#35006 - 25/07/2001 09:45
Hard drive upgrade questions...
Greetings!
...and, yes, I read the FAQ and the warnings...
I am looking to upgrade the 2 x 20GB hard drives that are in my empeg to 2 x the new IBM 48GB drives. My questions are:
1) Has anyone used, or have seen any problems with these drives?
2) Does the drive formatting utility work to wipe / stress test both drives simultaneously (i.e., any drive plugged in), or would I need to do each drive individually? The FAQ refers to making certain to unplug any drive you want to save the data from, but it does not state if both the wipe and stress test will span the two drives.
3) Has anyone had problems copying music data from two source drives (i.e., /drive0/fids and /drive1/fids) and merging them onto a new single drive as the target (i.e., /drive0/fids on the new high capacity drive)? I fully expect to loose my loaded collection anyway, and will need to load the rest, but this will get me through that painful transition period if it works.
Any thoughts or comments welcome. I will let everyone know how the upgrade goes when complete. Paul G.
SN# 090000587 (40GB soon to be 96GB Smoke)
#35007 - 25/07/2001 11:11
Re: Hard drive upgrade questions...
[Re: pgrzelak]
Good questions.
I've never tried wiping two drive simultaneously. I recommend doing them one at a time anyway, so you can be sure which one is being stress tested.
In theory, combining the two FIDS directories should work. Anyone ever actually do that? ___________
#35008 - 25/07/2001 11:22
Yes, I upgraded the player I use here at Empeg Towers from wonky old 6G and 14G drives that Hugo found lying around, to a single nice new 20G Fujitsu and just copied the contents of each "fids" directory into the new one.
#35009 - 25/07/2001 12:53
[Re: pgrzelak]
There are problems with partitioning >32G drives with the version of fdisk on the player, I believe. You may need a newer one. Once partitioned, it should be fine.
#35010 - 25/07/2001 12:58
[Re: altman]
He was planning on using Mike's Builder Image, not the Fdisk on the player. Does that statement still count for Mike's Builder Image? ___________
#35011 - 25/07/2001 15:46
Greetings!
Indeed. I plan on using the diskbuilder image. If that is a problem, let me know.
I will do them one at a time. Probably for the best... They arrived today, so the fun is about to begin...
Paul G.
#35012 - 25/07/2001 15:50
[Re: pgrzelak]
If it works, you might have the honor of being the first 96gb empeg owner.
Hope the builder image works for you. ___________
#35013 - 25/07/2001 16:20
Loc: Penarth, UK
Oh no, I will loose my crown  - --
Rod, UK Mk2 64gig Red S/No.341 2xDell RioReceiver
- -- Rod, UK
#35014 - 25/07/2001 16:54
[Re: pgrzelak]
Yes, it applies to that image too. We've fixed it for another product, but the carplayer wasn't urgent as we didn't ship any single drives over 30gb...
#35015 - 25/07/2001 16:56
[Re: altman]
MIKE ! ! ! ! ! !
#35016 - 25/07/2001 17:21
Greetings!
Hmm... What kind of problems? I received a block count that looks suspiciously correct for a drive of this size...
Paul G.
#35017 - 25/07/2001 18:31
OK. I could not wait...
[Re: pgrzelak]
Greetings!
OK. I could not wait. The deed is done!
I did not notice any problems at all in generating the file systems on the new drives. If there is a known problem, please let me know. Everything seemed to go very smoothly, however.
I know that I should have stress tested the drives more, but I was impatient, and wanted to see this...
and this...
empeg single channel IDE
Probing primary interface...
hdb: IC25T048ATDA05-0, ATA DISK drive
hda: IC25T048ATDA05-0, ATA DISK drive
hda: IC25T048ATDA05-0, 45780MB w/1806kB Cache, CHS=5836/255/63
hdb: IC25T048ATDA05-0, 45780MB w/1806kB Cache, CHS=5836/255/63
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
empeg-car 1.03.
