#352151 - 16/05/2012 00:19 What's wrong with my television?
RobotCaleb
Anyone know what's wrong with my TV? It started doing this a few weeks back. So far it has always corrected itself after a few minutes at most. Only once has it done it while using it. Every other time it does it at boot.
http://imgur.com/a/Bcukp
#352153 - 16/05/2012 01:27 Re: What's wrong with my television? [Re: RobotCaleb]
It's all jacked up.
#352155 - 16/05/2012 01:33 Re: What's wrong with my television? [Re: wfaulk]
RobotCaleb
Indeed. I should add that it only does this on the left half.
#352163 - 16/05/2012 12:00 Re: What's wrong with my television? [Re: RobotCaleb]
First step is to determine if it's the TV itself doing that, or the device that you are using to provide the signal (eg. cable set-top box).
#352169 - 16/05/2012 12:17 Re: What's wrong with my television? [Re: mlord]
RobotCaleb
Definitely the TV. It persists across inputs and occurs when no input is live.
#352171 - 16/05/2012 12:37 Re: What's wrong with my television? [Re: RobotCaleb]
Well, the usual two possibilities come to mind then: (1) failing power supply (possibly due to #2), and/or (2) bad capacitor(s).
Have you googled for others with the same model and similar issues?
#352172 - 16/05/2012 12:41 Re: What's wrong with my television? [Re: mlord]
Actually, since you say it does it only when warming up, then perhaps it's a loose connection on a data (ribbon) cable inside. As it heats up, the metal expands, improving connections and making the problem go away.
Edited by mlord (16/05/2012 12:41)
#352212 - 16/05/2012 23:26 Re: What's wrong with my television? [Re: mlord]
The last time I saw something like that, a trip to the tube tester at the drug store solved the problem.
#352237 - 17/05/2012 11:56 Re: What's wrong with my television? [Re: gbeer]
"Tube"? What's a tube?
Oh, wait. My bicycle has tubes that give me trouble sometimes. Are you saying that his TV set is leaking? smile
Edited by tanstaafl. (17/05/2012 11:57)
Edit Reason: Re-posted because I answered the wrong post before.
