03:55 Re: Visuals on 2.0 [Re: tms13]
tms13
I wrote:
> Somebody *please* tell me that the Toilet Floor renaming is just a joke. I'll lose what little respect I get if my empeg goes all PC...
Hmm, PC.  Public Convenience Floor?
Toby Speight
Toby Speight
#35452 - 10/08/2001 04:23 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
In the text search modes, the kenwood uses the AM- button for backspace.
#35453 - 10/08/2001 04:38 Re: Search controls (was: Visuals on 2.0) [Re: Roger]
tms13
The Rio remote doesn't have an AM button; the Source and Tuner buttons don't have any effect in text search.
[I've just discovered that Select-Mode and Info both toggle between "search by" and "append by" - perhaps that should be mentioned in the manual?]
Toby Speight
Toby Speight
#35454 - 10/08/2001 06:35 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
The fact that info alters the search mode is probably a bug. Or did you mean that the manual makes no mention of either button?
#35455 - 10/08/2001 06:38 Re: Search controls (was: Visuals on 2.0) [Re: Roger]
tms13
Yes.
I wasn't sure whether Info was supposed to have the same effect or not.
Toby Speight
Toby Speight
#35456 - 10/08/2001 09:26 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
Hmm. I could have sworn that Cancel on the Rio remote worked like backspace when doing alphanumeric searches. But I just tried it on 1.03, and it doesn't.
Rewind on the Rio Remote does work like backspace in the alphanumeric searches, but you have to hold down the button.
#35457 - 13/08/2001 07:42 Re: Search controls (was: Visuals on 2.0) [Re: tfabris]
tms13
Ah, I hadn't tried that (holding it down).
Now I've tried it, I can say I don't like it. If I want to backspace one character, it's hard to time it right - the autorepeat kicks in very soon, and I end up with the whole string being erased.
There has to be a better way - I suggest that Cancel should backspace until the string is empty.
BTW, my (Rio branded) remote seems a bit dodgy. It will work for a while, then stop working for 5 or 10 minutes. Is there an easy way to tell whether the remote or the player (Rio brand, 1.03 developer image) is at fault?
Toby Speight
Toby Speight
#35458 - 13/08/2001 07:49 Re: Search controls (was: Visuals on 2.0) [Re: tms13]
In v2.0, it does. I wonder why this didn't make it into v1.03?
Page 2 of 2 < 1 2