Damn roundoff and funny disk drive math!!! Plus, I already loaded a few essential utilities on the disk (displayserver, network utilities, a zip of the full debian distribution, etc.). Paul G.
SN# 090000587 (96GB Smoke)
#35018 - 26/07/2001 01:36
Re: OK. I could not wait...
[Re: pgrzelak]
Loc: Penarth, UK
Nice to see it working Paul, I have no excuse now  - --
- -- Rod, UK
#35019 - 26/07/2001 04:32
[Re: mardibloke]
Greetings!
The install went very smoothly. As far as I know so far, I only made one minor mistake, which I will go into detail later...
I did not try to use the disk builder image one two drives at the same time, but I did find that it would not work on two brand new drives in a row. Basically, the first went fine. I powered down, changed drives and restarted the player. It was unable to decompress the kernel onto the new (blank) drive, so I had to upload the builder software again. That software primed and pumped all of the partitions, so it must be run on any new drive. It would have blown away a used drive, but not a new one.
I began loading material from my old drives, but I found it was taking too long for my taste, and I was going to clean up and reload most of it anyway. I wanted to start fresh, so I stopped the disk to disk copy, and started with a clean empeg and emplode.
My mistake was in the hot glue. I needed to repair my unit when it arrived with a loose cable (the connection to the mainboard, not the drives), and I saw that it had no hot glue on the top of the drive or on the mainboard. I assumed I had no hot glue at all. Wrong! The underside of the drives was glued. I did not realize this until it was too late. I damaged the ribbon wire connector for the slave drive - popped off the back plate, so the ribbon was exposed on the back. I was able to fix it (more hot glue), and the drives test fine. I would, however, like to replace it in the long term. If anyone out there has a part number I should be looking for, please let me know. I know there is a part number for the Mark I in the FAQ.
[Additional: I have since checked out Videk and ordered part number 3018 - a dual drive model of the 3017 from the FAQ. I will soon find out if they ship to the US. Their site seems to allow international orders, but...]
Meanwhile, I am dumping my collection onto the empeg right now. Thanks to everyone for the help, to Tony for the FAQ and to everyone at empeg for the support and for a great product!!!
Paul G.
SN# 090000587 (96GB Smoke) Edited by pgrzelak on 26/07/01 04:57 PM.
#35020 - 26/07/2001 08:57
[Re: pgrzelak]
Loc: Albany, NY
Ordered and received a 48 gb IBM HD yesterday. It installed flawlessly with my 30 gb. Now I can fit my whole collection! Install was simple and both drives seem to function great together. It took a few tries to run upgrade program on it but once it "took" everything went smoothly.
#35021 - 26/07/2001 09:03
[Re: pgrzelak]
OOPS.
Okay, time to make another edit to that FAQ... ___________
#35022 - 26/07/2001 09:16
Greetings!
I should have been watching more carefully. My unit was shipped just as the hot glue was started. There was none on the main board or on the tops of the drives. Those ribbon cable connectors are very easy to dislodge. Fortunately, they are also easy to repair. It should hold, but I intend to replace it anyway.
The IBM 48GB drives are very nice so far. I continue to pour MP3s into it. I will be at this for a little while...
Paul G.
#35023 - 26/07/2001 09:31
[Re: pgrzelak]
The videk dual drive cable is no good for the mk2, it's very short.
The cable in the empeg is custom, but I don't think we have any stock of it I'm afraid...
#35024 - 26/07/2001 09:44
[Re: altman]
Greetings!
Well, the videk was worth a shot. I am certain I will be able to use it for another project.
As to the custom cable, I should be able to make one myself, but there is something nice about having the real thing. If any become available, let me know.
By the way, what was the issue with using the existing fdisk and upgrade utility on large drives? This drive did not seem to have any problems at all. Any symptoms I should watch for?
Paul G.
#35025 - 26/07/2001 11:04
[Re: pgrzelak]
ISTR it just got everything a bit wrong. It may be that v1.03 had the later version in it magically, such is the wonder of autobuild systems...
Mike/John?
#35026 - 26/07/2001 11:04
[Re: pgrzelak]
would you guys mind posting where you are getting the 48GB drives from, and how much you paid for them?? pricewatch.com still isn't listing them. My warranty is up in a month and i plan on cracking it open the day it's up...heheh.
|| loren.cox ||
#35027 - 26/07/2001 11:15
[Re: altman]
Except that I don't think Mike's builder-image on the download site has been touched since around 1.0...
#35028 - 26/07/2001 11:21
[Re: loren]
Loc: Albany, NY
I got mine at http://www.megahaus.com/ibm/ for $495 US dollars. As it becomes more available I'm sure you will be able to get it cheaper. I got to this site from the IBM site (how to order). Good luck
#35029 - 26/07/2001 12:15
[Re: rtundo]
Greetings!
Mine were from harddrive.com, and they were listed at $479 there. And they were in stock!!! Solutions4Sure (from the IBM page) has them backordered at $440, and Dirt Cheap Drives (one that I have used a bit) has them at $495. Have fun!
Paul G.
#35030 - 26/07/2001 12:17
Greetings!
Actually, when I put the autobuilder image in the upgrade utility, the comment field read 1.02 - if I remember correctly... Perhaps it was modified...
In any event, it seems healthy so far!
Paul G.
#35031 - 26/07/2001 16:42
Loc: Meije, Netherlands
Yep, I did, when I moved all music contents of the Mk1 to my Mk2 by transplanting the second drive. This works fine as the player looks on /drive1if it cannot find music files on /drive0. It goes as follows:
a) add all music files from disk1 onto whatever music files already are on the second disk:
mount -n -o remount,rw /drive1
cd /drive1/fids
cp /drive0/fids/* . (star space dot!)
mount -n -o remount,ro /drive1
sync
b) drop the disk into the Mk2, and remove all music files on it:
mount -n -o remount,rw /drive0
cd /drive0/var
rm database
rm playlists
rm tags
cd /drive0/fids
rm *
mount -n -o remount,ro /drive0
start the player, connect to it via emplode and let it rebuild the database, and voila: all music recovered! According to Mike (who authored this procedure) the player now uses the music from the second disk in addition to that on the first disk (which is nothing). The wonderful thing is that any *new* music is shared between the two disks depending on available space in that emplode puts music on the disk with the most space, first  .
(like rubbing a lamp . . . ) Henno
mk2 6 nr 6
Henno
mk2 [orange]6 [/orange]nr 6
#35032 - 26/07/2001 18:21
[Re: pgrzelak]
Loc: Penarth, UK
Paul, please could you keep us posted with how things turn out. I was considering the upgrade as only have 2gig free space now. However my Empeg runs a little hot IMHO, and thought I might be pushing my luck going for bigger capacity drives. Or at least that I should consider installing a fan.
- -- Rod, UK
#35033 - 27/07/2001 05:24
[Re: mardibloke]
Loc: Rochester, NY USA
To all you guys wrapped up in the largest empeg title, I want to help fund your project...sort of...do any of you want to sell an old drive? I was looking for a 20GB but I would be interested in any at the right price. Just a thought, -Doug
-Doug
Mk2-12G Blue (Now A/R Green)
-Doug Morrison
Mk2-32G Back light buttons, Neon red screen
#35034 - 27/07/2001 06:41
[Re: morrisdl]
Loc: Florida
Yeah, me too.
_~= Dearing =~_ "WAY too happy about having #99."
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#35035 - 27/07/2001 08:10
Scary Moments
[Re: pgrzelak]
Update:
I have been dumping music into the player over the past two days, pretty much non-stop. Unfortunately, I have to do the syncs in small bursts (very little available hard drive space, or dual CD), so I have been performing lots of small syncs. I have just hit my first FSCK.
WOW! That took a while! Got me very nervous for a moment there, until I finally saw a touch of blue in the progress bar.
Paul G.
